I bought a moffat electric oven 16 months ago it is burning the bottom of the oven housing unit whot is the problem thank you
    Brigadier General:
  • 6,277 Answers
You might find it difficult obtaining an answer from us- close, but this is the washing machine forum ;-0(
Try re-posting on the oven one and good luck ;-0)
John C
P.S. if I knew what was causing your problem I would have answered!!!
Posted on Mar 13, 2011
Manual for stoves 059050517
for some reason my bottom oven wont light, you can hear the fan but it does not click or ignite. I bought my house several months ago and the previous owner left no manual
Feb 05, 2013 | Ovens
Broiler will not come on when baking
Take a look at the element ( the "tube" inside the oven that glows red hot when the oven is turned on). If the element is burned out it will not be hot and glowing. You may have a loose connection to the element but most likely it is burned out and needs replacing.
Our stove is 27 years old and I have had to replace top or bottom elements every 6 years or so. I just bought a replacement element at Canadian Tire in Calgary for about $34. Just undo the 2 screws around the element and attach the new element to the old wires.
Good Luck -I hope this works for you
Jan 10, 2013 | Moffat Ovens
Oven rated for 208 voltage 220 volts available will this work or will I cause trouble
Yes it will work.Its nothing to worry. If the oven voltage is high and house old voltage is less then it will not work. But in your case its oven volt low and hose volt high.You can use it.Its a standard volt,you can use it. 'Most" equipment will work with a -15% / +15% voltage variance.--------- thanks.Helpmech.
Feb 05, 2011 | Moffat E32 Full Size Electric Convection...
No power to the unit. come with the house we bought. I know it went unused for about a year. Work fine for 6 months and then oven would go on and off, now cook top will not work....where is the...
The model unit is on the bottom drawer of the appliance. If you pull on the drawer it will be on the left hand side as soon as you open it. Good luck.
Feb 01, 2011 | GE Spectra JBP78 Electric Kitchen Range
I need a operations manuel for and E32 moffat
Try this site. http://www.moffat.co.nz/Catalogue/SalesPDF/E25.pdf
If this isn't it let me know and I will keep searching. Hope this helps.
Aug 27, 2009 | Moffat E32 Full Size Electric Convection...
Receiving F3 Code
HI, no need to replace the unit at this time. this is a Open or shorted oven temperature sensor (RTD).
Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
Jul 16, 2009 | GE JRS04 Electric Single Oven
Moffat 3000 oven
Can you please provide a Model number. Moffat has a huge appliance line. I do realize this can also either be a gas or electric oven. Possibly E32MS/2 or G32MS/A25 as a model number. Thanks
Oct 06, 2008 | Ovens
Heating
i would first check the lower units bake element , usually a visually inspection is enough to determine if its good or nor, usually a burn mark can be seen on the element itself, and if you can even see the element the bottom f the oven cavity will lift off for better inspection
Mar 25, 2008 | Maytag CWE5800A Electric Double Oven
GE Profile Spectra XL44
can ya post a picture of the piece and the door for refrence? thanks :-)
Sep 13, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Washing Machines Logo
23 people viewed this question
Top Washing Machines Experts
