Question about Char-Broil CharBroil 4637318 Grill
Where do you hook the sideburner ingintor wire to?
    Brigadier General:
  • 4,736 Answers
You connect the wire to the pin on the bottom of the peizo ingnitor (it looks like a 3/4"' needle) . The sleeve on the end of the wire should just slide onto the pin. Make sure you push it on snugly. You'll find it underneath the side burner.
Hope this helps to get you up and grilling. Please let me know. Thanks.
Posted on Mar 13, 2011
Where do you hook up the sideburner ignitor wire to on the char-coil bbq model 463721111
The side burner ignitor wire connects to the spare lug on the main ignitior module. That one module, controls all the spark ignitors at each main burner and the side burner. When you press the button all ignitors spark at one time. I know it sounds stupid, but that's the way Charbroil's R & D designed it. I guess it saves money.
Hope this helped you to make the final hookup. Happy Grilling!!
May 01, 2011 | Char-Broil CharBroil 4637318 Grill
My coleman gas furnace wont ignite. i replaced the ingintor but i think a wire has crossed and i am not sure which wire. i purchased my furnace and it didnt come with an owners manual
If you have the model number, go to the Coleman Heating and Cooling website and using the model number, you can search for and download the Owners Manual.
Mar 11, 2011 | Coleman Heating & Cooling
I need to locate a ignitor in my coleman gas furnance model 2865e766
Depending on the typ of burner it has, it should be located on the bottem in front of the burner rail, or to the side any way it will be int he burner rail, more than likey a hot surface ingintor.
Dec 30, 2010 | Coleman Heating & Cooling
Sideburn cutter part needs to be put back on. It became loose and now has fallen out. I could fix this myself if I knew how to open shaver.
if the sideburn cutter has come off, it is because it is broken. You will need to replace it. You will find the item at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/braun-activator-body-housing-with-trimmer-select-models-p-829.html
For instructional video on disassembling the shaver, also see shaveroutlet.com tutorial here:
http://shaveroutlet.com/video_tutorials
Oct 08, 2010 | Braun 8585 Electric Shaver
How to remove rechargeable battery for norelco 7864
hi minglim, welocme to the forum!
    Replacing a Norelco Shaver Battery Things You'll Need:Torx screwdriver set Rechargeable Ni-Cd AA battery 1)Slide up the sideburns trimmer on the shaver .2)Try the various torx head screwdriver sizes to find the fit for the two screws holding the top of the back shaver cover on. Unscrew the two screws that are under the sideburns trimmer that hold the back of the shaver on. On some Norelco shavers, the back will now slide off if you apply downward pressure on the shaver's back. Other Norelco shavers have one or two torx screws on the base of the back cover on the shaver; if so, unscrew them also. Place the screws in a safe place. 3)Take the back cover off the shaver. Some shavers may have a strap fastening the battery down. Unfasten the strap if there is one. Take out the battery. 4)Replace the old battery with a new rechargeable Ni-Cd AA battery. Re-fasten the battery holding strap if there was one. 5)Replace the back shaver cover and re-screw in all the torx screws,
May 20, 2010 | Norelco 7800XLCC Electric Shaver
Having problems lighting baby q grill. have followed all the procedures. I am on my second regulator. i believe I believe that I have inferior regulators.
If you are getting a strong gas flow when you turn on the valves, then it may not be the regulator. If you are using the ingintor to try and light the grill, it could be a bad ingnitor, a bad or loose wire going to the electrode, or the gap between the electrode and the metal maybe to large to create a spark. If you can light it with a match or a manual butane lighter, then it is probably not the regulator.
Jan 10, 2010 | Weber Q Grill
Sideburner for Thermos Stainless Steel Gas Grill (Mod # 461262006)
It sounds like the orifice is bad. An orifice is a small metal part that has a small hole in it. This regulates the gas coming out to the burner. It is at the tip of the pipe that brings gas to the burners, before the flame. I don't know what the hell the garggley noise is. Unless the bottle is upside down, and you are getting liquid, I don't know.
Mar 02, 2008 | Thermos Stainless Steel Gas Grill
Char-Broil CharBroil 4637318 Grill Logo
214 people viewed this question
Top Char-Broil Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dean Gruber
Are you a Char-Broil Grilling Expert? Answer questions, earn points and help others
