Question about DSC Ws4945 Wireless Door Window Contacts 4
Getting a tamper error from DSC WS4945...swapped out transmitter w/known working and tamper/base works fine...replaced batt in troubled transmitter and still get error...is there a reset or is the board toast?
03 Lincoln Navigator - No Door Locks, Auto Lights - Already used process of elimination - missing something - Help!
Simple fix; bring the vehicle to the dealership and let them reprogram the system!
Feb 21, 2017 | Ford Cars & Trucks
How can I find the code number to reset the anti tamper box so as the alarm will work
The code is specific to your device and would ordinarily be known by the person that installed it
Nov 24, 2014 | DSC Home Security
Dcs 5501 trouble light
When checking troubles on DSC, *2 brings up the trouble codes and trouble light will flash after pressing *2
1=Service Required (press 1 to get sub codes)
1=Low Battery
2=Bell Circuit
3=System Trouble
4=System Tamper
5=Module Supervision
6=RF Jam Detected
7=PC5204 Low Battery
8=PC5204 AC Failure
2=Loss of AC Power
3=Telephone Line Fault
4=Failure to communicate
5=Sensor (or Zone) Fault --- Press 5 to identify zone/sensor
6=Sensor (or Zone) Tamper --- Press 6 to identify zone/sensor
7=Sensor (or Zone) Low Battery --- Press 7 to identify zone/sensor
8=Loss of Time & Date
Apr 04, 2014 | DSC Home Security
2001 sentra SE Bogs Down, things I've done:
some have an egr valve thats operated by hot antifreeze which runs through the base of the tbi unit and sometimes these gaskets fail and cause this condition..it also affects the vacuum system too check to se if yours is equiped with these and repost...
Jan 20, 2013 | 2001 Nissan Sentra
I have a dsc power 832, and have replaced the battery, but i can not get it returned to the ready state as it shows " secure system before arming, and memory says -lid tamper", I have checked the plun
Hello Frank,
Great systems... Updatable, configurable...
even repairable... 832 is a "mature" system...
and the codes you get are not particularly helpful
if you don't have the ALARMS mapped.
There should be a map... (don't worry)
"-Lid" most likely is NOT the device you
are working on... Your ALARM condition
is FIRST on the warning list...
If you were given INSTALL notes with your system
you can use those... (instruction at bottom).
A simple area motion detector might also need a battery...
GLASS BREAK, SMOKE, HEAT, WATER... hard wired window devices...
(I'm guessing)... but FOR A FACT any device could
be mounted several ways... but control boxes
(at least in MY DAY had door & panel "TAMPERS")).
You obviously have a control panel
(you are getting system status "remarks)
It has been a long time since I have been around a DSC 832.
They are quite an excellent... and versatile security platform.
Lots of options and opportunities.
FIRST thing you will want to do is to inventory the system
to determine how many and what you are "monitoring..."
DSC PC5010 V2 0 Important Notice Page 4
Do look at this PDF ... (notice).
There are several manuals available
but before anyone can SERIOUSLY help you...
you need to walk the system and find all your devices.
Hope this helps
Jun 19, 2017 | DSC Power Supervision Relay For Smoke And...
Tamper error message when client went to enter a debit card pin number
It is possible that you have lost your pin-pad encryption. This may have created the error on the vx 570. I would be open to talk to you about this problem. call Frank @ 775-338-6634
Jan 12, 2011 | VeriFone VX570 Credit Card Terminal (Dual...
Have a 5 year old DSC Power Series 632 Model PC 1555MX. Trouble Light came on with message #1 Any options available to me other than " Call for Service " ? Would replacing back-up Battery possibly cure...
1=Low Battery
2=Bell Circuit
3=System Trouble
4=System Tamper
6=RF Jam Detected
8=PC5204 AC Failure
2=Loss of AC Power
Aug 09, 2010 | DSC Power Supervision Relay For Smoke And...
MY phone has a problem that says OUT OF RANGE I really don't know how to fix it, do you think you can help me?
If you are getting a out of range error ... that tells me you need to move closer to the base station AND/OR possibly put fresh batteries in the hand piece. Out of range happens when the transmitter transmitts and does not get a response from its mate. There is the possibility that one or the other of the transmitters is not responding aand the trouble is NOT electrically related.
I dont know if this will solve your trouble ...
Oct 18, 2009 | Uniden 5.8GHz Cordless Phone
My HP vs15/vs17/vs19 LCD monitor just stopped coming on. No problems previously, no distortion, perfect and one day it went to sleep and never came back on. We rebooted, checked wiring, etc. Any...
Hello there kittensue.
Here's your geek-steer ...
Based on your trouble description, likeliest to be either the monitor OR the video card:
  • Connect the troubled monitor up to a "known good" PC system.
  • Swap a "known good" video card into the system hooked up to the troubled monitor, or vice-verse.
Deduction will reveal which is in need of repair/replacement.
Good luck, and please do post back ...
  • to let me (and interested others) know how things worked out,
  • to provide clarification or feedback,
  • if you have ANY further questions.
Today's the best day of my life ... and NOW you're part of it!
Via-con-Dios and Godspeed -- Geekinator (aka Craig).
Oct 13, 2009 | HP vs15 15"LCD Flat Panel Monitor
DSC Ws4945 Wireless Door Window Contacts 4 Logo
104 people viewed this question
Top DSC Home Security Experts
Steve
don1956
Level 1 Expert
Tom Chichester
Are you a DSC Home Security Expert? Answer questions, earn points and help others
