Question about Panasonic PV-C2061 20 in. TV/VCR Combo
Found a spring inside vcr , i dont know where it goes
    President:
  • 1,623 Answers
The spring could go in a lot of places, does the vcr function correctly, or did you attempt to take it apart. Either way, how you can expect anyone to hlp you with that is beyond my capabilities
Posted on Mar 13, 2011
I FOUND A SPRING IN MY WINDOW AT THE BOTTOM 2006 COBALT
I have seen a spring on the window regulator which helps raise the window. Don't know about GM products made in the past 10 yrs.
You might look at a regulator at the dealer and see if it has one and if it looks like what you saw.
Jun 26, 2012 | 2004 Chevrolet Cobalt
Front load washer, gray seal came out, found a metal loop with a spring attached to it, I believe it just needs to be put back in but i don't know where it goes
it goes around the lip on the front of the machine inside the door after the boot is put into place.  it has to be seated correctly or leaks will occur..
Jul 31, 2010 | Kenmore Washing Machines
How to change the battery in a CASIO CA53W-1 Watch with Calculator
open up the watch. there is a small spring that could fall out. dont lose it. use a small pin to pull battery clip off. put new battery in, replace strap and pink plastic. short the tiny contact labeled AC with the + on the battery. check that the clock now operates. lastly, reassemble
there is a spring inside that goes betweeen one of the contact holes. dont know which.
Jun 03, 2010 | Casio Watches
The spring has fell out of the head when i was changing top i dont know how it goes back together
pull the black thing with the little blades until it detach, put the spring inside the hole, reassemble
May 09, 2010 | Braun Silk-epil 3370 Epilator
Part fell out of gun dont know where it goes
is it the carrier support spring or the trigger spring?
go to www.winchester.com look for owners manual for model 94 come times the site dont work well.you may have to call them and ask for a schematic parts break down they will send it to you or e-mail it.
Oct 28, 2009 | Sport & Outdoor - Others
Tape wont eject small spring found
Take off top of vcr to expose the tape carriage lift tape door, on the lhs/rhs you shouls see the other small spring fit the spring that you have to the opposite side and try to eject your video cassette, the spring is the part that is stopping from ejecting the tape hiopefully once you have reattached the spring all should be well.
Aug 14, 2009 | Sharp VC-A560U VHS VCR
The spring from the back where you load the paper has pop out and I dont know where it goes, and now I can not print anything because the paper cannot go through? Can someone help and guide me to put
The location of the spring is located near of the sensor.The sensor is attached by the sweveld arm then install the spring in the center of the pivot area of the sensor.So that the sensor will goes up ,it need a spring to do the act.
May 28, 2009 | Epson Office Equipment & Supplies
I dont know how to hook up my rca receiver to my dvd player and my tv and vcr so i can have it all running i dont know what wires go where
first check your receiver if it has inputs for all those gadgets you wanted connected. in your input function selector see if there are options for your dvd, tv, vcr. if it does have all those inputs then just connect all the audio output left/right rca jacks of your gadgets to each input function of your receiver. your VCR though is different, you have to connect the receiver input to vcr output. the vcr record goes to the vcr input connections. your TV, if it has got any audio out then connect to the audio in function of your receiver.
May 03, 2008 | Audio Players & Recorders
What do I do when my Emerson TV keeps turning off by itself?
I had the same problem with mine turning off after 3-5 seconds. After much research I found a suggestion that on some combo units the vcr part could have a power supply cutout if it is not working correctly. I tried to insert a tape and found that the tape mechanism would not accept a tape. I used a little bit of force and managed to insert a tape. I then played the tape forwards and backwards and the power stayed on! I ejected the tape and found the TV then worked just fine. The power has now been on for over one hour. I hope this give you another avenue to try and fix your problem.
Nov 30, 2007 | Televison & Video
Panasonic PV-C2061 20 in. TV/VCR Combo Logo
27 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
