Question about ViewSonic NX2232w TV
ViewSonic NX2232w 22" monitor. Model
    President:
  • 1,961 Answers
This kind of problem usually caused by a cold solder of components at the boards.You need to open the back cover of the TV and have a visual inspection on the boards.
here are the boards to check.
1.power supply board -this board is where the power cord is connected use a soldering iron to resolder all the possible loose board components.check also all the connectors/cables be sure it fits the socket and nothing is loose.Replace also any bulging capacitors use capacitor of the same rating.
2.The inverter board- this board is a high voltage board.The power input is 24 volts DC and the output is 100-200 volts be careful not to touch them during power on.The usual faulty here is the wiring connectors just re tighten the connectors and solder the connector terminals.
Posted on Mar 13, 2011
  • Danilo Baraquiel
    Danilo Baraquiel Mar 13, 2011
    3. The T-CON (Timing Control or LCD controller) board (on the LCD panel assembly). It transfer the universal image signal of TTL and LVDS signal to specific TFT (Thin Film Transistor) LCD.
    This
    is the interface board that talks to the Logic board and the LCD panel
    to produce pictures on the screen. White/gray glowing screen when it
    fails or not getting the voltage from the logic board (the 5 or 12vdc is
    supplied by switched transistor on the logic board). Notes: T-CON board is mounted under the metal cover shield.
    Common failures:
    Scrambled pictures, Lines, multiple pictures, color smears/blotches, rolling pictures after warm up.
    Blown surface mounted fuse.
    No pictures, very dark screen almost like there is no backlights.this board is availablle on line at shoppejimmy.com. heres the link you can inquire here
    you can order here a repair kit for your viewsonic TV.Just follow this link
We have a Viewsonic VA2226W that goes to black screen after 15 seconds or so, is it toast or is there a way to fix?ViewSonic monitor VA2226w
Make sure you are supplying a valid timing mode to the display. Call ViewSonic technical support to resolve your issue.
Oct 01, 2014 | ViewSonic VA2226w 22" Widescreen LCD...
Why is my monitor only showing white?
Your LED Panel looks got damage, no need inverter to repair, just replace your LCD Panel
Aug 30, 2014 | DMCOM Viewsonic Vx2250wm-led 22-inch...
Monitor flashes on then off power light stays on whats wrong?? shows screen for about 3 seconds then goes black
Some 22" Viewsonics will have worn out bulging capacitors in the power supply that causes this symptom.
Monitor Mike
Apr 14, 2010 | ViewSonic 22" FLAT SCREEN CRT BLACK...
Trying to pack
Few steps to take the stand and base off the 22" ViewSonic VX2235WM
1- Squeeze the bottom of the base to take the base off from the collar
2-This step is very important. The collar has two parts snapped in together, with 3 snap in each side. Carefully use small flat screw driver to take off the back side of collar
Feb 19, 2010 | ViewSonic VX2235WM Monitor
Screen goes blank
abandoned problem for now. will look for inverter board or parts from another monitor
May 12, 2009 | ViewSonic 22" FLAT SCREEN CRT BLACK...
In game border issues
Hi...there,
It's seems you've got a busted panel...but send me the screen shots anyways... to this address @ cjt@3rd-rocks.com
Nov 28, 2008 | ViewSonic Computers & Internet
ViewSonic NX2232w TV Logo
246 people viewed this question
Top ViewSonic Televison & Video Experts
Are you a ViewSonic Televison and Video Expert? Answer questions, earn points and help others
