Question about Husqvarna Daisy 310
I have a husqvarna viking sew easy 310 machine and I cannot get the bobbin back in correctly
  • 87 Answers
SOURCE: Threading a husqvarna viking 3610
This should be your machine:
http://www.sewingmanuals.com/Viking_Pics/Viking_3610i1.jpg
Sewingmanuals.com shows that they have this downloadable in Adobe PDF format here:
http://www.sewingmanuals.com/Sewing_Machine_Manuals/Viking.htm
#37 in the list as of me posting this. You can get a CD version too but you'll just pay more and wait longer for the same thing. Once you have it print the manual (preferably both sides to keep it small) ang you'll have it. You can also peruse eBay to see if anyone is selling a manual but I doubt that will yield regular results. The machine looks to be pretty basic and standard but it's best you have the manual to get the most out of the machine. Also be sure to check the cleaning and lubrication section and go through the process so that the machine is in top working order before you put it into regular use - saves a lot of headaches.
Posted on Apr 28, 2008
SOURCE: Husqvarna Viking Designer 1
Remove bobbin case,clean sencers with a soft brush.At 10 o"clock and 5 O'clock positions approx.
Posted on Jul 08, 2008
  • 8 Answers
SOURCE: Need manual for Scandinavia 200 sewing machine
I have one.
Posted on May 25, 2009
  • 371 Answers
SOURCE: husqvarna sewing machine - viking 400
Take to authorized Husqvarna Viking dealer for repair. This is not something that can be done by the owner. Check Husqvarna Viking website for dealer closest too you.
Posted on Sep 24, 2009
RichSew
  • 184 Answers
SOURCE: The bobbin on my Husqvarna sewing machine (Viking
If your bobbin still has thread on it, remove it by hand and then try to pull the bobbin off the winder.
Posted on Oct 15, 2010
Can i use a metal bobbin with husqvarna 1100?
What is important is that the bobbin is compatible with your machine. Not all bobbins will work even though they may fit into the machine. Using the correct bobbin is very important for a successful sewing experience. For the few dollars it will cost, purchase the right bobbin for your machine.
http://www.sewingpartsonline.com/husqvarna-viking-1100-sewing-machine-parts.aspx
Husqvarna Viking Concave Bobbins for 1 1100 1090
Nov 30, 2016 | Sewing Machines
Husqvarna viking sewing machine bobbin
Could the part number be 4011770? I've found the Viking 7 bobbins here: http://www.mysewingmachineparts.com/top-quality-metal-sewing-machine-bobbins-4011770-husqvarna-viking/ . Another site with them is http://www.sewingpartsonline.com/bobbin-viking-4011770.aspx . This bobbin is compatible with the Husqvarna Viking 7, 49, 51, 52, 21 & 21E . It probably will work for other machines. Sears also has them listed as 11770: http://www.sears.com/generic-viking-sewing-machine-bobbins-sewing-machine/p-SPM6124767105?prdNo=1&blockNo=1&blockType=G1 .
I also found these bobbins: http://www.amazon.com/Viking-Metal-Bobbins-5-pkg/dp/B000YZ5QSC . The part number appears to be 1702.
I hope this helps.
(googling Husqvarna Viking metal bobbins found a number of hits.)
Mar 05, 2013 | Husqvarna Viking 1
Viking husqvarna classica 100, thread tension
I suspect you are correctly threading the machine but the timing of the needle and bobbin hook is off. When the threaded needle goes into the bobbin area, a pointed hook grabs the thread and loops it with the bobbin thread. Something is catching when the needle starts to come up that is not allowing the bobbin thread to be pulled back through the needle plate opening by the upper thread. With machine threaded and bobbin in place, have the bobbin area open if possible and watch the thread interaction when the needle goes down. To set the hook/needle timing, normally covers have to be removed. Suggest taking it to an authorized Husqvarna Viking dealer for service. You can find the nearest dealer by click on the "Dealer" link at http://www.husqvarnaviking.com
Good luck.
Jan 19, 2010 | Husqvarna Viking 1
Thread bunching up around bobbin
If you do not have a user guide, you might want to find one. Try ebay or have an authorized Husqvarna Viking dealer order you one. In fact I would find your nearest authorized Husqvarnia Viking dealer and visit them with you machine. They should be able to help you and usually are very helpful even if you didn't buy the machine from them. If they determine it is correctly threaded and the bobbin is ok, have it serviced by an authorized Husqvarna Viking dealer or have them send it to Husqvarna Viking (SVP) Technical Service Dept in Tennessee for service. The machine should give you years of good performance.
Use only genuine Husqvarna Viking bobbins.
To find an authorized dealer near you, check the Husqvarna Viking website - http://www.husqvarnaviking.com/us
Good luck.
Sep 26, 2009 | Husqvarna Sewing Machines
Viking Husqvarna #1 + - A bobbin was stuck on the winder and I pulled it off. The black metal clip broke and came flying off. Now the machine thinks it has a bobbin on the winder and won't move the sewing...
The black plastic ring must be put back on with it oriented correctly. It can be a bit tricky, but experiment different ways.
Another small part may have come off too. If you can't get it, a Viking tech can do it for you without much trouble.
Jul 10, 2009 | Husqvarna Viking 1
Bobbin won't engage/turn
Doesn't sound good. If bobbin is in correctly, recommend taking machine to an authorized Husqvarna Viking dealer for service or have them send to Husqvarna Viking (SVP) Service Technical Department for them to repair. A list of authorized Husqvarna Viking dealers can be found at their website - http://www.husqvarnaviking.com/us
Good luck.
Apr 26, 2009 | Husqvarna Designer I
I filled the Bobbin, now how do I get it to go back to sewing
Something didn't click back in place when you removed the bobbin from the winding mechanism. Try winding another bobbin. Make sure it stops, then remove it. If the problem continues, take it to an authorized Husqvarna Viking dealer. They should still be able to take a look at it. Check Husqvarna Viking website for dealer closest too you.
Dec 16, 2008 | Husqvarna Viking 1
Missing bobbin case and bobbins Husqvarna 4000-serie sewing machine
ask where Husquvana machines are sold. google dealers if you don't know.
Oct 24, 2008 | Husqvarna Sewing Machines
Sewing Machines Logo
656 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Derek Massey
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
