Question about Jenn-Air JCD2290HES Side by Side Refrigerator
Refrigerator temperture is about 60 degrees. freezer 30 degrees and tehre is ice builu up on the back wall of the freezer
  • Jenn-Air Master
  • 43,501 Answers
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Mar 13, 2011
I have a Frigidaire FRS26R4CWE both the Freezer (30 degrees) and Refigerator (41 degrees)were not cold enough. This a spare basement refrigerator that we use once in while. There was no ice in the bin....
Hello;
My name is Peter. I am a retired field service refrigeration technician.
When you removed the freezer you should have seen a even frost pattern across the cooling coils.
If you have ice at the top especially in the upper right have corner, then you either have a restriction or a refrigerant leak. In the upper right hand corner you have a very small tube with a inside diameter the size of a small needle. It is not uncommon on older units for this tube to become plugged up or leak.
A repair of this nature by a service technician would be about $550.00 USD.
Feb 16, 2015 | Frigidaire Refrigerators
Kenmore refrigerator side by side. EnergyStar sticker says model series 56541-56551. Freezer side cold; fridge side between 50 and 60 degrees. I unplugged for at least 2 days for ice to melt. Fan at...
If there is ice built up on back inside freezer wall, you have a defrost problem. Either defrost heater, defrost thermostat, or defrost control (timer or Board) is bad.
Sep 05, 2017 | Kenmore Refrigerators
Our Amana frig temperature is approximately 60 degrees with the lower freezer under 32 degrees. The unit is running constant. Any repair solutions would be appreciated.
Check and see if the fan is running in the freezer. If not may be bad or frozen. If is running check and see if there is any frost in the freezer if the fan is in the back then check the back wall of the freezer. If yes the it is not defrosting . Thaw it out for 24 hours and it will work for a week or so but it will need either a defrost timer, heater or thermostat.
Oct 27, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
GE 24 Profile refrigerator: The freezer part
my refrigerator goes into auto defrost every 60hrs for 45 minutes or till the bi metal(defrost thermostat) says it had enough....recently i had ice built up on the coil because my defrost thermostat was stuck open...
ice builds up because the moisture that comes from opening the door or food condenses on the cold coil...tempurature of the coil is below 32 degrees which will ice up the condensed moisture...
defrost is timed to remove this build up
Oct 01, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
The refrigerator temperature ins 50 and the freezer is 15. Is this the appropriate temperature? The butter is soft at this temperature
the fridge should not be above 40 degrees and the freezer not above 30. check back wall of freezer for frost. if so, coils are iced up and need to be defrosted. either take off back wall of freezer and melt ice with warm water or hair dryer, or unplug unit and let it set with doors open for a day. then clean up the water.
Jul 20, 2009 | Jenn-Air JCB2280HES Side by Side...
We have an Admiral top freezer refrigerator. Freezer is working refrigerator is running at 60 degrees.
If there is no ice on the back wall of the freezer, make sure the freezer fan motor is running. If there is ice on the back wall of the freezer repair the defrost components. Timer,heater,thermostat.
Jun 09, 2009 | Maytag Admiral Top-Freezer Refrigerator
Kenmore fridge and freezer not cooling
Check to see if there is any ice built up on the back wall of the freezer. If so thaw the ice and take the back wall out of the freezer. next check to see if the fan is running in the freezer (evaporator fan) This fan is what circulates the air from the freezer to the fridge. If it does run then you have a defrost problem (if ice is on the coils and back wall). Then replace defrost timer, heater, and thermostat.
Nov 19, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Jenn-Air JCD2290HES Side by Side Refrigerator Logo
192 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
