Question about Thermador PG364GEBS Stainless Steel Gas Kitchen Range
I WAS COOKING SAUCE ON THE LEFT FRONT BURNER AND IT JUST WENT OUT CANT GET LEFT FRONT OR BACK TO SPARK OR GO ON RIGHT SIDE OK.
2 Suggested Answers
Macmarkus
  • 2605 Answers
SOURCE: I have a 6 burner,
Welcome to FixYa.
Based on the info you've provided in your post, specifically "The left-front burner (extra-low burner) doesn\'t spark and its gas doesn\'t turn on."
...I suspect you've got a faulty potentiometer ( burner switch for Xtra lo burners). Especially since you've stated the other burners are all OK, that pretty much rules out the simmer control and ignition module.
This is what I'm referring to...
Thus if it fails no current flows and the gas coil won't open and the ignitor won't spark.
Replacing the part can be fairly involved as it requires removing the front control panel of the range, you may want to call a pro, If not let me know and I'll try to assist you in any manner I can going forward.
I also have a service manual for most of the professional ranges from Thermador, even if not exactly like yours the operation and disassembly/service will be the same. I could only provide that via email though so you'd need to post an email address, your call.
I'll watch for your post and we can go from there. Thank's for visiting FixYa today. Good luck.
Regards,
Macmarkus :)
Posted on Mar 22, 2011
One burner won't spark when another is aflame. Multi-ignition BlueStar 4-burner range.
I would check that the plates are on correctly. Make sure they are aligned and sitting properly. Sometimes they move while cleaning and give you a bad ground connection for the spark.
Feb 15, 2016 | Kitchen Ranges
Amana Gas Cookertop flame goes out on burner but gas keeps flowing
which burner goes out on you when you use it. the front. the back. the left side. the right side. or all of them
Jan 04, 2013 | Kitchen Ranges
Tappan MGF500PBWH right side won't ignite
Helpful when people chime back in once a solution is achieved.
"bad igniter" above was incorrect terminology. "spark module" would be correct.
Problem was the 3 wires on the spark module. They all look the same, but must be seated correctly onto the proper connection. Failure to do so will result in the issue I first described. Seated all 3 correctly and now all burners (and oven) have spark.
Aug 27, 2009 | Tappan MGF500PBW Gas Kitchen Range
Front left burner doesn't work on our jes9800aab
This is your infinite switch. It just went out and you can replace it very easily. Just give us a call or email us and we'll be sure to get the right switch out to you right away to get you cooking agin soon. We hope to hear back from you real soon. Hope this helps you!
Aug 16, 2009 | Jenn-Air JES9800A Electric Kitchen Range
Top right burner on hotpoint gas range doesn't light
there is a spark ignition in the middle between the front and back burners....one for the left side and one on the right side. When it was cleaned i bet that the spark ignitor was slightly bent towards the front burner...now the gap is too big to fire the rear burner...the ignitor is very similar as the spark made in those push down lighters. so its safe to play around and adjust them as needed to make them work...Go ahead and take it apart and tinker with adjusting it...until you get both front and rear burners running again the way it was before.( peek at the otherside as a reference and try to make it match)
I hope this helps you out a little bit 8-)
Jun 06, 2009 | Hotpoint RGB745 Gas Kitchen Range
GE Spectra - burner pops & blows breaker
Either the burner has gone bad or the limiter on the burner.
Jul 11, 2008 | GE Spectra JBP78 Electric Kitchen Range
It is not a GE but it is a Jenn-air
It's either a bad spark module or switch.
Nov 17, 2007 | GE 36 in. JGP628 Gas Cooktop
Sealed Burner
Ralph, you need to look at the electrodes at the burners. They might be cracked or dirty. It's very hard to tell sometimes when they are cracked. The burner cap itself has to have a good ground and the wires going to the electrode should be on tight. You can eliminate the spark module by switching the right and left side burner wires at the module. Once you do that, if the right side works ok, but now the left doesn't, you can be pretty sure it's the module...Catriver..post back.
Mar 03, 2007 | Maytag MGR4451ADS Stainless Steel Gas...
Thermador PG364GEBS Stainless Steel Gas Kitchen Range Logo
Top Thermador Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Are you a Thermador Kitchen Range Expert? Answer questions, earn points and help others
