Once it's goes into hybernation, how to get started back up? comp. won't even start now
    Sergeant:
    Novelist:
  • 185 Answers
Remove the battery from your laptop for 5 minutes. Then replace battery and hold power button for a few seconds until laptop boots.
Hope this helps and please rate.
Posted on Mar 13, 2011
Hi there I have a msi fx603 that won't start when you hit the power button it flashes once then when you let it up it flashes once more but wont start ...the only other thing that happens is the m
Hello here is the msi homepage:
http://www.msi.com/product/nb/FX603.html#/?div=Driver&os=Win7%2064
I think your harddrive is dead, and must be renewed.
The fault could also be the mainboard itselves.
A computer repair shop, can help you with that.
Good luck
Apr 01, 2013 | Computers & Internet
My emachine isn't starting up after hybernation, unless i press the power button and reboot. Why is this?
When your system goes to hybernation it creates a file on the root drive called hyberfil.sys in most instances this file gets corrupted and is causing the computer not to wake up from hybernation.
You would have to try and delete this file so that it will re enable the normal hybernation wake of your computer, here's how to do it:
http://helpdeskgeek.com/windows-7/windows-7-delete-hibernation-file-hiberfil-sys/
Just have to reverse the process to re-enable hybernation.
My recommendation would be to just disable Hybernation and just let the computer go to sleep if you're going to leave it idle.
Hope this helps!
Aug 03, 2011 | E-Machines eMachines Desktop PC
My laptop is not switching to AC mode even when plugged into Ac Power outlet. I work on battery mode and after full battery drain, the laptop goes into hybernation...once into hybernation it starts...
1. You may possibly have a faulty power supply adapter. Contact the manufacturer and see if there are any call backs on the power adapter for you laptop unit
2. you may also have a damaged connector at the laptop connection. This will require repair by a technician.
Aug 03, 2010 | Computers & Internet
WHEN MY LAPTOP HYBERNATES, IT WILL NOT COME BACK ON BY TOUCHING THE KEYPAD. I HAVE TO SHUT IT DOWN AND TURN IT BACK ON TO USE IT.
go into control then power options click on advanced then on the bottom 2 drop down arrows it will give you the options of how you wake comp from hybernation.
hope this helps
Apr 28, 2010 | Dell Inspiron 6000 Notebook
Gone into hibernation - can I retrieve
When your laptop goes into hybernation, all files are saved as they were. As soon as you re-start your computer, it will open all files and programs as they were before hybernation started, so YES, you can retrieve everything as it was before.
be sure the computer ios plugged into a charger, to be sure the batteries are charged.
Please, let me know how it goes.
Alex
Mar 21, 2010 | Computers & Internet
Computer goes into Hybernate Mode after each print Job.
Try plugging the printer power cable into a different power outlet, preferably an outlet that is not shared. I had a similar problem but in my case, the computer would crash. For some reason, the HL-5250DN demands so much electricity on starting a job that it doesn't play nice with the other equipment.
Mar 04, 2009 | Brother HL 5250DN Laser Printer
Toshiba Satellite A55-S306 doesn't come out of hybernation
Turn the PC on, when it is booting up, keep hitting "F8" until windows boot options come up, choose "Safe Mode" and then once it boots into safe mode fully, go to the start menu and choose shut down. After it shuts down, turn it back on and it should go back into normal mode. From now on, don't use Hibernate, its buggy and has been since XP.
Feb 02, 2009 | Toshiba Satellite A55-S306 Notebook
Black screen
Yes, it could be stuck in hybernation
Or.. Check to See if the Lid Switch is Stuck Down... Some laptops have alittle Movable plastic pin that depresses when the lid is closed to turn the screen off... this can sometimes get stuck down to the board button.. causing the symptoms youre experiencing
Jun 04, 2008 | Toshiba Satellite A105 Notebook
Random Hibernation
this sounds like power settings options.
what i can suggest now is that......................
go to the Power Options in the Control Panel and do the following.
  • first uncheck the hibernate option on the hibernate tab
  • use your computer and see if the problem re-appears, go to the control panel and on the power option, select Never to all options when using battery or ac power.
cheers...............
Oct 24, 2007 | Sony VAIO VGN-N130G/W Notebook
Computers & Internet Logo
14 people viewed this question
David Payne
David Payne
