Question about Philips Office Equipment & Supplies
This is not an actual problem, just a question about the Personalized Key Chain. The instructions don't say whether or not the unit should be turned on or not when being charged. Does it need turned on while charging?
    Problem Solver:
  • 11 Answers
No, it does not to stay turned on while charging.
Posted on Mar 13, 2011
Keypad don't light up
see this causes and fix it. God bless you
Lights come on, but can not program unit, Touchpad dead If you have a stuck key or non-responsive key, most of the time you will have to replace the keypad for this microwave oven repair. If your keypad is connected to your control board by a flat ribbon wire, try disconnecting it and clean the silver contacts with an ordinary pencil eraser. After cleaning, plug it back in and try it. If it doesn't fix it, replace the keypad unit. Some units actually have keypad tests to confirm your diagnosis of a bad key.
If your keypad and control is the same unit, replace that unit. Another note, unlike stove/oven keypads and controls, most microwaves do not have error codes or tests to distinguish whether it is truely the keypad or control. Most of the time, it is the keypad that needs replacing, but a small percentage of the time it can be the control. Check the tech sheet if they can point you to the right part.
Sep 25, 2012 | Maytag MMV4205 Microwave Oven
Yesterday was the first time that it happened.
There's always a first time for everything.
Go to HD or Lowe's and buy you a blue bottle of StarTron Star Brite, and use it per the instructions. While you're there get a can of Berryman B-12 Chemtool and use it per the instructions. Your key switch can cause the same symptoms, and the key switch can actually cause your fuel pump to fail, because ti looses enough ground. But don't worry about that until after the tricks above.
dc don
Sep 03, 2012 | 1997 Nissan Quest
2000 jimmy ignition wont turn
your tumblers are worn or damaged, some people don't realize if you have to many things on your key chain the weight can cause damage to the tumblers in your ignition. That may not be in your case but I bet the tumblers or maybe even your key is worn out, if you have a spare key try it first.
Aug 01, 2012 | 2001 GMC Jimmy
Does the fuel pump on a 97 chrysler lhs make sound when the key is on?
check the fuses for the fuel pump then if its good check the wiring for the system.there is also a pump relay in the system to check,if there is no power to the tank unit then changing the pump is not going to fix the problem.
Oct 23, 2011 | 1997 Chrysler LHS
I have captial E with an accent on my question mark key and cant get if off! It will not give me an apostrophe either. How do I get it off
Probably your keyboard is set for a different language. Follow the instructions.
1. Open control panel.
2. Open 'Regional and Language Options'.
3. Select the second tab "Languages' and click Detail button.
4. See whether 'English (United States)' is present in the lower box. If you don't have it, click 'Add' button to add it to the list.
5. Select 'English (United States) - US' from top combo box.
6. Click 'OK'.
If your problem is solved, do not forget to give me a comment/feedback!
Goof luck!
Jul 12, 2011 | Acer NSK8458AN Keyboard
Why want my truck start. Turning. Over fast
When you say it is "turning over fast," I'm assuming that the starter is engaging and actually cranking the engine. Not knowing the YEAR and MODEL of your truck, I can't even guess which engine it has.
Whether it has a timing CHAIN or a timing BELT in the engine, chances are that is broken and that replacing the belt or chain will likely solve the issue. Hope that's helpful!.
Jul 01, 2011 | Lincoln Navigator Cars & Trucks
PULL CHAIN FOR LIGHT BROKE AND IS INSIDE THE UNIT. HOW DO I GET THE LIGHT UNIT OFF TO GET TO THE PULL CHAIN UNIT.
"PULL CHAIN FOR LIGHT BROKE AND IS INSIDE THE UNIT. HOW DO I GET THE LIGHT UNIT OFF TO GET TO THE PULL CHAIN UNIT."
My oh my!
I don't know of any shortcuts, and the working position does not make the operation a pleasurable one. Not in Summertime!
The time I had to repair that, I needed to pull the whole fan down. Once the whole fan was down, the rest was easy!
It's easier that it appears, but mark all the wires connected in the box.
There is USUALLY a steel cable attached to the fan assembly and the box, to prevent the thing accidentally falling on someone's head.
If you don't have a helper, taking the blades off may be a good idea, but don't take my word for that. Putting them back on was no picnic.
FYI. If you don't have any bead-chain handy, a suitable lenght of sash cord is probably the best replacement.
May 15, 2011 | Hunter (25417) Ceiling Fan
Where can i download lg gb230 themes for free?
You can only use the preloaded themes on your phone. However you can actually personalized the wallpaper, screensaver, message alerts, ringtones, on this phone whether it's downloaded online, or you made it yourself. Hope this helps!
Jan 15, 2011 | LG GB230 Cell Phone
Lost instructions on how to sync bluetooth to new phone
If you go in to your phones menu you will find a bluetooth snyc tool. The phone should pick up the signal if the earpiece is turned on. One thing this multifunction button does NOT do is turn the unit on and off. The entire switch itself slides up and down. There are times when you simply don’t want to bother with the earpiece, change wireless headphones, or don’t want to risk accidental calls. So the slider switch is a much easier way to keep track of whether or not the H670 is on or off than waiting for a blinking blue light that may never come.
Have a great day.
Jun 29, 2009 | Motorola Mobility H670 Wireless Headset
Programming the DSS/BLF
Need to login in system and program buttons from there.
Nov 07, 2007 | Inter-Tel Axxess Phone 5504400
23 people viewed this question
Top Philips Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Philips Office Equipment and Supply Expert? Answer questions, earn points and help others
