Question about Continental Electric CE23581 4Cup Coffee Maker
Coffe maker turns on and drips a little into the filter then stops. The coffee grounds are still dry and it doesnt make coffee. The plate is hot. The coffees not.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 37 Answers
First check that the thermo switch is not opening at to low a temperature. Can you measure the hot plate temperature? It should be over 180 degrees. If not then it the thermo. I would replace the Thermo switch, These are not soldered in because of the heat application. You must use mechanical connections, such as crimp splicing.
The other option is that the water can't flow into the heating element Or from the element. There is a one way value in the feed path that needs to be checked that it is functioning. You can test it with straws on units that do not have a removable water tank. locate the water drain in the tank and take the straw and place it at that drain and blow hard. You should hear air flow through the unit and out the drip tank. You need a far amount of seal at the bottom for this to work, I built a ridged tube with a cup on the bottom. This will not work if there is a bar grid were the water is pored.
Good luck.
Posted on Mar 14, 2011
Why does coffee come out while pouring in water its a bunn 10 cup coffee maker
The Bunn has a little stopper that closes the water drain port in the reservoir while the lid is open. You can see a little white plastic pin protruding up out of the grate with the lid open. When you close the lid, it pushes on that pin which causes the stopper to lift off the drain port, allowing the water in the reservoir to enter the heating tank.
If water is entering the coffee basket BEFORE the lid is closed, then something is wrong with that little stopper. It may have a chunk of debris on it preventing it from sealing, or it may be deteriorated, torn, disconnected, etc.
Only way to know is to remove the the screws in the grate and pull the top off exposing the reservoir, and the stopper assembly. The little plastic flapper disc should be seated in the reservoir drain port. It should be relatively flat (not wrinkled) and covering the drain port completely. Test it by pouring some water into the reservoir. If it drains out without you activating the stopper, then a repair is needed.
Move the lever up and down and check its operation. The arm must move freely and close when released. There should be no dirt or debris on the sealing surface of the flapper nor on the sealing surface of the drain port. Gently clean with vinegar as necessary. If the seal is damaged, then a replacement is required.
Nov 29, 2014 | Bunn 10 Cup Home Coffee Brewer
Very little water comes through...small drips...enough to get the grounds wet but not enough to make coffee.
mix half white vinegar and water together...then pour this solution in just as you would if you were making coffe....minus the coffe grounds of course... then run it through a cycle and then run clear water through again... and you will be good to go...do this once a month or so to keep it working great...
heatman101
Aug 22, 2010 | Krups Small Appliances Espresso Machine
I purchased the espresso maker above. My problem is the strength of the espresso brewed. It comes out strong at first, but by the end of the dripping it turns watery. By the time the dripping stops the...
to have a good espresso depends from many factors, first of all is the coffe blend, the grind, then water quality, espresso maker pressure and temperature, and that is just the most important!...I think you can try with a REAL espresso blend with very thin grind, let the water flow without filter, then when the light switch on put the filter, you can also try to warm first for steam and after commute to make espresso and wait for right temperature. Finally you will obtain a discreete espresso, never as in the professional machines!...otherwise you have to invest such 2000 euros for a professional good coffe machine
Aug 22, 2010 | Ariete Cafe Retro Espresso Machine
Water will not pass through seems clogged
Sometimes coffee grounds get into the intake if you don't use the intake filter. Unplug, set the pot aside and then turn the coffe maker upside down in a sink with a good hose sprayer. Direct the water up into the intake side of the coffe maker with the filter out.
Then refill and see if water will flow through. If it works, run vinegar or a pot of water with a tablespoon of dissolved baking soda (dissolve in pot first or it will clog the coffee maker).
It worked for me.
Apr 24, 2010 | Cuisinart DCC-1200 Coffee Maker
Can I adjust the water flow for finely ground coffee?
You probably have coffee ground for a drip coffee pot, not an automatic drip coffee maker. With a drip coffee pot, you put the coffee in and add the hot water on top of that. You might want to try a coffee press. They are fantastic for the finer grinds of coffee. Some Mexican coffees are ground almost as fine as flour and a press works great. You can get a press for about $12 & up.
Jan 30, 2009 | Cuisinart DCC-1200 Coffee Maker
COFFEE GROUNDS COME THROUGH THE HOLES IN COFFEE BASKET. WHAT TYPE COFFE SHOULD I USE TO ELIMINATE THIS? IS THEIR A FILTER MADE FOR TJHIS URN
Your coffee is too finely ground for your basket. 2 solutions: buy "regular" ground coffee from now on, OR use filters inside the basket. Many 30 cup or 45 cup maker's baskets are sized so that a normal filter, flattened-out, and a small hole torn in the middle will fit into basket and prevent the grounds from passing through.
Oct 05, 2008 | Hamilton Beach GE 42-Cup Coffee Urn Coffee...
No flow
Tamp the coffee a little less - run water through filter basket to make sure it is dripping out before filling with espresso grounds. Dry the filter thoroughly before inserting coffee grounds. I would reccomend using double filter basket only instead of the single.
Aug 11, 2008 | Cuisinart EM-200 Espresso Machine
Leaks after coffe dispenses
I've found that the reason is usually because the "coffee tank filter screen" is sitting crooked in its placement and causes the valve to be propped open. But with boiling hot coffee in the tank, it's hard to fix. Sometimes we can tap it with a butter knife and it will sit back into place, and sometimes we've drained all the coffee into a pitcher, waited for the plastic parts to cool, repositioned the filter, and put the coffee back in and turned the pot back on. Depends on how far the valve is propped open and how quickly the coffee is coming out. Hope that helps! :)
May 30, 2008 | Hamilton Beach BrewStation 47214 Coffee...
Continental Electric CE23581 4Cup Coffee Maker Logo
152 people viewed this question
Top Continental Electric Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Continental Electric Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
