Question about RCA HD52W59 HDTV Projection Television
Can you tell me where to find the remote sensor on the television? We just got it, used, and took the screen off and cleaned bulbs and all and it was all real dusty, Can't get remotes to work, so figured maybe the sensor is dusty also. Please advise.
    Scholar:
  • 155 Answers
A dusty sensor should still let the control work, I suspect that the remote control has an issue.
If you already replaced the batteries open it and see if the infrared LED is still well attached to the board, often by dropping the control it get detached.
Best regards
Posted on Mar 13, 2011
LG tv remote control not working
change crystal on the remote.........to check if remote is ok use ur camera mobile......how--
1. switch on your mobile phone camera.
2. Set mobile so that you see the bulb(LED) of remote on your mobile screen thru mobile camera
3. Now press any button on remote (ensure batteries are installed in remote)
4. If u see a purple light comming out of the remote bulb(LED) then remote is ok......change remote sensor ( also called eye) of your TV
Mar 28, 2013 | LG Televison & Video
Toshiba rear projection needs cleaned
I take it that this is aDLP seening you said bulb this bulb is a halegen so us gloves. There is the lens coming from the colour wheel did you clean it.Clean only with hot water and soft towel no chemicals.If you have used a chemical on it use soft towel to polish.
Dec 24, 2012 | Toshiba Televison & Video
Changed bulb, but cannot get blue" change bulb and reset hour meter "banner off tv
You need to use the remote control that cam e with the TV and press the PIP/SWAP button on the remote and the VOLUME down on the front of the TV simultaneously for more than 10 seconds. Once successful the on screen display will tell you the lamp timer is reset to 0.
Sep 08, 2010 | Panasonic PT-50LC14 50" Rear Projection...
My verizon fios remote control stop to control the 65" cinema series toshiba tv.the remote seems to be ok.The oryginal tv remote doesnt control it also.I think that there is something wron with the tv...
Yes, most likely the sensor is at fault - more precisely it's connections to the motherboard are iffy. You must take the back cover off the tv and reseat them. While you are there check their soldering points - with age they tend to melt and get loose.
Jul 28, 2010 | Televison & Video
I've already replaced the bulb on my Panasonic television model number PT52LCX66, but I can not get the message of the screen that tells me to reset the hour meter lamp. How do I reset the the hour meter...
Turn off tv. Hold vol- on tv and tv/video button on remote same time for 5 seconds. Select lamp time use vol- on remote to reset to zero. turn off tv to remove serv menu.
Nov 24, 2009 | Televison & Video
Remote will not turn off TV The Charter Cable technicain thought the problem was the LED What do I do?
LED? or the IR sensor?
LED is a light bulb in short terms or a light emitting diode witch has nothing to do with your set all togeather.
First clean off the senor with a dap of alchol, try changing the battery if your using a cable box remote call charter for the correct remote codes for your TV.
I think your technition may have been under the influence or just not educated to tell you the remote codes or just did not want to set this up for you!
Ether way do as i suggested call them and ask them for the remote code booklet if your using the remote control from the cable box to control your tv. You be glad you did.
please leave postive feedback and ratings for your free soltuons today.
Nov 16, 2009 | LG 42LG50 42 in. LCD HDTV
Panasonic dlp new bulb clean filter error message reset info not
For the Air Filter message, the filters are located inside the unit, if already cleaned, perform a reset of the unit, Press Hold, VOL - on set and TV/Video on remote for about 5 sec. If a Lamp timer reset message, try VOL - on the set and Mute, Move or PIP on the remote (try all three)
Mar 29, 2009 | Panasonic PT-50LC13 50" Rear Projection...
TV does not respond to Remote
follow wire from sensor inside tv to tuner board and resolder.
Apr 04, 2008 | Zenith E44W46LCD 44" Rear Projection...
Purple blotches
Ok, so I'm about to flip a lid with my TV. I am showing purple quater sized blotches all over my screen. I bought it for a discounted price because of this issue, in hopes i could fix it. I took the back panel off the TV. ( about a 6in * 6 in plate) removed the light bulb and cleaned the bulb and lens, where the light bulb faced. I used a dust cleaner and special cloth. NOTHING! I took the entire front screen off cleaned it and then cleaned the mirror and second lens.... NOTHING! Then i heard that dusk sometimes gathers behind the lens and that should be cleaned. Try this, Its 4 screws, just be careful and remember the way you took it out, because it has to be replaced the same way.
Lindsey <3 AZ
Nov 28, 2007 | Epson Livingstation LS57P2 57" Rear...
RCA HD52W59 HDTV Projection Television Logo
42 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
