Question about LG 47LG60 LCD TV
I can't hook up surround sound because there is outputs
    President:
  • 1,623 Answers
There should be an audio out connection that you can feed to the input on the surround speakers. Then you will have surround sound
Posted on Mar 13, 2011
  • joshchild Mar 20, 2011
    there is no audio out connection on the tv
Have lenoxx ht 500 surround sound speakers & dvd but dvd is broken, need to purchase another dvd player but can't source lenoxx model, what other models can i connect surround sound to? or whe
If your surround sound receiver unit has rca audio inputs(red/white), you can hook up any brand of DVD player that has rca outputs. You would hook the yellow output from DVD player to yellow input on TV. Hook red/white output from DVD player to red/white input on surround receiver. Hope this helps.
Jan 03, 2012 | Audio Players & Recorders
I want surround sound. How do I hook up my audio 5.1 RVC-884VBK, with my HDbox and LCD TV? It's too confusing. What hooks to what? Currently the HD box and blueray DVD is hooked straight to TV ...
Does you television have an "Optical Audio Output"? This would be the best and easiest way to get surround sound from your system. If your TV has an optical output the you can use an Optical Cable to connect the TV to the reciver. This way whatever you are watching from the TV will be in surround sound. The HDMI connection sends a surround sound signal from each device to the television. If you connect it to this output on the TV then make sure the optical output is turned on in you telivison's menu. If your TV does not have an Optical Audio Output then you will need to connect each optical output from the blu-ray and HDbox to your reciever. Your reciever will need to have two Input channels(one for each device). Then you can select that input to the device(blu-ray or HDbox) that you are using. The optical cable is the best way to go for surround sound because it is pure digital and produces the best sound. If the HDbox or Blu-Ray does not have an optical output then you will need the six rca jacks to get the surround sound. Let me know further info on what you have so I can assist you more.
Jun 26, 2010 | JVC RX-884V Receiver
Audio output on TV
Sounds like you have it hooked up properly. Be aware that if there is not a digitally encoded signal for surround sound [they don't always do that] you simply won't have surround sound. Usually there is a mode in your receiver/amplifier that will allow you to simulate surround sound. An example of that would be "theater" or "hall" sound. Try it with a DVD known to have surround sound encoding [most of them do] and see if it works that way. If it doesn't then check your owners manual for information about how to make sure that feature is actually turned "on".
Apr 16, 2010 | iLO Televison & Video
Im trying to hook up surround sounds on a 50in lg
Use the audio jacks in the Monitor Output section. See pages 9 and 19 of the manual:
http://www.hdtvsolutions.com/pdf/50PX5D-0314-50px4dman.pdf
Nov 17, 2009 | LG 50PX5D 50 in. Plasma HDTV
Sharp LC-42SB45U
You Have to check The owners manuals for both products to see if you are using the correct switching method to use your television with the surround sound.There is usually a setting for each unit that must be set for the correct signal path to the amplifier output to the speakers. The way to test this out is to use the first input on the surround sound unit for the television. Hook- up the output of the sound for the television to first input on the surround sound amplifier.Set the surround sound amplifier to the first setting and test to see if it is working. If still not working check the televisions sound output section in your owners manual and see if you have to set the output to the line out sound and turn off the television speakers output.If this is true make this adjustment with the on screen menu and test the sound again.If still no sound output there may me a problem with the output sound section of you television. You should then check the Sharp website for the frequently asked question and troubleshooting sections to see if similar problems have been posted for this problem and have answers.If all this fails you should contact customer service for both units and ask for technical assistance for your problem. Hope this helps you with your problem.
Mar 05, 2009 | Sharp Aquos LC-45GD4U 45 in. LCD HDTV
Cannot get digital output
Digital output is for the reproduction of 5.1 or higher surround sound.  Though it will support 2.0 audio it is not meant to be hooked up to a tv, but meant to be hooked up to a surround sound reproduction device.
Jan 06, 2009 | RCA DRC8295 DVD Recorder/VCR Combo
Kenwood VR6070 speaker/amp problems
unit needs repair. Look at the b speakers. Conect a speaker or two to the B position. If you have no sound than your surrond sound is ok and the unit is bad. Sound comes directly into the b speaker and not threw the surrond system. My 6070 has a cold start up problem. no sound. time to purchase a new one. to costly to repair.
Dec 30, 2008 | Kenwood VR-6070 Receiver
Hooking up new tv to surround sound
I recently purchased a vizio 37" LCD tv, I have tried everything in hooking up my Sony DVD surround system to the TV. However, I found no audio output on this TV. Could you tell me if there is a way to hook the tv directly up to the surround without an output?
Is there something else I need to buy?
Feb 17, 2008 | Vizio VX32L Television
Hooking up video
I am assuming that you are using a surround sound system?If so on the back of the satellite receiver you will have RCA cables labled yellow ,red,white uuse an rca cable to run from the output on the back of the sat box to an rca input on the surround sound unit.the inputs should be labled on the back of the surround sound unit.once you have the sat box plugged in look for the output on the surround sound (rca cables) run one set of rca cables to the rca cable input of the Tv.on the original tv remote select the tv input that is the cable from the surround sound is plugged in to . make sure the surround sound unit input is selected to the input that the sat box is plugged into.this will give you surround sound from your satellite receiver,repeat with your DVD player plugging the DVD rca cable output to another empty input on the surround sound.to switch between the sat box (satellite TV) to DvD select another input on the surround sound unit.Try to correspond the units you are plugging into the surround sound to the correct name of the component on the back of the surround sound unit to avoid confussion.any questions,Im here to help.If this works rate me FIXYA! if it helps.GOOD LUCK!
Nov 18, 2007 | Panasonic SC-HT40 System
LG 47LG60 LCD TV Logo
143 people viewed this question
Computer Repairing
Computer Repairing
