Question about Panasonic KVS1025C SCANNER W INFONIC MGR BUS ED 5U LIC KVS1025C Barcode Scanner
I have KV-S 1025C .When I click scan,message comes Paper jam or Double feed.There is no such problem..no jam no double feed..Please help
    President:
  • 3,278 Answers
Hello.
Since you appear to be not experiencing a hardware problem, then a software problem is occurring.
Here's a link to download the latest driver (software) for your device:
http://panasonic.net/pcc/support/scanner/eula_pnul.html?http://cs-im.psn-web.net/Japan/Scanner/cojp/data_cmns/devdrv/panascan550.exe
Scroll to the bottom of the screen and select "I agree". Save the file first.
Go to Printers (or Printers and Faxes) and remove your device.
Then, Run the file that you downloaded..
Hope this resolves your problem.
Posted on Mar 13, 2011
Double printing on pixma mp470
Double printing or double feed??. Double printing means document printed in 2 copies. Double feed means printer feed double paper in one moment. For double printing,please check number of copy of document in printing preference properties.
Double feed occurs when pickup roller fails to pick the paper correctly. It's usually caused by shaft of paper pick up roller which is broken. You should replace drive assembly (include pick up roller) in this case
May 13, 2010 | Canon PIXMA MP470 All-in-One Printer
Double sided copying
http://www.brother-usa.com/ModelDocuments/Consumer/Software%20Users%20Manual/SUM_DCP_7030_7040_MFC_7340_7345N_7440N_7840W_EN_1650.PDF
here is the manual p4 and p16 discuss the topic:
Duplex printing 1
The supplied printer driver supports duplex printing.
Guidelines for printing on both sides of the paper 1
�� If the paper is thin, it may wrinkle.
�� If paper is curled, turn over the stack, straighten it and then put it back in the paper tray or the Manual Feed
Slot.
�� If the paper is not feeding properly, it may be curled. Remove the paper, straighten it and turn over the
stack.
�� When you use the manual duplex function, it is possible that there may be paper jams or poor print quality.
If there is a paper jam, see Paper jams in the User’s Guide. If you have a print quality problem, see
Improving the print quality in the User’s Guide.
Manual duplex printing 1
The machine prints all the even-numbered pages on one side of the paper first. Then, the Windows® driver
instructs you (with a pop-up message) to reinsert the paper. Before reinserting the paper, straighten it well,
or you may get a paper jam. Very thin or thick paper is not recommended.
Simultaneous scanning, printing and faxing 1
Your machine can print from your computer while sending or receiving a fax in memory, or while scanning a
document into the computer. Fax sending will not be stopped during PC printing. However, when the machine
is copying or receiving a fax on paper, it pauses the PC printing operation, and then continues printing when
copying or fax receiving has finished.
�� Manual Duplex
Check Manual Duplex. In this mode, the machine prints all the even numbered pages first. Then the
printer driver stops and shows the instructions required to re-install the paper. When you click OK the odd
numbered pages are printed. There are six types of manual duplex binding directions available for each
orientation.
�� Booklet Printing
When you want to print a booklet, use this function. To make the booklet, fold the printed pages down the
middle.
�� Binding Offset
If you check the Binding Offset option, you can also specify the offset for binding in inches or millimeters
May 14, 2009 | Brother MFC-7440N Laser Printer
Not printing double sided
check the driver
does not print from bypass tray (manual feed)
does not print on thick paper (check paper type)
Apr 01, 2009 | Ricoh Aficio SP C410DN Laser Printer
The scanner wont scan, everytime i add papers it will act like its about to scan but then says there is a jam.
These scanners have multiple sensors, that can check if there is a double feed or paper jam. May be one of them is faulty or a small piece of paper is stuck there. Remove/clean this and the scanner will be fine.
S. Mohan, Chennai, India
Jan 02, 2009 | Panasonic KV-S2046C Pass-Through Scanner
Resetting PaperPort after paper jam
I found the solution to this problem. Whenever the paper jammed in the feed tray, I was pulling the jammed paper out without opening the door of the feed tray. Apparently, PaperPort gets confused and does not know how to proceed. Now when I get a paper jam, I open the door of the feed tray, take out the paper, click on the paper jam error message in PaperPort, reset the paper in the feed tray, and then hit "scan." Works like a charm.
Sep 30, 2008 | Xerox DOCUMATE 510 Flatbed Scanner
Double feed detection
though it has a flexible papr handling capabilities you might want to consider the ff:
Stacker Capacity: 100 Sheets Document Feed: Automatic or Manual Document Size: Width: 2.2" - 10.1"
Length: 2.8" - 14.3" Thickness: Automatic: 0.06 - 0.15mm
Manual: 0.06mm - 0.20mm Feed Capacity: 100 Sheets
all scanner are equipped with double feed prevention, however it still the user responsibility to ensure that you follow manufacturer's advice, to prevent double feeding:
1- do not feed dog eared paper
2- moistured paper or with strong humid
3- concave paper
4- convex paper
cheers!
Aug 28, 2008 | Canon DR-3080CII Path-Through Flatbed...
Paper Jam
Hello vidalia
(01) You can find support and downloads for your Canon Pixma MP780 AIO (all-in-one) HERE.
(02) You can find Canon's support and services for this device HERE.
(03) You can find drivers and manuals for it HERE.
(Select your computer's operating system under Drivers/Software selection and the appropriate downloads will appear)
(04) For instructions on clearing a paper jam, download the USER'S GUIDE (it might take a little bit. It's pretty extensive).
(05) Then double-click on the file name: (depending upon the operating system you selected, it will be something like: PIXMA_MP780_750_UG_WIN_EN.EXE)
The file will extract to a folder (in the same location w/ the same name as the file)
(06) Double-click on the folder.
(07) Double click on the file named "TOP" or "TOP.htm"
This will open the USER'S GUIDE for you.
(08) Now, in the left column, click on TROUBLESHOOTING
(09) Then click on the link immediately below TROUBLESHOOTING called "Paper is Jammed"
(10) Follow the instructions provided for clearing a paper jam.
Please, let us know if you have any questions at all, etc. We'll continue to work w/ you on this problem until it is resolved.
Thank you
BJ @:)
If the information I provided enabled you to resolve your problem, kindly take a moment to rate my solution w/ a "FixYa" :)
Apr 16, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Frequent Paper Jams
The only suggestion I could make may be obvious but my experience has taught me that you need to make sure the paper is installed correctly, especially with double ply paper. We have learned that the yellow receipt copy ply must be attached properly to the green roller so that the double ply paper from the roll feeds correctly through the print roller. Also make sure the double ply roll paper is not loose coming off the roll that feeds to the print roller.
Nov 20, 2006 | Ithaca (93+PRJ11) Matrix Printer
Panasonic KVS1025C SCANNER W INFONIC MGR BUS ED 5U LIC KVS1025C Barcode Scanner Logo
97 people viewed this question
Top Panasonic Computers & Internet Experts
micky dee
Computer Repairing
Computer Repairing
Are you a Panasonic Computer and Internet Expert? Answer questions, earn points and help others
