Question about Garden
Own a Delta 46745 wood lathe. there is a wobble in the spindle. How do I determine what is causing the wobble? The cause has to be in the faceplate or spindle and I would like to order the correct part(s).
  • lcage487 Mar 13, 2011
    Is there a possibility that the spindle is bent as the wobble is in the same place all of the time. Or will worn bearings cause the same result
  • lcage487 Mar 14, 2011
    Thank you
  • 3,740 Answers
Hi and welcome to FixYa, I am Kelly
You can find your parts here:
http://www.ereplacementparts.com/delta-46745-type-lathe-parts-c-3275_9659_14232.html
The spindle is item 12 while the bearings are times 13 and 14. Most likely you have a worn bearing Item 13 but if the bearing went dry and spun in the bearing mount you may have to shim the NEW bearing. Note that the housing item 9 is not even listed on the itemized parts list nomenclature. The bearing seem terribly expensive. I would think that you could take a "sample" bearing (the one you removed) to a place like NAPA auto parts and find a much cheaper replacement. I would certainly give that a try before spending over $100.00 for a bearing. The two bearings combined will be over $200.00 + shipping. Usually NAPA can take the number off of the bearing AND use a micrometer to find a bearing that will work for you. The only reason I can think that these 2 bearings are so expensive is due to the side loads they incur when in use.
Thanks for choosing FixYa,
Kelly
Posted on Mar 13, 2011
  • Kelly
    Kelly Mar 14, 2011
    If the wobble is in the same place it certainly can be a bent spindle. You should be able to use a true stick (eliptical distance check) off of the side of the spindle and prove that. You can use anything that you can get in that area stationary at a fixed distance and then rotate the spindle watching for the distance to change. If you can not see it you can hit it with a light spraying of some white spray paint. Watch to see if the scratch marks you make with your measuring device has gaps in it. Gaps in the paint would show up where the spindle moved away from your measuring device. I hope you understand the concept of what I am referring to here.
    Kelly
  • Kelly
    Kelly Mar 14, 2011
    I had yet another thought and that would be to use your tool rest with a stick and see if the spindle head was wobbling left and right as it rotated. This check would pretty much nail down the fact that at least the end of the spindle is bent somewhere. I am not sure how sturdy your lathe drive base is but you could attempt to straighten the spindle head if you understand the physics of doing so with a jack and some blocks of wood. IF the base is not that sturdy... this could be a very bad idea as you could cause catastrophic failures of structural components by using a jack. If the structural components are not that sturdy your only option would be to replace the spindle. Just thinking on how I would solve the problem in the most feasable way without damaging the Lathe.
    Kelly
Looking for a live centre and drive end spur for a Mastercraft 554508-0 cast iron wood lathe
Such accessories tend to be universal rather than dedicated to any particular make or model of lathe.
Such accessories are available from many outlets and catalogues containing items for the wood-turning enthusiast.
The tailstock of most lathes would be produced with a Morse taper numbers 1, 2 or 3 and with a variety of adaptors a number of live or dead centres, drill chucks or morse taper drill bits can be used.
Similarly the headshock spindle should be found to have a standard thread capable of accepting a number of chucks, faceplates, drive spurs and so forth.
The headstock spindle thread and the tailstock taper should be listed in the machine specifications and then armed with that information you can shop around a multitude of suppliers to find the best deal.
Apr 19, 2016 | Tools & Hardware - Others
I'm looking for a owners manual for a ML618 wood lathe. I'm looking to see if it has more than one Chuck?
Most wood lathes, like most metalworking lathes, have a spindle that is threaded to accept a variety of fairly standard accessories including chucks and faceplates of various sizes and types to accommodate different types of work.
Any lathe that does not accept a variety of such accessories would be a complete waste of time.
Obtaining a manual for much imported machinery is almost impossible to obtain but most imported machines are close copies of industry standard machines and so generic information such as can be obtained from almost any supplier or experienced user is all that is required.
Oct 19, 2015 | Tools & Hardware - Others
The turret is out of center on sl25mc lathe
The front turret bolts will need to be removed. Remove bolts in face of turret. There should be some adjustable bolts that will allow you to move the turret back in the correct position. Load a precision ground block into OD tool holding slot, usually tool 1 position. Hang it out around 4 inches. Indicate this block within .0005 or as close as you can get it while tightening the set bolts. It usually takes a couple of tries. Also the spindle might be knocked out as well. You can check spindle by cutting between centers. If it cuts tapper then it is also out of alignment. Hope this helps...
Dec 20, 2013 | Samsung Tools & Hardware - Others
Fix motor pulley on delta 46-715 type 1
Just make a quick google search. You'll surely find several suppliers.
Jun 07, 2013 | Saws
Fox mini lathe not running right
Could you be a bit more specific? This is a very simple machine...it either works or it doesn't. Have you checked the belt? Is it binding, or cross-threaded on the drive spindles?
Jun 16, 2012 | Shop Fox W1752 Mini Wood Lathe
I need a MANUAL for a Rockwell/Delta #46-525 Wood lathe
I have a paper copy of the manual and parts list. I can scan to pdf but don't know how to get it to you.
Jan 15, 2012 | Delta Saws
Brake lathe chattering bad
There's a lot of reasons why a brake lathe chatters during a cutting operation. They range from lack of maintenance, adjustments, cutting speeds, wrong cutting tools and so on and so forth.
Be a little more specific.
What kind of machine are you using?
What are you cutting? (rotors? drums?)
Are you using the proper silencers?
Come back with some answers please.
Buy Sell Used Brake Lathes Brake Lathe Parts
Dec 16, 2010 | Ammco Combination Disc/Drum Brake Lathe
I have an old Delta D-220 drill press. While the chuck spins true, even at high speed, a drill bit will have a slight wobble towards the end of the bit. I tried many bits so its not a bent bit. Solutions? ...
You are right,but if the wobble is not too big to do drill jobs it can be used.Sometimes drill jobs need to be precise,so the you will need it just aligned.
Try at eReplacementParts.com : Power Tool Parts and Tool Repair Diagrams or go direct to this link.
Good price and service.
If you need more help come back.Post / thumbs / testimonial are welcome!
Nov 15, 2010 | Delta Woodworking Vintage Delta Dp 220 14"...
Crib sturdyness
If it feels as though it wobbles, a likely problem is that the screws have not been fully tightened. They may feel tight, but give them all one good torque turn or two, until you cant anymore, pretty much. It should solve most of the wobble.
Jun 04, 2007 | Childesigns Shelby Crib
Garden Logo
98 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
