Question about Acer X193W LCD Monitor
The monitor is half dark, constantly flickering, makes electrical/static noise that is coming from the back, controls have no effect
    Novelist:
  • 66 Answers
This sounds like a serious electric short in the internal workings of the monitor. I highly recommend unplugging the monitor from electric power and taking it to a business that can diagnose it properly.
I'd hate to say check the power cable and other diagnostics you do yourself because the risk of shock and injury is high.
If you have a Best Buy locally they tend to be nice about doing quick diagnostics on this type of thing for free, but they do generally charge for all work done.
Hope this helps!
Posted on Mar 13, 2011
It sometimes makes a static nose and the picture is dark i have tried messing with the color and back light settings and it doesn't do much
Samsung LCD TV with no video and high pitched sound - Digital TV ...
www.tomsguide.com/forum/54120-4-samsung-video-high-pitched-sound
Jan 7, 2010 - 26 posts - ‎15 authors
Hi, I have a Samsung LN40A550 LCD TV which I have had for just over a year. ... I was watching TV yesterday and all of a sudden the picture went all. ... started makinga very high pitched buzzing sound with no picuture coming on. We did have a bunch of green vertical lines, but now just a black screen.
Samsung LCD Green Screen - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - TV hooked up to basic cable and getting green screen picture. ... I was getting green static in the dark areas and green fuzz down the left hand ... where can you find the white ribbion, i have a lg rt-32lz50. it works sometimes, but i goes green. Samsung LCD TV screen went black (audio on, no picture)
Jun 11, 2015
Samsung LCD TV Has Flickering Horizontal Lines (Pic Inside ...
Jun 11, 2015
Samsung DLP crackling/static noise
Jun 11, 2015
LCD TV making clicking/cracking sounds
Nov 24, 2006
More results from www.cnet.com
Samsung LCD Loud Noise and Green Vertical lines at Start up ...
www.badcaps.net > ... > Troubleshooting TVs and Video Sources
Feb 03, 2016 | Samsung Ln40e550 40 1080p Lcd Tv ln40e550
Uniden gmr2638_2ck is always stuck on receive. Rd is always showing and static coming from the speaker
Adjust your SQUELCH control or setting so that the noise disappears. The RX indicator will go out.
Mar 01, 2015 | Uniden Radio Communications
My washiong machine is an LG washer/dryer its coming up with message LE each time i start a cycle, the wheel will not turn. I have halfed the load, turned off and on tried different cycles put still does...
Hi
Thanks for using FixYa. LE' error message indicates the control board has detected that the motor is either not turning, or has locked up for some reason. Monitoring the motor is the job of the Hall Effect sensor board which constantly determines the direction and speed of the motor and feeds that information back to the control board. If there is a problem between what the motor should be doing and what the hall effect sensor says the motor is doing, the 'LE' will be displayed and the cycle will be stopped. The hall sensor is rather easy to replace, and is covered by a seven year part warranty (in US). It only takes around half hour to replace it with a new one. Take the back cover off. Take the big nut off and remove the motor rotor. Remove the bolts holding the motor windings. Remove the electric plug on the sensor and unclip it from the motor winding. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Sep 06, 2010 | LG WM3431 Front Load Washer / Dryer
LE comes up on message center
Hi
Thanks
Rylee
Jul 03, 2010 | LG WM-2277HW Front Load Washer
LG Computer Half Light, Half dark?!?!!?
Install the forteManager software that comes with your LG LCD monitor. Go to the Options tab and choose Restore which will set it back to factory settings. For some reason some monitors come this way out of the box and this was the only way I was able to solve the problem with mine.
Sep 18, 2009 | LG Flatron L1919S LCD Monitor
Acer AL 1912 (black) resolution issue
[u][b]LCD Monitor Shadow Effect[/b][/u]
This problem is best described as the LCD monitor "Shadow Effect".
The solution to this very simple. No software or hard ware changes required.
The cables that are connected to the LCD monitors are causing the problem. Its also called as electromagnetic noise or electrical noise.
[u][b]Solution: [/b][/u]Keep the two cables - (power cable and moitor display cable), that are connected to the LCD monitor as far away as possible with each other and also away from other electrical cables.
Thats it. Your shadow effect is fixed.
Thank you.
May 27, 2009 | Acer AL1912 19" LCD Monitor
Dell E193Fp Blue Screen
It can be due to the effect of some kind of magnetic effect.. If your monitor has the degauss feature then degauss it ONCE and see if returns to normal. Do not use degauss feature more than once in less than half an hour. It can damage your monitor.
Nov 16, 2008 | Dell E173FP (Black) (Dark Gray) 17" LCD...
Speakers making a constant poping noise.
this could be due to some static  please get your electrical point checked up 1st  is your tv hooked to watch television thru RF or AV please have the interlink cables if this does not help get back with more details
Oct 15, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Xbox 360 flickers across screen
it is your av cable however the components in the cable get a small static boost when u are using your controller so it becomes an intermittent fault ie;....when in game vidios or watching dvds, u rarely use the controller so u dont see the flickering and u only see it when in game play because u are in constant contact with the controlls and the components inside the av cable recieve a small static boost causing the interference.
Oct 07, 2008 | Microsoft Xbox 360 Console
High pitch sound being emitted
It could be a harmonic noise caused by dust inside the monitor. If you are qualified (brave enough) to remove the back cover, blow the entire inside of the monitor out with compressed air (carefully) that may help. It could also be the flyback transformer. In that case, you would have to have the transformer replaced (I wouldn't recommend doing it yourself unless you are a TV technican as the CRT can contain a static charge of 14,000-25,000 volts- even when unplugged)
Oct 15, 2006 | Philips SoHo 107T21 (White) 17" CRT...
Acer X193W LCD Monitor Logo
125 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
