Question about Hotpoint Aquarius WMA56 Front Load Washer
Our Hotpoint Aquarius WML520 will not pump out water or get past the wash stage when on the Baby Cycle or any cycle with the Super Wash. The appliance is only a week old.
    Brigadier General:
  • 6,277 Answers
Try this first but if it isn't a blocked filter, which is a bit unusual at only a week old, get back to the supplier- I presume it is under guarantee?
Having re-read your problem I suppose a week isn't much when washing baby garments which are likely to be a bit 'fluffy' ;-0)
Sorry but I do not know your particular machine BUT I would suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters. The motor is unable to drain all of the water in the allotted time.
Here are my complete, general pre-typed guidance notes for checking filters and motors ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Mar 13, 2011
Aquarius WML520 Cold Wash not working
Washing machines start a cold wash cycle with hot water to dissolve detergent.
May 19, 2016 | Washing Machines
Washeing machine not heating up
It sounds like either the cable's have rusted off, fallen off the water heater element. Or the Water heater element has failed.
Watch this link to get the repairs done
How to replace washing machine element on Hotpoint washer
Mar 04, 2014 | Hotpoint Washing Machines
My hotpoint aquarius will not spin
If the inlet cycle proceeds and then activated the wash after the water level is detected then the program cycle is intact. However if the second spin does not start, you need to check if there is voltage to the motor at this time , if not the control panel memory to the processor can be corrupt or the IC damaged.
Jul 03, 2012 | Hotpoint WML520 Washing Machine
Hotpoint Aquarius WMA56 wont drain properly water leaking onto floor
pump is working water is only a trickle coming out so wont final spin
Nov 07, 2007 | Hotpoint Aquarius WMA56 Front Load Washer
Problem with our washer/dryer
sump/filter is blocked instead of flushing on dry cycle is filling as not pumping well. ring hotpoint to reorder pts cheaper then anyone
Jan 06, 2007 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Aquarius WMA56 Front Load Washer Logo
370 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
