Question about Samsung Refrigerators
My samsung is not making any ice and have also seen some water at the base of the food center.
  • doctor_agha Aug 01, 2008
    Thanks for your kind reply. My refrigerator is a food center with a built in ice maker. The freezer is working fine but the ice dispenser is not dispensing any ice at all.
  • 833 Answers
I'm assuming that you're telling me that the freezer is not cold and that the unit has defrosted. Is the compressor running? If not, it may have gone bad, the thermostat may be bad or the defrost timer is stuck or defective. The last one is my favorite but the testing of these issues is complex.
Posted on Aug 01, 2008
Lid stuck on work bowl of kitchen aid processor
This tip is used to remove a stuck bowl from the base of a Kitchen Aid tilt-head mixer. It might work for your situation. Fill the bowl with very hot water (use the food shoot as a pour spout). Now use either frozen gel packs, or a bag of ice cubes, and lay the ice on top of the lid. Wait for a few minutes. The hot water with make bowl expand, ice will make lid shrink, thus loosening the tight lid. I'm assuming that the lid edge fits inside of the bowl, like most food processors do. Try to gently move the lid, and see if it'll give.
Mar 20, 2017 | Food Processors
How do I get it to produce ice?
Without a model# it is impossible to help you.. Sometimes it is simple and other times it is not. Samsung has a ton of issues related to icemakers and could be as simple as turning it on "usually done through the front controls on samsungs" or you could have one or more bad water valves in it. (just because the water works doesn't mean the ice will.. It is two different valves,or sides of the valve).
A way to check for a bad valve is to defrost the fridge. 24 hours,unplugged,doors open. This will clear any ice build up within a line. Plug back in and see if it starts making ice. If the problem comes back then the valve is usually seeping and will stop making ice again. This method is free and completely tool-less but takes time and you have to move your food.
Feb 03, 2018 | Samsung Refrigerators
Why has the water dispenser stopped working all of a sudden. Do the lines freeze up or is there an on off function on the control panel
Without knowing what make / model fridge it is nearly impossible to say , however, most domestic fridge have a water tank in the base of the food compartment which stores the water before going into the freezer dispenser. Have a look behind the crisper drawers for it. If the food compartment is too cold, this tank can freeze up and stop water from going into the dispenser. Is it still making ice? If so, the water valve which is normally 2 parts (1 for ice making and the other for water dispensing) may have failed.
Apr 09, 2015 | Refrigerators
How can I make my Samsung Food Center produce more ice?
Contact after sales support. Could be an issue with the compressor but it should be covered by manufacturers warranty
Jan 18, 2018 | LG Dryers
Liquidiser base jammed
No...No! Don't try any waters there!! Call Authorized Service Center.
Apr 23, 2014 | Kenwood Multi Pro FP730 Food Processor
Ice maker not dumping ice.
sounds like the icemaker timing or motor is bad. those parts are not replaceable on this model, you would need a new icemaker assembly
May 02, 2012 | Samsung Refrigerators
I have a bottom drawer freezer Samsung refrigerator (Model: rb217abw) that is two months old. The ice maker fills with water and I can hear the mechanism drop the water into the ice bucket causing the...
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze, blocking or diverting the water.. You can take the water line off the valve and watch to see if it drips.
Aug 25, 2009 | Refrigerators
Fridge drain is overflowing into base of fridge, causing build-up of ice over base, which then 'sticks' the salad boxes to the base of the fridge, making them difficult to draw out. I have to scrape the...
Some insect would have gone into the drain pipe and blocked the outlet for the water to flow and it gets collected inside.
First please clean the drain pipe and remove any block.
Defrost your refrigerator at least once in three days.
Excess ice formed in the freezer chamber will result in less cooling and melting of ice and make it run down.
The above remedies should solve your problem
Jul 10, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Samsung RS26 frozen water line in Ice maker
all you can really do is put heat to it (hair dryer) but be careful that you don't melt the water tube. or you can remove food and leave door open til it melts
Jun 23, 2009 | Samsung RS2630SH Side by Side Refrigerator
Refrigerators Logo
197 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
