Question about Home
Dripping facet - Home
    Novelist:
  • 144 Answers
If a faucet is leaking the necessary repair will be either:
1. For a ceramic or washerless faucet, replace the cartridge.
2. For a typical old fashioned faucet, open the faucet, replace the washer (and packing if it has any) and verify that the faucet seat has not eroded.
The newer washerless faucets cannot be repaired except by replacing the cartridge. Cartridges for most common faucets are available at most home improvement stores or plumbing supply houses.
It sounds a lot more difficult than it really is, just shut off the water (usually a shut off valve under the sink). After the water is off, remove the handle and any chrome protective covering. Depending on the faucet type, it may be a little difficult to remove the cartridge since they are often covered with mineral build-up or corroded into place.
Once you remove the old cartridge the new one usually goes into place easily.
NOTE!!!
For single handle faucets, make sure you put it in the right way, some of them will put the hot to the wrong side if you put them together backward.
Posted on Mar 13, 2011
  • cperrodou Mar 13, 2011
    Thank you, have washerless, will try replacing cartidge.
How do I fix a dipping CA8440 Facet. Both Hot and Cold Dip?? What makes it drip?
Replace the valve body if it is a single valve design. Replace both hot and cold valve bodies if it has separate handles. They are not expensive if you hava a faucet worth fixing. If they are not available, either your faucet is too old or not worth fixing. When in doubt, call a plumber.
Feb 23, 2015 | Plumbing
Moen 7700 kitchen facet started dripping...help?
Dismantel the entire faucet and clean. Probably grime or dirth buildup if it has a rotating shutoff
Jan 25, 2015 | Moen Plumbing
Delta 18 series tub facet leaks
the possible cartridges you can replace are listed on this pdf
http://www.deltafaucet.com/media/SpecSheet/DSP-B-R18000_Rev_A.pdf
Jan 13, 2013 | Delta Innovations 18 Series Monitor...
Blanco alt drips
The drip may be caused by poor design. The aerator may have been installed incorrectly by the plumber.
Sep 25, 2017 | Blanco Classic Single Handle Faucet with...
My single handle bathroom facet works in middle and cold position ,but when placed into the hot water side water just drips. How can I fix that?
It appears some scale from the water heater has the valve obstructed. Going to need disassembly to clear it.
Nov 01, 2009 | Plumbing
Losing hot water in one facet only
There is something in the line or in the faucet.Are your pipes going to the faucet black iron or galvinze.Some of the pipe will rust up and stop a full flow of water.But I would check the faucet first to see if the screw is loose or somethng in it.
Mar 17, 2009 | Rheem 50 Gallon FVR NATGAS Water Heater...
Kitchen facet has been losing water pressure.
Faucets are normally fitted with an aerator that screws on. These can get clogged with minerals from hard water and cause the problem you're having. Try unscrewing the aerator and removing it. It may be pretty tight, but it will come off. Slip-joint pliers with the jaws wrapped with vinyl tape to prevent scratching the chrome can help.
Once the aerator's off you'll probably find the water works properly. It might be possible to clean out the aerator, but the best solution is to get a replacement at a hardware store or big-box home improvement store. They're only a couple of dollars and a new one will be more reliable.
Please take a moment to rate this solution, and thanks for asking here!
Mar 01, 2009 | Price Pfister Plumbing
Home Logo
729 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
