Question about Zanussi F1045W Front Load Washer
My zanussi f1045w wont drain, have emptied the emergency drain and cleared pump and is still holding water how do i get into pump and check it thourly
  • stephwickham Mar 13, 2011
    Hi John , I put in on empty spin and the motor/fan was spinning alrite...
    Brigadier General:
  • 6,277 Answers
Sorry but I do not know your particular machine but see if these guidance notes help---------->
Here are my complete, general pre-typed guidance notes for checking filters and motors ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Mar 13, 2011
  • 1 more comment
    tanks very much john,
    i put it on full cycle yesterday and it didnt spin properly so i just put on to spin again and it worked ,??? having removed the filter ( and cleaned) i can see the drain motor, i can turn the motor but it is not very free...
  • john_cross Mar 13, 2011
    Hi Steph,
    Motors tend not to be totally free running- bit like fans, with a little resistance. Can you see it working, though, with no water in but on a spin- as in the last paragraph of my notes?
    Cheers,
    John C
    Hi John i turned on and put on to spin with no water and the motot/fan was spinning
Tip
AEG Electrolux Lavamat 50600 is not spinning here are a few work throughs
Download manual
First off that was a link to the online user manual. If this was the first time using the machine did you follow the recommended first time use procedure by following these steps:
Before using your machine for the first time
0 Slightly pull the detergent compartment out of the control panel.
0 Pour about 1 liter of water through the detergent compartment into the washing machine.
When this has been done the ?KO lock can function correctly.
0 Run a wash cycle without laundry (COTTONS 95, with half the amount of washing powder).
This removes any residues from the drum which may have been left during manufacture.
If you have used this prior to the problem occurring try this:
The issues for not spinning are numerous as to what may cause this and it appears to be a lot but most of it is rather simple :
If there is water in the drum you need to follow the pump out procedure and remove water in the drum. Then there may be a "Bend" in the inlet hose. If there is water reaching the drum this is the possible causes and simple to check:
Water is leaking out from under the washing machine.
Fabric softener is not added, compartment for fabric softener is filled with water.
Appliance does not spin, water in the drum.
Washing has not been spun sufficiently, there is water left in the drum.
Door cannot be opened.
The rinse water is cloudy.Possible cause
The inlet hose connection is not tight.
The inlet hose has a leak.
The drain pump cover is not tight.
Washing is caught in the door.
Suction cap in the fabric softener compartment is not correctly fitted or is blocked.
RINSE HOLD selected.
SOAKING program is terminated.
There is a "Bend" in the outlet hose.
Maximum pumping height (drain height 1 m from the position of the machine) is exceeded.
Drain pump is blocked.
The water drainage system is blocked.
The door is locked due to safety reasons
Probably caused by a washing powder with a high silicate content.
Troubleshooting these are the remedies:
Tighten the inlet hose connection.
Check the inlet hose and if necessary replace it.
Tighten cover by turning clockwise.
Abort the program, remove the washing caught in the door, start a new program.
Clean the detergent compartment, fit the suction cap on firmly.
Deselect RINSE HOLD.
Pump out water and set the main wash cycle as desired.
Eliminate the Bend ( it would not allow me to use the proper word here see manual.)
Please contact AEG Service Force Centre, it has a retro- kit available for pump heights above 1 m.
I would definitely try this as it appears to the reset procedure for this machine:
Switch off the machine and pull the plug out of the socket
I would say no less than 20 minutes
but do this while waiting further:
clean the drain pump.
Clean the blockage
Carrying out an emergency emptying
1 Warning! Isolate the washing machine from the main supply before the emergency emptying!
If the washing machine no longer pumps out the water an emergency emptying must be carried out.
Warning! The water, which flows out of the emergency emptying hose can be hot.
First allow the water to cool down before emergency emptying!
0 Put down a flat container to catch the water draining out.
0 Pull down the flap in the left corner of the base strip and remove it.
0 Release the emergency emptying hose from its holder.
0 Pull the emergency emptying hose out a little.
0 Place a container underneath to catch the water.
0 Release the plug of the emergency emptying hose by turning it anti-clockwise and pull it out.
The water will drain out. Depending on the amount of water, it may be necessary to empty the container catching the water several times.
To do this, temporarily close the emergency emptying hose again with the plug. When the water has drained out completely:
0 Push and twist the plug firmly back into the emergency emptying hose.
0 Push the emergency emptying hose back in a little and let it catch onto the holder.
0 Replace the flap in the base plate and close it. When the washing machine is completely empty, the ?KO lock can no longer function correctly. Therefore before the next wash pour in approx 1 liter of water (pour it in through the washing powder compartment)
steps to Clean the drain pump
1 Warning! Switch off the washing machine and pull the plug out of the socket before cleaning the drain pump!
0 First carry out an emergency emptying (see section "Carrying out an emergency emptying").
0 Place a towel on the floor in front of the cover of the drain pump. Surplus water may flow out. 0 Unscrew the cover of the drain pump by twisting it anti-clockwise and pull it out.
0 Remove any foreign bodies which maybe in the pump housing.
0 Check whether the impeller of the pump can be turned. (It is normal forthe pump to turn in steps.) If the impeller cannot be turned at all please contact your local AEG Service Force Center.
0 Replace the cover (insert the ridges on the cover into the guiding slots)and screw on tightly in a clockwise direction.
0 Close the emergency emptying hose, push it in and twist.
0 Close the flap. I sure hope this helps a few people especially the one who I posted this for initially. GOOD Luck! If none of these suggestions work then best to call AEG for servicing, I strongly believe that the Bend in the inlet hose or the drain pump most likely the culprit and or any one of the other issues may well resolve the spin malfunction as well as possibly the main computer may have been goofed due to a slight power surge which unplugging from electric and turning off water for 30 minutes is the basic reset procedure for most electronics ( not all ;but most) while working through these steps should not hurt a thing.
on Dec 26, 2014 | Washing Machines
The water is not out
The pump should be inspected if •
the machine does not empty and/or spin •
the machine makes an unusual noise during draining due to objects such as safety pins, coins etc. blocking the pump. Proceed as follows: •
Disconnect the appliance. •
If necessary wait until the water has cooled down. •
Open the pump door.
Place a container close to the pump to collect any spillage. •
Pull out the emergency emptying hose, place it in the container and remove its cap. •
When no more water comes out, unscrew the pump cover and remove it.
Always keep a rag nearby to dry up spillage of water when removing the cover.
Remove any objects from the pump impeller by rotating it.
Put the cap back on the emergency emptying hose and place the latter back in its seat.
Screw the pump cover fully in. •
Close the pump door.
Oct 21, 2012 | Zanussi ZWF1020 Front Load Washer
Hi the machine wont drain im afraid thanks for your help bernadette
bernadette, sounds like you have a blocked pump.isolate machine from the mains. get as much water out of the machine as possible, get a few towels ready and open the filter at he front of machine. if you look in you will be able to see the pump head, make sure you can turn it with your finger. remove any blockage.
hope this helps you
Feb 16, 2011 | Zanussi F1045W Front Load Washer
Cycle stops and shows error E20. Cylinder hold water and does not drain or complete cycle
E20 is a draining error.
Check the filter.You need to take the filter out, empty it of all lint and replace it. It may have water trapped in already, so get a cloth ready to soak up excess liquid! Also, make sure when you put it back in you have tightened it enough to avoid leaking but not too much that you cannot get it back out.
If still the problem persists then the problem is with the draining pump.The pump is not pumping out the water.Check the pump impeller it may got stuck due to some obstacles.Replace it and this wont come again.
Sep 16, 2010 | Zanussi ZJD1219 Front Load Washer / Dryer
My clothes are coming out smeeling musty
I have a zwf1241w with similar problem. When I disconnected the drain hose that runs from the drum casing to the pump housing there was a lot of collected debris that had prevented the water from draining through properly. You could try clearing this out.
Oct 06, 2009 | Zanussi F1045W Front Load Washer
Zanussi ZWF1437W E23
E23 indicates Drain pump faulty; Wiring faulty; PCB faulty.
The service information also says it should stop with the door open.
Unplug the appliance and manually remove the water via the filter or front drain point if it's fitted.
Drain it into a shallow dish, tighten the filter when you need to stop the water (or plug the hose if draining via a hose) while you empty the container.
Once empty, try the door again.
Take the filter out and clean out any debris in it.
Plug the appliance in and put the machine on a drain programe.
Listen/look at the open filter to check that the drain pump is running.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 27, 2009 | Washing Machines
indicated low water pressure from your external supply or blocked filters in the fill hose. turn water off, remove hose and check filter in end of hose - it is just a bit of gauze. also look into the valve and clean out if needed
Jul 20, 2008 | Zanussi F1045W Front Load Washer
Zanussi wj1054 front load
Check the water level pressure chamber for a partial blockage, this can cause all sorts of problems.
Apr 07, 2008 | Zanussi F1045W Front Load Washer
Zanussi F1045W Front Load Washer Logo
80 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
