Question about HP Computers & Internet
The screen is yellow sometimes it will go back to normal but only for a few seonds what would cause this?
    President:
  • 1,623 Answers
It is likely that it is the cable connecting the computer to the monitor, if it can be undone at the monitor side then you are in luck and can replace the cable, to test if it is the cable give it a twist and bend to see if the screen colour changes, if it does then the cables at fault
Posted on Mar 13, 2011
  • 55 Answers
Usually that's due to a VGA cable issue, not making good contact with the plug.
Try plugging the VGA cable fully in on both ends, Monitor and PC. If that didn't help solve the problem, try inspecting the pins of the cable for any bent ones (might be bent from trying to force the plug the wrong way). You could easily straighten bent pins by carefully using a small screwdriver.
Hope that helps!
    Sniper:
  • 69 Answers
Hi
Properly due to a bad connection to the monitor, theck the cables, or try another cable.
I have a 5 year old pdp-5050sx Pioneer TV, it has a yellow on the screen that goes from the bottom of the screen to the middle of the screen and it is a few inches wide. the yellow bar is also few inches...
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Check the CCFL lamps too, for low light emission, if the backlight of the TV is of CCFL type.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Aug 21, 2017 | Pioneer Televison & Video
My screen went out and im trying to find out what the problem is my sound still works and the tv cuts off after a few seonds of being on?? whats could this b?
Either your backlight circuit or image processor is shorted/fried, which would cause too much power across the circuits, causing it to shut off as a safety precaution.
Jun 03, 2010 | Toshiba Regza 32LV67U 32 in. LCD HDTV
Screen got yellowish color
Sounds like overstressed video cable, at least that wire for BLUE signal, 'cause when image is yellow - the BLUE color is missing.
Open the monitor and ring coaxial wire in blue insulation.
Sep 11, 2009 | AOC CT720G 17" CRT Monitor
Samsung Tantus Picture Problem. Green Yellow Black Hue
it seems that your unit got loosed contact.i mean it needs resoldering.call a technician to do further troubleshooting.
May 11, 2009 | Televison & Video
Yellow Screen
Furst, check the video signal cable, if you can, try a replacement. Try removing and then refitting the original, sometimes this clesans the connections
Dec 26, 2008 | LG Flatron F700B 17" CRT Monitor
My monitor turns yellow
Computer monitors get separate red, green and blue video signals from the computer, and if you lose the blue the result is a yellow picture. This can be caused by video card failure in the computer (very unlikely), a bad cable (fairly common), or trouble in the monitor (which is most likely what you have).
The usual problem with monitors is bad solder connections to the red, green and blue output devices. These are usually three separate transistors, but sometimes an integrated circuit that puts all three in one package is used. These outputs get pretty hot, and the heat can cause the connections on the circuit board to crack. Resoldering them usually fixes the trouble. (Sometimes the part actually fails, but bad connections are more common.)
The parts are normally in one of two places. Most commonly they are on the small circuit board you'll find right at the neck of the picture tube. Some monitors have them on the main circuit board. They may be mounted to metal heat sinks to help keep them cool. If you can identify them and resolder the connections, you'll probably get your normal picture back.
Sep 22, 2008 | HP mx705 17" CRT Monitor
Color problem MAG Innovision 14" monitor
1. try to connect to another computer . if it is fairly good then it must be your computer is having a problem.may be your video card problem.
Mar 21, 2008 | Mag Innovision lt456s 14" Flat Panel LCD...
I have a new Canon SD850IS and only used it for a week. Sometimes it powers on normally, and sometimes it doesn't displaying E10 on screen for a few seconds. Have not dropped or otherwise caused damage....
A new camera should not be doing that. Take it back or return it for an exchange. Make sure you let the retailer know what the issue is so they don't restock that particular camera.
Feb 18, 2008 | Canon PowerShot SD850 IS Digital Camera
Screen patch
Sometimes lcds will turn a yellow/brown/redish colour if they overheat. normally this will not cause long term damage to the screen but it is not good for it, try letting the monitor cool then using commpressed air to get rid of dust or attach a small fan to see if it helps. This may not fix the problem but should confirm if thats what it is.
Oct 30, 2006 | Samsung 997DF 19" CRT Monitor
Computers & Internet Logo
20 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
