Question about NetGear WGR614 Wireless Router
Trying to connect wii to internet....its asking me for a security key
    President:
  • 1,851 Answers
You can locate your security key in the router settings. Use your computer and with any internet browser log in the router's settings page. Navigate to Wireless network - security. At this page you will locate the security key and all the rest settings about the Wi-Fi. Write at asafe place SSID and security code in order to use them anytime you need them.
In case of a problem or clarification or further details needed for logging at the router's page, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct fixya link: http://www.fixya.com/users/technical114
Add a comment
Posted on Mar 13, 2011
  • 49 Answers
1. Open your browse.
2. Then type in the address bar http://192.168.1.1/or http://192.168.0.1/
(Try both, one of them will work)
3. It will ask you for a username and password. By default the username is admin and password is password.
Once you're on the setup page of your router click on the wireless settings on the left hand panel. Then look for the wireless security settings - if the security is set to WEP - Key1 will be the network key or which ever has a tick. Or if the security is set to WPA the passphrase is your network key.
    President:
  • 1,623 Answers
Your wireless key is written on a label on the bottom of the router it will be network security key or wireless security key. use that to connect the wii
  • 35 Answers
Maybe you set the WEP security in you WiFi Router, if you hace access to console http://192.168.0.1 you can look at it.
Hope will help
Regards,
HOW TO I GET MY WII TO CONNECT TO THE INTERNET
1.Power on your Wii console and press the A Button on the Wii Remote to reach the Wii main menu. Use the Wii Remote to select the "Wii" button.
2.Select "Wii Settings" to access the "Wii System Settings" menu.
3.Using the arrow on the right side of the screen, scroll to page two and select "Internet."
4.Select "Connection Settings."
5.Select "Connection 1: None."
  • If you do not have an empty connection slot, you will need to clear a slot.
6.Click on "Wireless Connection," then click "Search for an Access Point."
  • If using a wired Internet connection,
7.Select "OK." The Wii will display all the wireless networks it finds.
8.Select the wireless network that is yours.(If you're not sure which is yours, or you don't see any wireless networks)
Asked to enter a security key?
  • If you are prompted to "Enter the Password or Key," then the wireless network you are trying to connect to has wireless security turned on. You will need to type in your security key or password and select "OK."
  • If you need to switch between upper and lower-case letters, or numbers and symbols, select the "Shift" key on the on-screen keyboard.
  • Ensure you review the security type in the top-left corner as well. If this is not the same security type that is used by your router, select "Change Security Settings" and select the appropriate security type.
9.Select "OK" 3 times to save your settings and start an Internet connection test.
  • The Wii console will run a connection test with your wireless network.
  • When the test is completed, you should see the following screen:
  • If the connection test succeeds, then your Wii is now connected to the internet.
  • The connection test was not successful, you will receive an error code.
    • Error Code 51330 or 52130: This means the security code you entered into the Wii is not the same one your router is set to. Look in your router's settings and try again. Please refer to step eight (8) above for more information.
Don't know your routers security key?
Here's some:- A..To login into your Linksys router:
  1. go on this link: http://192.168.1.1
  2. The default username is: (leave blank)
  3. The default password is: admin
  4. Look for the security key settings. For Linksys routers, they are usually in "Wireless Security" on the "Wireless" tab or something similar.
  5. Find the selected WEP or WPA key, and write it down. Enter this number into the Wii or Nintendo DS when prompted.
B. To login into your Netgear router:
  1. Go on this link: http://192.168.0.1
  2. The default username is: admin
  3. The default password is: password
  4. Look for the security key settings. For Netgear routers, they are usually in "Wireless Settings" on the "Setup" tab or something similar.
.C.To login into your DLink router:
  3. The default password is: (leave blank)
  4. Look for the security key settings. For DLink routers, they are usually in "Wireless" on the "Home" tab or something similar.
Aug 18, 2017 | Internet Computers & Internet
How do I connect to the internet
What to Do:
  1. Power on your Wii console and press the A Button on the Wii Remote to reach the Wii main menu. Use the Wii Remote to select the "Wii" button.wiimenu.gif
  2. Select "Wii Settings" to access the "Wii System Settings" menu. wiisettingsmenu.gif
  3. Using the arrow on the right side of the screen, scroll to page two and select "Internet." wii_settings_arrow.png
  4. Select "Connection Settings."
  5. Select "Connection 1: None."
    • If you do not have an empty connection slot, you will need to clear a slot. How to wiisettingsinternet3.gif
  6. Click on "Wireless Connection," then click "Search for an Access Point."
    • If using a wired Internet connection, click here for specific help. wiisettingsinternet4.png
  7. Select "OK." The Wii will display all the wireless networks it finds. sfap2.gif
  8. Select the wireless network that is yours. (If you're not sure which is yours, or you don't see any wireless networks, click here.)
    Don't know your router's security key?
    Let us help you find your router's security key. Select the brand of your router below and we'll provide you with the default information for that brand!
  9. Select "OK," "Save Settings," and then "Yes."
    • The Wii console will run a connection test with your wireless network. When the test is completed, you should see the following screen:sfapun2.gif
      As long as you see "The connection test was successful," the "Wii Support Code" does not matter and can be ignored.
Nov 09, 2014 | Nintendo Wii Video Game Consoles & Games
Undefined
From the Wii main menu, use the Wii Remote to select the "Wii" button.
Now, select "Wii Settings" to access the "Wii System Settings" menu.
Select "Connection 1: None"
(Don't see "None" in Connection 1? Click the Connection 1 button, then choose "Clear Settings.")
Click on "Wireless Connection" and then "Search for an Access Point."
Select "OK" and the Wii will display all the wireless networks it finds.
  1. Select "OK," "Save Settings," and then "Yes."
  • As long as you see "The connection test was successful," the "Wii Support Code" does not matter and can be ignored.
  • The connection test was successful - Then you're almost done! After your connection test, the Wii console will check if there is a new Wii System Update available. Once you select "Yes" and "I Accept," the Wii will begin to download any available updates.
  • The connection test was not successful - If the test was not successful, you will receive an error code.
    • Error Code 51330: This means the security code you entered into the Wii is not the same one your router is set to. Look in your router's settings and try again.
For detailed step by step instructions with pictures use this link: http://www.nintendo.com/consumer/systems/wii/en_na/netflix.jsp?menu=watch&submenu=rvl-ht-sys-internet-connect
Apr 23, 2013 | Nintendo Wii Video Game Consoles & Games
I cant get my wi to connect to the internet
Power on your Wii console and press the A Button on the Wii Remote to reach the Wii main menu. Use the Wii Remote to select the "Wii" button. Now, select "Wii Settings" to access the "Wii System Settings" menu.Using the arrow on the right side of the screen, scroll to page two and select "Internet." Select "Connection 1: None"(Don't see "None" in Connection 1? Click the Connection 1 button, then choose "Clear Settings.") Click on "Wireless Connection" and then "Search for an Access Point."(Are you using a wired Internet connection to your Wii console Select "OK" and the Wii will display all the wireless networks it finds.Select the wireless network that is yours. (If you're not sure which is yours, or you don't see any wireless networks, Asked to enter a security key? If you are prompted to "Enter the Password or Key," then the wireless network you are trying to connect to has wireless security turned on. You will need to type in your security key or password and select "OK."Select "OK," "Save Settings," and then "Yes."
The Wii console will run a connection test with your wireless network when the test is completed. You should see the following screen:OR Go to this link http://www.nintendo.com/consumer/systems/wii/en_na/getOnline/index.jsp
Aug 15, 2011 | Nintendo Wii Console
I need help setting up internet connection
Let's get you connected!
Aug 14, 2011 | Nintendo Wii Console
Error code 51331. unable to connect to internet. choose internet settings and then cofirm your connection.
(Are you using a wired Internet connection to your Wii console? If so, click here for specific help.)
Linksys Netgear DLink
Belkin Apple 2Wire
All other brands
The connection test was successful - Then you're almost done! After your connection test, the Wii console will check if there is a new Wii System Update available. Once you select "Yes" and "I Accept," the Wii will begin to download any available updates. Click here to find out what's next!
Error Code 51330 or 52130: This means the security code you entered into the Wii is not the same one your router is set to. Look in your router's settings and try again. Please refer to step seven (7) above for more information.
All other error codes: Try our error code troubleshooting where we have detailed information on many common error codes. (You can ignore any "Wii Support Code" you receive on a connection test.)
Jun 28, 2011 | Video Game Consoles & Games
Trying to connect my WII council to the internet and it keeps coming up "Unable to connect to the internet Error code: 50230"
Error code 50230 is thrown when the Wii's internet connection has not yet been configured. These instructions on configuring the connection settings come from Nintendo's website at:
  2. Now, select "Wii Settings" to access the "Wii System Settings" menu.
  4. Select "Connection 1: None"
  5. Click on "Wireless Connection" and then "Search for an Access Point."
  6. Select "OK" and the Wii will display all the wireless networks it finds.
  7. Select the wireless network that is yours.
  8. Asked to enter a security key? If you are prompted to "Enter the Password or Key," then the wireless network you are trying to connect to has wireless security turned on. You will need to type in your security key or password and select "OK." secureaccess.png Don't know your router's security key? Let us help you find your router's security key. Select the brand of your router below and we'll provide you with the default information for that brand! Linksys Netgear DLink Belkin Apple 2Wire All other brands
    • The Wii console will run a connection test with your wireless network when the test is completed. You should see the following screen:
    • The connection test was successful - Then you're almost done! After your connection test, the Wii console will check if there is a new Wii System Update available. Once you select "Yes" and "I Accept," the Wii will begin to download any available updates. Click here to find out what's next!
      • Error Code 51330 or 52130: This means the security code you entered into the Wii is not the same one your router is set to. Look in your router's settings and try again. Please refer to step seven (7) above for more information.
      • All other error codes: Try our error code troubleshooting where we have detailed information on many common error codes. (You can ignore any "Wii Support Code" you receive on a connection test.)
May 07, 2011 | Nintendo Wii Console
Cannot conneted to internet
    Belkin Apple 2Wire
    All other brands
Mar 01, 2011 | Nintendo Wii Console
52030 error message when trying to hook to the internet
Jan 23, 2011 | Nintendo Wii Console
My wii finds my wireless connection. but it is asking for a password or key to be entered, cuz my access piont is sucure. what can i do
You cannot connect to wireless internet due to wep key password because it is secured that requires password. try to connect to your home internet or unsecured connection
Nov 24, 2010 | Nintendo Wii Console
NetGear WGR614 Wireless Router Logo
141 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
