Question about Toshiba MW20FN1 20 in. TV/VCR/DVD Combo
I have just recieved froma friend a Toshiba MW20FN1 (-R) Television and there is no remote with it. I have purchased a universal remote. My problem is I can't get the tv to switch from TV to Cable so as to search or set up all of the channels. It will not go over 20 channels. What is the universal remote code for this TV and how do I get the tv to correctly go up and down to all of the cable channels. Thanks.
techman
  • 3130 Answers
SOURCE: my remote control does not work
You could have a defective IR sensor in the tv set that sends the infared signal to the MIcroprocessor IC. These are something you cant just replace, as it needs to be trouble shot with a scope to see if theres a data signal comming out of the sensor and if there is it could be a bad solder connection somewhere between the sensor plug to the Main IC. Also could be the B+ that supplys voltage to the sensor. Unless you have had electronic repoair experience, You should have a pro assist you with this repair. Sorry I couldnt assist you more with this . Good Luck
Posted on Jul 06, 2006
SOURCE: Code for Direct TV remote control
Program AV1 with 20695, program TV with 10765, then switch to AV1, press select/mute, enter 933, and press select
This will allow volume and mute controls while in DTV mode and allow power on and off while in TV mode. This worked for me on the RC32 remote control.
Best of luck
Posted on Dec 03, 2007
SOURCE: 30HF85 TV with CT-877 remote, which doesn't work.
I had the same problem with my remote...over time it slowly stopped working. (sorry for poor terminology) I noticed that one of the battery terminals was corroded and that the metal connecting the battery to the board was completely gone. I simply swapped this out with one from another remote and now its working fine. Seems the only issue is that the battery was not connected.
I hope this helps.
Posted on Apr 05, 2008
  • 4 Answers
SOURCE: Need help to re-program Toshiba remote that came with MW20FM1
Check out Toshiba Customer Support. They e-mailed me the instructions to reset the V-Chip.
customer_support@tacp.com
Posted on Sep 14, 2008
  • 13433 Answers
SOURCE: remote control not working
is the remote original and ment for the television? if not I would suggest a universal remote from any local retail shop to replace the non working remote.
Posted on Jan 02, 2009
I need codes for universal remote for my Toshiba 2006 television
Try these:
TOSHIBA TV 3 Digit Remote Control Codes:
013, 049, 089, 105, 109, 117, 118, 120, 159, 178
TOSHIBA TV 4 Digit Remote Control Codes:
0260, 0358, 0394, 0924, 0398, 0983, 0973
Read more: http://codesforuniversalremotes.com/universal-remote-control-codes-toshiba-tvs/#ixzz3piGVqocr
Oct 26, 2015 | Toshiba Televison & Video
Toshiba Color Television 36A43 Lost the original remote and purchased a universal remote. Tried to program using all four systems to no avail. I require the universal remote code to program for this TV
Place one remote on table, place other (new) remote facing old remote, then push the program button on new remote, remotes IR screens has to face each other to make this work. and if you've tried to program the new one before, you will have to clear the new ones memory first. Good luck.
Jul 13, 2011 | Televison & Video
Program remote to a direct tv reciever
You are most likely out of luck using these as universal remotes. You are better off purchasing a Logitech remote and programing it for the Polaroid and your Directv box.
Jan 06, 2009 | Polaroid FLM-3232 Television
Remote control not working
Jan 02, 2009 | Toshiba 32A33 32" TV
No cable. converter box needed for Toshiba MW20FN1?
www.radioshack.com , get a digital stream 1500150, I sell them, they work wonderful. I personally have been selling them for over a year now, and I've only ever had to exchange one once (and we do thousands :-) )
Jan 02, 2009 | Toshiba MW20F51 20 in. TV/VCR/DVD Combo
Lost the codes for phillips universal remote control
Those little booklets are hard to keep up with. Try this website http://www.universal-remote.net/philipsmagnavox.html
Dec 13, 2008 | Philips PM335 Remote Control
REMOTE DOES NOT WORK ON SYLVANIA TV
It sounds more like a problem with the TV, than the remotes. It's possible that the IR reciever or microprocessor for it have pooped out. It's something that would have to be serviced by a shop, but due to the age and size it would likely be cheaper to replace the whole TV.
Dec 04, 2007 | RCA F25432 25" TV
Help
Hi,I have this same model Tv. The Remote control Model is CT-90037 http://www.tacp.com/televisions/product.asp?model=CT-90037 You can pick it up often times on Ebay or Amazon. Hope that helps.
Sep 17, 2006 | Toshiba 50A50 50" Rear Projection...
Toshiba MW20FN1 20 in. TV/VCR/DVD Combo Logo
66 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
