Question about Acard Technology (ARS-2030LD) DVD±RW Burner
I have a problem when I burn my Mix cds on my Acard Technology. I have 3 second gap on my cds when I burn them, but my master cd doesn't have any gap in there. Can your help me to fix that problem, thanks
    Genius:
  • 1,043 Answers
You should check the settings for the program that you are using to burn your copies. Inserting space between songs is a common feature in burning programs and it may be turned on in yours.
Posted on Mar 13, 2011
    President:
  • 1,623 Answers
You can remove the 3 second delay in the burn options of whatever software you are using to burn the files to cd? I.E. Nero, Ashampoo, Roxio etc
Problem with duplicator controller Acard 2037P.After the first or second sucefully duplicating/burning of all seven CD DVD,the controler stop to "listen the orders".when i push the any button of...
Could be either. Perhaps the unit is overheating. Try aiming a fan at the ventilation holes and see if that makes a difference. Another possibility is that there are some capacitors that are aging. It could also be software, so check the manufacturers site for firmware updates. The unit probably doesn't require drivers, so I don't think you'll find any. The other possibility is the software you use to author the disks.
May 27, 2014 | Acard Technology 15 CD DVD Duplicator...
Update frimware
It's telling you to update the firmware. Visit the manufacturers website to see if it's available.
Mar 29, 2014 | Acard Technology Acard ARS-2039A 1-to-9...
How to factory reset acard pro
Does it have a reset button? If yes, then depress it for a few seconds.
Mar 15, 2014 | Acard Technology (CD1TO7T) CD-RW Burner
Acard technology 1 x 5 burner manual
Check out this manual .... at:
http://www.wimmedia.com/content/support/adtec_manual_standard.pdf
Mar 05, 2014 | Acard Technology Acard ARS-2030A 1-to-5...
I have burned disk using the ACard Pro. It plays well in the computer but skips and is blank in places in my car. How can I correct this
You can try using different brand of media, and try cleaning the lenses with a lens cleaner disk. Acard pro probably needs adjustment usually performed at the factory repair center.
Jan 30, 2014 | Acard Technology Computers & Internet
Acard 2039A copy problem
If you have access to the lens clean with a tissue or micro fibre cloth In circular motions gentle 10-12 swirls and then try the drive if problem persists then your drive lens have got weak need to replace drive. You have to remove the top cover of drive with 6-8 small screws. It first stops cd reading and writing or just take a specific brand of DVDs or CDs and then It fails over time, it's normal failure behaviour. Pls rate my solution if I helped.
Nov 19, 2013 | Acard Technology Acard ARS-2039A 1-to-9...
My acard technology pro burns dvds but the target dvds end up all scratchy like quality the pixels move and everything
is resolutions pixel problem only on the dvd disks you burn?
you might have to save the dvd to a file first then burn it to a dvd
are you copyning from another dvd or from a saved file ??
you might be burning it as data
this might be a problem with the quality of the dvd disks you are using or might be the software you are using there are lots of free burning sofrware programs on the internet
this might be because you have not selected the option to burn an audio or data dvd or your burning software does not support dvd burning
there are plenty of free burning software programs on the internet
http://www.majorgeeks.com/BurnAware_Free_d5839.html
BurnAware Free is one of the most popular free CD, DVD, Blu-ray Disc burning software available for Windows.
Using this program you can easily create and burn Audio and MP3 CD, Data and DVD-Video disc, ISO and Cue Image,
erase or format rewritable disc, copy your CD or DVD to ISO image.
http://download.cnet.com/magicdisc/3000-7970_4-10383679.html
MagicDisc Virtual CD/DVD-ROM is a utility designed for creating and managing virtual CD drives and CD/DVD discs. MagicDisc Virtual CD/DVD-ROM emulates audio, data, and game CDs and DVDs with ISO image, CD and DVD images. MagicDisc Virtual CD/DVD-ROM offers 200x speed and noiseless CD/DVD access without a physical drive. It supports creating up to 15 virtual drivers. You can run games, software, see movies (VCD, SVCD, DVD), and hear music directly from your hard disk without inserting and swapping CDs and DVDs. MagicDisc allows you to use almost all CD/DVD image without burning them onto CD or DVD in order to easily access your favorite games, music, or software programs. It works like a real CD/DVD-ROM: You can run programs, play games, or listen to music from your virtual CD-ROM. It can compress ISO CUE MDS NRG CCD image; can encrypt ISO CUE MDS NRG CCD image; can make ISO image from CD/DVD; It can mount UDF only CD/DVD image and multi-session MDS/MDF and CCD/IMG image.
hope some of this helps you
Sep 10, 2011 | Acard Technology (ARS-2030LD) DVD±RW...
How do i burn dvd's
http://dl.acard.com/manual/english/ars-2030ld.pdf
http://dl.acard.com/manual/english/Duplicate%20Controller%20Functions.pdf
Apr 17, 2010 | Acard Technology (ARS-2030LD) DVD±RW...
Got acard 7 duplicator burns but will not play
This may due to you have not closed the sessions properly. After burning need to finalysing the same.
Revert back for more assistance and give your valuable feedback/rating for the solution provided.
Thank you for using Fixya.
Mar 03, 2010 | Acard Technology (ARS-2030LD) DVD±RW...
Help
Laser problem.
will either be a dual laser, 1 of which is not working.
Or the laser is not powering up enough to burn the DVD Layer.
Try using a laser head cleaning CD.
Hope this Helps. p.s don,t worry if you can,t resolve this.
DVD burners are as cheap as chips now, you can always keep this one as a reader.
Good luck Mike @ Compurepair.
Feb 20, 2008 | Acard Technology (ARS-2032) CD-RW Burner
Acard Technology (ARS-2030LD) DVD±RW Burner Logo
42 people viewed this question
Top Acard Technology Computers & Internet Experts
Martin Murray
Alun Cox
DROPNDEAL
DROPNDEAL
Are you an Acard Technology Computer and Internet Expert? Answer questions, earn points and help others
