Question about Whirlpool Refrigerators
My freezers fan was blocked with food now it has lost its cool. Removed food from vent, fan cont to run, but frig still warm.
  • Whirlpool Master
  • 43,501 Answers
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Mar 13, 2011
Need schematic Amana frig SQD25VW-P1314202WW
Hello Ron Carlson
Page 6 of 6...
Pretty straight forward refrigerator!
Although I agree with the first answer you got from Todd Marr...a lot of available volunteers here have been around a lot of blocks...
Can call out the Whirlpool & Frigidaire units you share parts with... and how to very cheaply you can
test various parts to bring you to your very quick victory...
I'm just saying, ice-maker, defrost issues, warm refrigerator side... Fast frost build-up... puddles?
If you'll pardon the pun ...
FROST FREE REFIGERATOR/FREEZERS are pretty cool...!
Amana SCD25TBW Technical Information Wiring Diagram
Apr 06, 2016 | Amana Refrigerators
Evaporator fan is running but refrigerator side still not cool
Possibly blocked vent between fridge and freezer. could be ice or frozen food that has gotten in vent, blocking air flow. Also you say the fan is running but can you SEE IT? I have had occasion where the MOTOR is running but the fan blade is loose on the motor shaft. especially top freezer models.
Feb 01, 2014 | Whirlpool Refrigerators
Frig or freeser not cold
If it is your freezer, check to make sure that the air vents inside the freezer are not blocked by food. Putting too much food in an blocking the air vents will prevent the freezer from freezing. Air needs to circulate inside the freezer for it to work properly. This can also cause excess freezer ice collecting on freezer or in foods. Dust and lint will collect under and behind a frig. Pull the frig out from the wall, unplug it. Check for lint under and on the back of it. If it has accumulated some, vacuum it all off and plug it back in and wait a while to see if it gets cold. The fan pulls lint and dust under the frig and it stops the cooling system. If this doesn't work, it may need the freon (can't spell it correctly) stuff replaced. If these don't work, you need to call
Feb 15, 2013 | Microwave Ovens
I have a kitchenaid, KSRS25RSMS01, refrigerator and the freezer is fine and the fridge is not cooling. I have checked the evaporator and it has normal frost, and the fan is turning fine, but the air coming...
Your frig has the classic symptoms of a frig with a clogged or blocked vent between the
freezer section and the refrigerated section. This clog can occur due to (a) stuff in the freezer blocking the vent, or (b) ice in the freezer blocking the vent, or (c) both of the above.
The way a refrigerator works is it cools the freezer, and the warmest air in the freezer is vented out
to the refrigerator section. If this vent is blocked (and everything else is working), your refrigerator
just became a eye-level small freezer atop a well-insulated section of dangerously warm food.
May 13, 2011 | Refrigerators
My Frigidaire refrigerator is at 60 degrees Fahrenheit and will not cool down
There are a few possibilities. First, Is the freezer portion working okay? If yes, then the problem is blocked air flow from the freezer to the frig. If no, then the cooling fan could be bad or the thermostat could be bad. First check for temperature in Freezer section, should be about 4-8 degrees no more. If it is cold, then locate the cooling fan behind the back of the frig and see if it is moving or listen for movement. If it is moving then rearrange the food in your freezer compartment.and frig compartment away from the vents. If it is not moving, then the thermocouple could be bad. compressor problems and freon leaks are not that common unless the frig has been moved alot. The cooling fan or thermocouple or overstuffed freezer compartment are the usual suspects in 90 % of cooling problems. cooling fans and thermocouples can be cleaned by using canned compressed air to remove dust which will sometimes cause a failure. The parts are inexpensive but labor is about $80. Start with the freezer because all of the cooling for the whole unit starts in the freezer.
Dec 18, 2010 | Frigidaire Refrigerators
Freezer cools but refrigerator doesnt
you can have one of several different problems,,
1.light bulb door switch may be stuck on
2.door seal could be bad or warped
3.food could be to warm when first put in or to much food in frig for air circulation
4.the vent at the back coming from the deep freeze is blocked
Aug 01, 2010 | Dometic Refrigerators
Fridge/freezer. Freezer works great but fridge is
Air from the freezer is blown into the fridge by a fan, some new type frigs have electronic controls that open and close a vent to frig. the older ones have two vents in the frig from the freezer and when covered with frost or ice the air will not reach the frig. check for ice or just defrost the freezer if there is ice or frost, also check for food or plastic over vents in freezer. Also check that the freezer fan is running as these sometimes become blocked or defective motor.
Mar 07, 2010 | Electrolux Freezers
Refrigerator part not cooling, freezer is fine Amana TXI18JW (top freezer model) I noticed in the last week or so that my refrigerator was slowly starting to warm up, so I started to turn the dial up on...
There is a vent that is connected from the freezer down to the fridge right where the fan is,make sure nothing is blocking it.
Hope this helped.Let me know by rating me or
for more help go to live chat.Thanks
Len West
Feb 27, 2009 | Amana ARSE66MB Side by Side Refrigerator
Freezer and refrigerator run but is not cold
Andeb, couple of things you want to check. Is the fan in the freezer section running? Take the lower back panel off and see if the condensor fan is running as well as the compressor. As long as you tilted it only slightly I would think this is a fan or overload relay problem. Check the things I mentioned and post back...Catriver.
Aug 21, 2006 | Kenmore 50522 / 50524 Side by Side...
Refrigerators Logo
69 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
