Question about Microsoft Computers & Internet
Had a motherborad meltdown-had all documents transferred to another tower. chart done in black-came back all in red-cant get it to change to black-tried to print it -new text (which did comeout black0) not on document!!
  • Kasper Jensen
    Kasper Jensen Mar 13, 2011
    try asking the question in other words, please?
  • 442 Answers
Please check if the chart was done with Microsoft 2007 or 2011 and then transferred to a computer that does not have the same version. If this is the case, install the same Microsoft office version and try opening the same file / even try printing it.
Posted on Mar 13, 2011
PROCESS IN HOW TO CALIBRATE C253
utility /counter, details, stop 00 stop 01,(SERVICE MODE) Image processing adjustment select all colors run twice ensure the image units are toned up for the gradation adj. Now run stabilization once. Now you will run the following three times (Gradation, Resolution, and compression). each. you will press start machine will run and print out a chart place the chart on the big glass do not use the document feeder use your best paper no color paper!!!!! ensure the black square are up against the scale on the left side you can use 11 x 17 or 8.5 x 11 paper 11 x 17 will give extra color strip not used 8.5 x 11 must be landscape. press start. In the end you should have 12 print outs 3 from each process.
Gradation, Resolution, and compression. once done print out a demo page in user mode check it out.
Feb 23, 2013 | Konica Minolta Bizhub C253 With Document...
Vtech sit to stand dancing tower stopped working
Not a solution but ours has done the same. Annoying!
Jan 03, 2013 | Vtech V Tech Sit To Stand Dancing Tower
Transferred Print Shop to a new computer. Copied the files from My Documents. My wife uses it and she says none of the My Arts & Pictures are there. How can I copy them from my laptop to our new...
Hi jeffhale137
You can copy the files on a cdrom or a flashstick , unless your machines are connected in a network making it easy to transfer documents instantly from one machine to another .
The program itself needs to be previously installed on the new Tower , making first sure it's version is compatible with the existing OS .
Best regards ,
fanaudi .
May 18, 2011 | Broderbund The Print Shop 21 Deluxe Full...
Had to change tower looking for the layout to connect the front usb wiring to the board , need to know which wires go on the board
motherboard usually red-white-green-black
Standard USB Cable Wiring Color Code
5V / Red
D+ / Green
D - / White
Ground / Black
hope this helps
Mar 31, 2011 | Intel Motherboard
Black line across the top of every print on bh c250
Hi first do a cmyk test chart of each color if it happens when you do black copies then check the black imaging unit as it is not being cleaned and will give you black lines replace black drum unit
if it is on color copies black copies then the other thing to look at is the transfer belt unit and you may need to change the transfer belt
do the CMYK and you should get each color fully covered on each page see if there is any lines on the sheets in the same area you are getting the lines if so replace that color drum
Feb 12, 2011 | Minolta C250 Color Copier
2003 Impala: HOW DO I CHANGE BATTERY 2005 CHEVROLET IMPALA...
The battery is under the hood, just behind the passenger headlight.
There is a black bar that crosses over the battery and goes back towards strut tower. Remove this bar and the three bolts; probably a 12 or 13mm socket.
Remove the negative (black) battery cable with an 8mm socket or wrench. A 5/16" should work also.
Then remove the positive (red) cable with same socket.
Remove the battery clamp and bolt. Probably a 12mm socket with extension.
It's tight, but the battery can be removed.
Reverse instructions for installing the battery. (That includes hooking up the red battery cable first, then the black cable.)
May 16, 2010 | 2003 Chevrolet Impala
My hp 1610 only prints letters in red. Downloaded
I suspect this is happening because your "Font" is set to Red. What you need to do, is when in the document, go to the Tool Bar and find & select the "Font" and change the color to Black. It is usually a little "Box" at the side of the name & size of the Font, you click in here and another little popup will appear showing colors, simply click on the Black color, and it is done, set.
Feb 24, 2010 | HP PSC 1610 All-In-One InkJet Printer
Color chart in Word 2007 prints as a black box
have you tried saving the document as a 2007-document, and printing it out after that?
Feb 07, 2008 | Microsoft Office Professional 2007 Full...
Memory Stick
dcp 130c cant transfer plain data. Its a pic bridge (digital camera standard) connection only.
You have to use your PC USB.
Jan 10, 2008 | Brother DCP 130C All-In-One InkJet Printer
Computers & Internet Logo
117 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
