Question about Kenmore Washing Machines
Sears Washing machine Model 110.28803890 Stock No. 28803
Rust pieces in bottom of drum, most likley from agitator shaft.
Can it be fixed or is it junk?
5 Suggested Answers
blueextc3221
  • 15935 Answers
SOURCE: I have a Sears Kenmore
The following advice is for replacing the "Agitator Dogs" on Kenmore and Whirlpool TOP LOADER style washing machines. This simple repair can save you a fortune in repair costs as the replacement parts are very inexpensive at a cost of less than $10. The replacement kit part number is 80040. You can order on line at various appliance parts websites, or use this part number and go to your nearest appliance parts retailer.
What are "Agitator Dogs"? These are small plastic pieces (usually 4) that are located under the agitator center cap that grip the agitator and turn it during the wash cycle. They can (and do) wear out dependent upon the use of the washer. If you are in the habit of doing large load sizes frequently, or wash large items such blankets or afghans, this can wear the teeth off and reduce the life of the agitator dogs.
SYMPTOMS REQURING REPLACEMENT: The agitator fails to turn during the wash cycle, or will not turn with a heavy load. The timer will run normally through all cycles, and you will be able to hear the gearcase (transmission) engage and run. The washer will also drain normally. The only indication that something is wrong will be the agitator slipping or not turning at all. The result will be clothes that do not wash properly and will sit on the bottom of the wash tub.
To replace the Agitator Dogs, follow these steps:
1.Remove the agitator center cap by either pulling straight up or gently placing a flat blade screwdriver into a slot located in the cap.
2.If the agitator is equipped with an inner cap with a handle, remove this as well by pulling straight up.
3.Remove the center bolt of the agitator. You will have either a 7/16" hex bolt or a recessed square plastic nut. If you have the square recessed type, use a 3/8" to ½" ratchet adapter to remove.
4.Remove the agitator by grasping the bottom flange and carefully pulling straight up. Try to keep all the parts assembled while doing this, so do not pull too hard. This will make this repair much easier.
5.Place your hand over the top of the agitator and separate the upper portion of the agitator from the lower portion and turn the top half over in your hand. The agitator dog assembly will come out in your hand.
6.With the agitator dog assembly in your hand, lay the rest of the agitator aside. Pay careful attention to how the dogs are installed. Remove the worn dogs and reinstall new ones. It's that simple.
7.With all the dogs replaced and the assembly still in your hand, place the upper part of the agitator over the top of it, upside down, ensuring the inner assembly tabs align correctly.
8.Now keep your hand over the agitator top to hold all the pieces together and turn the entire assembly over (upright position).
9.Carefully align and reinsert the upper portion of the agitator to the lower portion. Again, making sure the two pieces align correctly.
10.Place the entire agitator assembly back on the gearcase shaft and reinstall center nut. NOTE: DO NOT over tighten the nut, or the agitator will not spin correctly. Just make the nut snug. Reinstall center cap and inner cap (if equipped).
These instructions should give you the basics on how to perform this repair. Since there are various agitator types in use by Whirlpool and Kenmore, assembly can vary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 17, 2010
mikedurland
  • 481 Answers
SOURCE: Sears Stock# 28803 / Model# 110.28803890 / Kenmore 80 Series
this sounds like the direct drive coupling between the motor and transmission. very common problem and not very expensive. look under the machine and and between the motor and transmission you will see a round rubber coupling and 2 plastic pieces one on either side; they all connect together to mate the motor and trans without a belt.
Posted on Jun 27, 2008
jsrock516
  • 5911 Answers
SOURCE: I have a sears model 110 (82881110) the upper
It sounds like you need to replace the agitator dogs. The following link explains:
http://www.fixya.com/support/r823955-replacing_agitator_dogs
The part number is included in the link I provided. Replacements can be purchased at appliancepartspros.com for about $5. For a little bit more you can purchase the entire agitator cam replacement kit (includes, the dogs, seals and cam). The parts will be listed under the "Agitator Parts" section. Just use your model number for your search criteria.
If you have questions about this repair, or require additional assistance, please let me know. I hope this helps you.
Posted on Aug 22, 2009
Testimonial: "Thanks for the quick reply. "
  • 1937 Answers
SOURCE: Our Kenmore Model 110 - 82980120, Stock 29801 runs
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.82980120&pathTaken=partSearch
and you'll see a list of major sub-components with diagrams and parts.
When in agitate mode, the motor turn one way, When in spin mode it turns the other way for draining and spinning.
First, I'd pull the agitators and check for worn or damaged splines inside the agitator or on the agitator shaft.
Following is a description of how to take them out.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
If the agitator and shaft are OK, the problem may be in the transmission.
See the following Whirlpool / Kenmore installation and service manual for top load, direct drive washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
I'd also look at the troubleshooting section of the manual.
Starting at page 10, you'll see a description of how the transmission changes from agitate to spin mode.
The key (and likely problem) is the "agitator spring" or Agitate Cams.
See the Sears diagram for the gearcase:
The spring holds the agitate gear down so that the two sets of splines on the agitate gear are connected and the agitate rack can turn the agitators.
See the following Whirlpool parts list for a blow-up of the transmission and how the various gears and springs connect.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
See the following for how to remove the transmission and clutch.
Tearing apart the transmission is a bit messy but if the problem is the spring or agitate cams, it's a lot less expensive to fix than a $170 transmission.
Remove the clutch (the spring holding the clutch to the spin pinion is a bear to replace.
Remove the 8 transmission screws carefully, the transmission is full (15 oz.) of 80-90 weight gear oil.
Remove the transmission cover and drain the oil.
Pull off the spin pinion.
Carefully remove the clip that holds the main Spin Gear on and remove it.
Push down on the agitate spring and remove the spring clip. Note where is attaches to the main shaft.
Check the spring, Agitate Cams and the cams in the Neutral Drain Assembly.
Re-assembly is obviously the reverse of taking it apart.
If you're reasonably comfortable with tools you can fix it yourself.
When we had a problem with ours, we ended up spending less than $30 replacing the agitate cams, neutral drain assembly and oil instead of $170 for a transmission. It was worth fixing.
As an aside, tearing the washer apart will give you the opportunity to completely clean it.
Posted on Apr 17, 2010
  • 1937 Answers
SOURCE: My Kenmore model 110 will not agitate
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.92582210&pathTaken=partSearch
Newer model Whirlpool / Kenmore washers use a Lid Switch as a safety device. Unless the switch senses that the lid on the washer is closed, the washer will neither agitate nor spin.
Older models only used the switch during the spin cycle.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
This is a Whirlpool PDF on how these washers operate. It has a diagram on jumping the switch as well as a detailed section on how the transmission works.
It also has a troubleshooting guide.
To bypass the switch, you only have to disconnect the power to the washer, tilt the console back, unplug the switch and using an short piece of insulated wire, jump the two outermost contacts on the connector coming from the console and plug the washer back in.
Following is a description of how to gain access to the console and how to remove the cabinet if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=913ba652cd504fb162f87d892bcb427b
With the jumper in place, try to re-start the washer.
If it works, the Lid Switch is a relatively inexpensive part and only requires you to access the console and remove the cabinet.
Posted on May 10, 2010
GE washer WNSB9080B only allows me to run "Drain and Spin", no other cycle. It wounds like there is still water inside when I move the drum around.
In top loading washing machines, the agitator is responsible for moving the clothes through the water and detergent and is driven by the output shaft of the transmission. The output shaft is normally splined and the center of the plastic agitator will have a matching spline to ensure a tight fit. Depending on the brand of washing machine, the agitator may be a single piece unit or a two piece dual action agitator. If the single piece agitator or the lower portion of a dual agitator does not oscillate back and forth during the wash cycle, or if the agitator can be turned on the transmission shaft, then the spline may be damaged and the agitator may need to be replaced. Most agitators are held in place with a bolt that threads into the top of the transmission shaft and is located below the softener dispenser or top cover. Some models use a small set screw in the barrel of the agitator just above the base to secure the agitator to the shaft, while some will use a rubber o-ring to provide a tight fit. When the retaining device is removed you should be able to lift the agitator from the shaft.
Jul 18, 2016 | GE Washing Machines
I have a Kenmore 90series washing machine model 110.20902990. I removed the upper agitator as well as the bolts, on every video I've seen I should be able to lift the bottom agitator but I can not.
this most likely has a spline inside it , after years of washing id say rust is on shaft making for some tightness in side it , id try to use a heat (air) gun to soften up plastic to try and move it , don't forget to wear thick gloves as it will be hot on the hands
Sep 30, 2015 | Kenmore Washing Machines
Simpson ezi loader
The bearings are pre-loaded with grease but a smear of lithium grease can be used to ease fitting into the spider.The howling could be possibly because of the drum bearings.If your machine is making a rumbling noise as the drum turns then you most likely have an issue with the drum bearings. It's possible that normal use can allow water to get to the bearings. Remove the washing machine belt and manually turn the drum. If you hear a rumble as you turn the drum then problem is the ball bearings. Remove and replace them with new ones.Not knowing if your Simpson is a direct drive through a multi -speed gear box or another method, that makes it hard to give you a definitive answer. In my experience with earlier Simpson Washing machines the agitator should lift off the Splined shaft in the bowl by gripping the bottom of the agitator on the bottom edge using both hands at 180o between them, basically one opposite the other and trying to lift the agitator off vertically straight up until it clears the splined shaft and above the top lip of the bowl at which time you can remove it from the bowl. Be careful it doesn't give way suddenly as you maybe leaning over the bowl and with the force you sometimes have to exert it might come up and strike you hard around your facial region. If the agitator either has never been lifted off or a long period of time since it was then you may have to "wiggle" the agitator whilst attempting to lift the thing of the drive shaft. Once you have removed the agitator clean and re grease the splined drive shaft with suitable grease, not too much only a smear as too much will melt and leach into the bowl and hence you'll have greasy marks on the washing. Clean out the female splined section of the agitator and again a thin film of grease should be rubbed on the female splines. Replace the agitator on the shaft and make sure it's fully the length of the shaft as it will ride up and attempt to come of the drive shaft whilst the machine is operating if it's not seated correctly. If you think there are / is foreign objects beneath the agitator that seldom happens but sometimes it can with small articles. The problem of noisy agitators can be caused by worn bearings in the drive gear box which in turn allows the agitator to move sideways a bit and that then can grind on the bottom of the bowl under the agitator or even allow a small piece of cloth to get under the agitator etc. I doubt the unit would be driven by a belt directly connected to another pulley on the agitator but only a sub bowl inspection can prove that. I've never come across a Simpson that doesn't have a 2 speed direct drive gear box for the agitator and the spin dryer.
Note:- if you aren't sure about the greasing i would recommend you to contact the company's technician.
Hope this solves your problem.Please rate me if it helped you.
Regards,
Apr 12, 2014 | Washing Machines
I have a GE top loading washing machine. The agitator has stopped working and the drum no longer spins at the end of the cycle when the water drains. What can I do to fix it and get the agitator...
When the agitator on your GE washing machine does not work correctly, the most likely cause is a worn drive bell. The drive bell sits on the agitator shaft inside the agitator. The shaft and the inside of the bell lock together using splines. When the splines inside the drive bell wear out, the agitator will not rotate correctly. To repair the agitator on the GE top loading washing machine, you will need to remove the agitator and the drive bell.
1. Unplug the GE washer from the wall outlet. Open the washer lid to access the agitator.
2. Grab the bottom of the agitator with both hands and pull the agitator out of the washing machine. If the agitator will not budge, rent agitator hooks to pry the agitator out. Agitator hooks are available at appliance repair stores. Set the agitator hooks under the agitator and push down on the handle to pull the agitator off the shaft.
3. Pry off the plug on the top of the drive bell on the agitator shaft with a small flathead screwdriver. Use a socket wrench to remove the hex head bolt at the top of the drive bell. Carefully pull the drive bell up off of the agitator shaft. This may take some force depending on how stripped the inside of the drive bell has become.
4. Inspect the inside of the drive bell. There are splines inside the drive bell that line up with the splines on the shaft. Most often the splines inside the drive bell have worn, causing the shaft to spin but not the drive bell. Also inspect the notch on the outside of the drive bell and the notch inside the bottom of the agitator. If either of these are worn, replace the drive bell and the agitator.
5. Take the drive bell to an appliance repair shop to purchase a new part. If you need to replace the agitator, take the old one with you as well. Compare the new parts to the old ones, making sure they are identical.
6. Position the new drive bell over the agitator shaft, lining up the splines on the shaft with the splines on the inside of the drive bell. Set the securing bolt back into the top of the drive bell and tighten the bolt down until it pushes the drive bell down until the bell bottoms out. Push the new plug on the top of the agitator bell with the palm off your hand until the plug locks into place.
7. Place the agitator over the drive bell and slowly rotate the agitator until the notch inside the agitator lines up with the notch on the outside of the drive bell. Tap the top of the agitator down with the palm of your hand until the notch on the agitator locks down over the notch on the drive bell. The agitator will not bottom out flush with the tub.
8. Close the washer lid and plug the washer power cord back into the wall socket.
The defective agitator is the cause of the drum not spinning. So get the agitator fixed and it should solve the spinning problem.
Good luck.
Apr 22, 2011 | Washing Machines
Slow agitator in Sears Kenmore 800 Series washing machine
Enter your model number (110.#######) and you'll see a list of major sub-components with diagrams and parts.
Kenmore / Whirlpool top load, direct drive washers use a "Motor Coupler" between the motor and transmission.
It's used as a fail safe device and consists of three parts.
Two of the parts are the same, plastic units with three prongs that fit on one of the motor output shafts and the other on the transmission input shaft. Between them is a rubber piece with six holes.
The power from the motor is transmitted through the rubber piece to the transmission.
The other shaft on the motor directly drives the pump. .
If the motor coupler is broken, or worn, the motor may not be able to send full power to the transmission for agitating or spinning.
See the following for how to remove the cabinet, pump, motor and motor mounting plate to inspect and replace the motor coupler.
If the coupler looks damaged, it's a relatively easy fix.
Pry the plastic pieces from the motor and transmission. Some people use a claw hammer but I've found that using a small (6 inch) pry bar works well.
Carefully fit the plastic pieces over the motor and transmission shafts and press them in place (Use a 1/2" of larger socket to put pressure equally around the pieces.
Put the rubber piece on the transmission plastic piece.
Replace the motor mounting plate.
Carefully line up the plastic prongs on the motor based plastic piece to the three un-used holes in the rubber piece. If they don't line up right, the coupler could be damaged.
Mount the motor, don't forget the two screws, put the pump back on the motor and use its' clips.
Put the cabinet back on, don't forget to plug the lid switch back in and re-mount the console.
Jan 19, 2010 | Kenmore 15864/15862 Top Load Washer
I need a technical manual for a sears elite washing machine model # 11026922502. washing machine fills up, but does not agitate,spin.etc...
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=11026922502
Also see the Whirlpool service manual for these washers:
If it neither agitates nor spins, the first place to look is the Motor Coupler.
Between them is a rubber piece with six holes. The power from the motor is transmitted through the rubber piece to the transmission.
The other shaft on the motor directly drives the pump. This is likely why the machine drains.
Nov 02, 2009 | Kenmore Washing Machines
How do I reassemble Kenmore model 110.29842991 Need a parts manue
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=110.29842991
See the Agitator and Tub section.
Basically lower the main agitator onto the transmission drive shaft. (Be sure that the two pronged "washer" and clip are on the shaft).
2. Screw the double threaded bolt (with a rubber washer on the bottom) into the agitator shaft
3. Carefully lower the top agitator onto the lower one and screw the 1/2" (probably plastic) bolt onto the double threaded bolt.
4. Put the cap on
5. Put the fabric softener unit on and push down on the locking ring.
Oct 22, 2009 | Kenmore Washing Machines
I need direction how to remove Kenmore washing machine clutch
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
See the following:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137&osCsid=a90e77f262530006e64486ae2d6f5699
NOTE:
You don't have to remove the agitator(s) to get to the clutch.
You do have to take out the bolts that hold the agitator(s) to the main spin shaft inside the drum. The main spin shaft is part of the transmission.
You also don't have to remove the Spin Tube and Brake assembly.
It is a lot easier to remove the transmission if you lay the washer down on its' back.
Oct 16, 2009 | Kenmore Washing Machines
Jun 23, 2008 | Kenmore 24032\24036 Top Load Washer
HELLO, WSL100D0WW IS MAKING NOISE ON DRAIN/SPIN CYCLE.
Or, you have coins in your pump casing. Look on the back of the washer, and unscrew the circular port in the bottom right corner. (Keep an 8x13 baking pan underneath, water will escape once you open the chamber). Remove and change/objects from the chamber and replace the port. You should be good to go. This is actually very common for this model washer.
May 17, 2008 | GE Spacemaker WSLP1100D Top Load Washer
Washing Machines Logo
110 people viewed this question
Richard Roth
Richard Roth
Archaeology
Archaeology
Fordexpert
