The captiva camper furnace ignites but will not stay burning
  • 1,420 Answers
Plugged vent, bad flame rod, bad thermostat.
Posted on Mar 13, 2011
Chev captiva 2015 wiring diagram as vehicle has burnt out wiring
geee
2015 ....to new for a burn out thats bad luck
Chevrolet Captiva Wiring Diagram
hardwick.io/doc/chevrolet-captiva-wiring-diagram.pdf
if not an insurance claim
best solution for a burn out fix like that is
source a full car loom from a wrecker
and fitting that in
Nov 04, 2016 | Cars & Trucks
I have a 2006 jag camper 29' and my furnace won't ignite
When you hear the "click" can you observe the pilot assembly to see if any sparking or a hot surface igniter is glowing, it is likely a spark type, if so and you have 24 volts to the gas valve I would suspect a spider or web has obstructed the pilot orifice, this is very common to find after sitting unused, if no spark I would suspect the ignition module, you can try using a flame and aim fireplace lighter to see if the pilot assembly is putting any gas out, but be careful and keep well ventilated as propane is heavier than natural gas and will settle on the floor.
Jan 09, 2015 | Heating & Cooling
Atwood 38591 Excalibur xt 1522 LP two stage furnace. Operates on high fan only
Hi Dave. I'm Roger. Its normal for a furnace to shut down completely when the set point on the thermostat is reached. The first and second stages are used when the temp. gets close to set point. The heat output drops to its low stage at around 3 degrees before set point. Check your owners manual for specifics on the fan though.
Mar 14, 2014 | Atwood 38591 Excalibur XT Furnace 1522 15K...
Atwood 1522 LP furnace fan operates at one speed only
Furnace only works at one speed, high and low fan is usually used for AC. It never has had 2 speeds on furnace correct? Furnaces usually only have 1 speed, except for some home models.
Furnace will come one once in a while not regulary
how lonv does.it stay off and check the board for flashing lights count them then look on the back of the door for flash code it should tell you whats wrong if you still can't fix it post the info
Nov 27, 2013 | Dometic 3109226.005 Electronic Control Kit...
Goodman furnace gmh95090cxac wont stay lit keeps clicking will lite then clicks back off what would be the problem
Hello, if the burners light but do not stay on for more than 10 seconds, I would clean the flame sensor. The flame sensor is a metal rod that is on the opposite side of the Igniter, sometimes it gets coated by oxidation and does not sense the burner flame and shuts the Furnace down. To clean to kill power to tje furnace, remove flame sensor and clean with a steel wool, then reinstall and start Furnce back up. If this does not work then most likely the Igniter is too weak to ignite the gas and will have ro be replaced.
Oct 29, 2012 | Heating & Cooling
Where is the ignitor for the furnace in a 1998 flagstaff popup camper
This is the car and truck section. You may want to repost this in the RV section, or contact the company that built the camper.
Sep 26, 2012 | Cars & Trucks
Our furnace igniter burned out repairman replaced igniter which burned out the second that furnace was turned on. this happened twice. he does not know why.
If you are not talking about a computer game, but about your furnace-I would suggest that you check that the exhaust of your furnace is not too close to your intake pipe. This could cause a problem, possibly what you are experiencing.
Dec 19, 2010 | Got Game RHEM for Windows, Mac, Mac and PC
The furnace will light up and the fan will blow but the flames cut out before my house reaches temp. i have the thermostat set at 70 and the house will not get above 55. i have tried turning the propane...
First, for those of you who might not know, "What is a flame sensor?" A flame sensor is a safety device. When your furnace's main burners ignite (light Up) the flame sensor picks up the heat from the furnace's main burning and says, "YES," and sends a signal back to the main furnace control board saying that it is OK to let the main burner stay on. Or if the main burners do not ignite, the flame sensor does not pick up the heat and says, "NO" to the main control board, Shut That Gas Valve and Main Burners Down! Thank God we have safety controls like the flame sensor. Most of the time, after turning your furnace's power off, you may clean the flame sensors with light sand cloth, emery cloth or steel wool. Reinstall the flame sensor and you are back in business! Over the years flame sensors can build up a light coating of burned-in dust and dirt. This insulates the flame sensor so that it doesn't sense the heat of the flame well enough, so by cleaning it you have almost restored it to its new condition. Seldom, but sometimes they do go out completely.
Dec 08, 2010 | Coleman Heating & Cooling
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
