Question about Canon Office Equipment & Supplies
I have a canon image runner 330 s, My question is. It is asking me to conact the finisher? What is a finisher and where is it located?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 58 Answers
A finisher is a whole seperate piece that sits beside the copier or sometimes it sits partially in the copier. Its used for collating and stapline mostly. There are also other options you can get( hole punch, folding, etc.) If your machine is telling you to connect the finisher and you dont have one i would try restarting the whole machine. Turn the main power of the copier off and let it stay off for about a minute. Turn it back on and see if the message goes away. If that doesnt work let me know and ill look into it further.
Posted on Mar 13, 2011
Canon Error E000075-002
514-0002 is a finisher error in the finisher
The delivery belt does not return to home position when the stack delivery motor is driven for 3 sec.
Main problem The stack delivery motor is faulty. The delivery belt home position motor is faulty.
Try to check motor & sensor or operate copier without finisher.
Sep 06, 2012 | Office Equipment & Supplies
My canon image runner 4005 (ir 330-405f) was connected to a network while i was formating my syste. The ip got deleted in it. What should i do?
check with network administrator for new ip or goto network settings and fetch ip by using DHCP.off/on the machine and thats it.
Sep 18, 2011 | Canon imageRUNNER 400S Copier
HOW TO LOAD STAPLES IN A CANON IMAGE RUNNER 3025
pull the finisher assembly out by the handle located just below the finisher output tray.on the back side of the finisher u will find the stapler unit.reload them by simply taking it out and then close the finisher
Jun 03, 2011 | Canon ImageRunner 3025 Black and White...
Hello Expert, Canon image runner was moved to a new location. Now error displays "attach finisher". Do you know what may be causing this error? Thank you
Hello rob,
the copier sees the finisher is attached but it does not believe the finisher is firmly docked against the copier.There is a mechanical latching system that holds the finisher firmly against the copier and has a positive latching system, This externally mounted hardware that resides on the copier not only has a physically latching mechanism **** also has a metal tab that sticks out and penetrates an area of the finisher.This small **** on the finisher has a switch inside,When the finisher is close enough and secured to the copier the metal tab on the copier penetrates the **** on the finisher and presses the switch and tells the copier the finisher is in place.The finisher is either not close enough and docked securely to the copier, or the metal tab on the copier is bent and not reaching the switch on the finisher, or the switch was damaged by the move.
Feb 14, 2011 | Canon imageRUNNER 5000 Copier
Do not have the system management password
try this press * with head near ? mark button then simultaneous press 2 and 8 .then same asterisk ,LCD display change, press COPIER>FUNCTION>CLEAR>PWD CLEAR> OK switch off/on the machine hope this can help
Jul 15, 2009 | Canon imageRUNNER 210S Copier
How to remove 4 cassette unit from canon machine IR 400
THIS WILL BE SOFTWARE SETTING ON THE CONTROL PANAL
CANON IMAGE RUNNER 400S COPIER USERS GUIDE
OR
CANON RUNNER 400S SERVICE MANAUL DRIVERS
OR
WWW.CANONUSA.COM/COPIERS
ROD
Feb 09, 2009 | Canon imageRUNNER 400S Copier
Image runner 400/330
Try buying a Intervia book, you can always use it. I think they are in book number nine.
Jul 01, 2008 | Canon imageRUNNER 400S Copier
47 people viewed this question
old marine
old marine
