Question about Humminbird Sport & Outdoor - Others
I have a vhf5 marine band radio with no battrie charger can you please tell me the output dc voltage of the charger so i can get one to charge my batt. thank you.
Benimur
  • 6966 Answers
SOURCE: lost power supply
If the desktop charger is the version that can accommodate two radios simultaneously similar to the T5000, then the AC wall adapter or the power supply is 9 volts AC.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on May 26, 2008
eradiostore
  • 1654 Answers
SOURCE: What is the dc input voltage for a 7.5V NTN1171A charger for a MTX838?
The book list the wall adapter to charger NTN1171 as being part number 2580162R01. The description says 13.8VDC 1.5A AC ADAPTER. When googling the part number, it appears someone is selling one on eBay for around $29.99. Retail from Motorola appears to be $125.
Posted on Sep 30, 2008
  • 3 Answers
SOURCE: Navman icn 720 gps will not power on
Poss that the battery is totally dead, and therfore will not power up even when on ac or 12v charger lead. Often the battery is part of the circuit, and if the battery is dead rather than just weak or discharged, then the circuit is incomplete.
I posted on here how to remove the battery, you can get a replacement quite easily. Also would be an idea to search out a correct output charger, or maybe borrow one just to determine if the problem was with the battery rather than a blown unit.
Good Luck
Posted on Mar 05, 2009
haayz
  • 197 Answers
SOURCE: Replaced the dc jack because it would not run on the charger. Still won't charge or run on charger. Is there a voltage controller on the motherboard, because the charger puts out 19.5 static volts a
Try taking out battery and plug in power. If it works, battery is faulty. If not,
Try taking out your hard disk plug in power, if it works, hard disk is faulty. If not,
Try taking out memory card, if there's a sound, memory card faulty. If no sound, it's your motherboard that is causing the error.
Note: If machine is under warranty no need to pay for the repairs.
Posted on Jun 03, 2009
  • 67 Answers
SOURCE: Trying to convert marine radio to ham band ? Cybernet CTX 1200
big shuift 156 MHz to 144 MHz !!
Posted on Jul 28, 2009
Telefunken south africa
Check the DC output voltage from the charger. If there is no DC output, replace the charger.
Jun 17, 2014 | Televison & Video
Tip
Samsung TL205 Battery Charger Samsung TL205 Charger
With the most high-quality camera battery charger,
Description: Home Travel Charger
Input Voltage (AC): 100-240V 50-60HZ
Car Input Voltage (DC): 12-24V
Output Voltage: 4.2V/8.4V
Output Current: 600mA
Dimensions: 1.86" x 3.33" x 1.50"
Weight: 2.5oz (85g)
Color: Black
Features:
A. Direct Plug-In wall Samsung TL210 Battery Charger - No cable necessary
B. Samsung TL210 Battery Charger Output: DC 4.2V 600mA
C. 110-220 Volts - Works in every country in the world
D. AC Car Adapter - Charge your battery at home or in your car
E. Fast Charger 800mA - Charges most batteries in 60-120 minutes
F. LED Charger Indicator - Red light: needs charging, Green light: charging is complete
G. Samsung TL210 Digital Camera Battery with Manufacturer's 1 Year Warranty.
H. The Samsung TL210 Battery Charger is for charging your battery only. It does not work as AC adapter for your camera
on Sep 21, 2010 | Cameras
Shuts down on AC in less than 3 minutes after boot but not in safe mode. Works fine on battery only. Charges battery fine. DC output voltage 19.77 VDC. Sony Vaio PCG-K35
Sorry about your SONY problems.
You may want to try another charger,
Your charger changes your input voltage from A/C 120V / 220V to a constant regulated 19.77 ? Volts DC. or direct currant.
If your charger is allowing to much A/C to pass to the Unit, the unit may charge OK but with sense the incoming and as a protection, will shut down the power source.
I would take the charger to a Radio Shack or maybe someone qualified to check it !
If the charger is fairly old and you live in a lightning area, this may be the case.
If your unit will run without the charger attached, Boot it up regularly ( not in safe mode ) and make sure the battery if not at fault.
If you have a battery check utility !
Hope this information has helped you with your problem.
John Ray
john@johnrraycomputer.com
Readers, please rate your technicians information.
Jul 12, 2009 | Sony VAIO PCG-K35 Notebook
My motoflip is not charging
Your battery is dead. You need to change it. One more thing you can check before changing your battery put your battery in some other handset and try to charge it through that charger if it works then your chargers output voltage is wrong change it.
Jun 16, 2009 | Cell Phones
1. isthe battery charging 2.isthe charger
You don't mention a make or model, so I can only give you general solutions. If the radio has a drop-in charger there may be a light to indicate charging. If the light comes on when the radio is in the charger, it's getting a charge. If you have a multimeter, DVM, or DC voltmeter you can check the battery voltage (charge) both before and after a charging cycle. You can also use the meter to confirm the output from the charger. If possible, replace the batteries with standard alkaline types and see if the radio works. I hope this info helps.
Bill B.
San Antonio
Apr 30, 2009 | Motorola Walkie Talkies 2-Way Radio
The voltage for charging and plug-in power, cobra hh35?
the voltage for the charging is 12 volts dc the charger is a 110 volt dc 12 volt to the radio if you lost your charger you can get a aftermarket at any radio shack store just be sure you take the walkie with you when you go so they can match up the rdio plug end.
Mar 11, 2009 | Cobra HH 38 WX 40-Channels Handheld CB...
Where can I purchase a battery charger?
A new product laptop battery charger
AC input:100-240V AC 50/60HZ
DC input:12-24V
High output:16.8V 2.5A DC
Low output:12.6V 2.5A DC
charge time:3-5h
color:black
That has be dead against use front happen problem and LI ion battery trait., when charge battery must take out use, has insure up to snuff on room temperature charge , as well as can avert happen blast or combustion or life reduce problem. simultaneity can let it is accomplish normally charge and discharge process the battery , It’s activation state urge LI ion battery inside is longtime. Can prolong use life the battery.
That has be dead against use two species battery voltage parameter at laptop IT trade, the product have setup switch switchover voltage, insure apply two species different voltage laptop battery charge, any more introduced commutator model the product DC output plug, can use different variety, let use charger electricize for laptop battery is safety and set one's heart at rest. And that can prolong use life the battery, best economize expenses which needless for the peoples.
It’s charge use AC to DC, DC to DC two model charger. May use in the home or office ,and car or ship or train. Usag is best convenience .
If you have need the product, please contact us
Mobile:13751018213
skype:lincen18213
Email:lincen18213@163.com
FAX:86-755-61573100
Feb 25, 2009 | Zenith ZPA-314 Portable DVD Player
14.4 B&D firestorm battery will not charge. I got it about a year or so ago online and just now tried to use it. charge is gone and it won't charge. do they wear out if not used?
Yes, Batteries can go bad if not keep charged. The problem may also be the charger itself. If you have a DC Voltmeter, you can check the charger's output...... if no output voltage is apparent (or too low an output voltage, relative to the Battery's voltage, it may be time to replace the charging unit.
Aug 27, 2008 | Energizer Rechargable Battery with Charger
Sport & Outdoor - Others Logo
162 people viewed this question
Top Humminbird Sport & Outdoor - Others Experts
Are you a Humminbird Sport and Outdoor - Other Expert? Answer questions, earn points and help others
