Question about Hitachi DS18DL 18V Liion Cordless Drill Driver
The chuck on my cordless drill won't open or close. It was working fine then I went to change a bit and it was frozen. The chuck is empty(no bit in it).
kirkx
  • 2019 Answers
SOURCE: A bit is stuck in my cordless Hitachi DS18DFL
There are always 2 different rings to the chuck grip surface, you always hold the back one and turn the front one counter clockwise.
You should be able to do this by hand.
But if it is really tight for some reason, you could use a channel lock pliers or even a pipe wrench if you had to, but both might leave some marks.
Posted on Feb 27, 2011
  • 18 Answers
SOURCE: drill
the chuck should be in two sections. hold the bottom section and twist the top section to the left to undo.
Posted on Sep 19, 2008
  • 74 Answers
SOURCE: Keyless Chick will not Release - Hitachi DS18DMR
It's best not to use the drill power and your hand to try and release. Or tighten for that matter.
Set the drill down, and try using both hands on the clutch.
If that don't work, try using vise-grips or channel locks.
If that don't work, whip out of the WD-40 and let soak and then try again.
Posted on Feb 10, 2009
  • 277 Answers
SOURCE: Any tips on how to remove the chuck from a Hitachi
most are screwed on
Posted on Jun 21, 2010
  • 90 Answers
SOURCE: i need a new chuck for a hitachick cordless drill
tool parts direct or replacement parts. those are two best.
Posted on Aug 30, 2010
I have a Milwaukee M18 cordless drill with a bit broken off inside and the chuck won't open.
Put your drill into reverse, and hold the chuck. With luck, that will loosen the chuck and the broken bit will fall out.
Jul 17, 2015 | Milwaukee 2610-20 18V Cordless M18 High...
How to insert bit for Black and Decker 3/8 Variable Speed Reversing Drill.
Most new cordless drills don't have a key(keyless chuck). Put the drill in reverse and hold tight to the chuck barrel, pull trigger and the chuck will open. Opposite to close/tighten Best I can do with info provided
Apr 15, 2015 | Speed Drills
I have just purchased a Makita 8391DWPETK 18V Cordless Combi Drill - how do i actually put a drill bit in? Do I need to take off the plastic ring?
The large black part of the chuck should turn left and right to extend (close) and retract (open) the three chuck teeth that hold the bit in place. Turn the chuck to open it far enough to get your bit fully in the chuck then turn it closed to hold the bit in. When the teeth make contact turn the chuck a bit further to get it tight enough that the bit won't slip. When you get used to it, sometimes it's easier to hold the chuck lightly and turn it by lightly squeezing the trigger to turn the chuck with the drill motor.
Feb 25, 2012 | Makita Drills
Black & Decker Cordless drill 9.6V Model PS3350
Sounds like something may be binding. Try applying some very light (sewing machine) oil to the chuck and other parts, and working it in. Perhaps, over time, it will loosen up.
Sep 14, 2017 | Tools & Hardware - Others
Black & Decker cordless drill 9.6V chuck will not come off shaft
If it won't close the only other option you have is to break the outer collar and use a chisel to hit on the exposed jaws inside the chuck. I have detailed instructions in the tip section on how to remove a chuck from these drills. Let me know if you need more assistance.
Jan 31, 2012 | Black & Decker Drills
I borrowed a die hard 19.2 volt cordless drill from a friend, but I can't figure out how to change out the bit! Can you help me?! Thanks!
Hi Mary,
Welcome to fixya!
This drill has a keyless chuck. To remove the bit, just turn the chuck to the right (looking from the handle to the front) to open the jaws. To put in another bit, tighten the chuck to the left to close. You have to use both hands. You will see where the ridged portion of the chuck is in two sections. Hold on to the back section with your left hand to keep it from turning while you turn the front section with your right hand.
A lot of the time I just push the button to put the drill in reverse, hold on the front section of the chuck and turn it on. It will loosen by itself. Then when you put the new bit in, put it in forward and hold on to the chuck and press the switch. The bit will be in nice and tight.
Good luck, Mary.
Please place a vote when you accept this solution.
Thanks,
Handie Andie
Aug 15, 2011 | Craftsman 192 volt DieHard Cordless...
Drill chuck stok in the thigt possition cant get the bit out ; cant make de chuck to open or close
Sometimes this happens when you have a drill bit that slip. Take a pair of channel lock pliers, and try and turn the chuck counter clockwise. Do it sharply so the drill doesn't turn. IF that still doesn't work put the drill in reverse and try the channel locks again
Jul 05, 2010 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
How to unlock the chuck
this how to get a chuck off a drill.look inside the chuck for a screw. it will be a left handed screw.once you get the screw out put the chuck in a vice . you will need to squeeze it very tight. then put the drill in reverse and pull the trigger.if i wont come off you will need to hit the chuck with a hammer while you are holding the trigger. if you have a bit stuck in the chuck and cant get it out put the chuck in the vice and hit it very hard with a hammer until the chuck falls apart.i work on drills every day ,this is the only way we have found that works
May 30, 2009 | Milwaukee 0612-20 14.4v Cordless Drill Kit...
Makita 12Volt cordless drill driver - chuck is frozen
Ok glad I have helped and that WD-40 has solved the sticking chuck...
Please rate this solution on FixYa!
Mar 24, 2009 | Makita 3/8" Dr. 14.4V Cordless Drill Kit
Hitachi DS18DL 18V Liion Cordless Drill Driver Logo
1,100 people viewed this question
Top Hitachi Drills Experts
John Trevino
Are you a Hitachi Drill Expert? Answer questions, earn points and help others
