Question about Dryers
Need a new globe - Dryers
    President:
  • 2,992 Answers
I'm assuming you need a globe for a ceiling fan, since this is posted under an electric fan heading. Without any brand or model to go on, I can't give you any specific links to fan part sources. But most big-box home improvement places (Lowes, Home Depot) and large hardware stores carry generic replacement globes to fit common-sized light fixtures. The big-box places also can get replacements for the brands they sell if you're looking for an exact replacement. You can also check their websites. Several online sellers of fan parts also offer a range of sizes and styles of replacement globes. You may not be able to find the exact part in all cases, but there is always something available that will fit.
Posted on Mar 13, 2011
I need replacement globe for light kit.
If it is the type with the triangle shaped base there are only two types available direct from Hunter. I replaced the entire light kit on mine when the globes started to fail due to excess heat and the tips of the triangles started to break off causing the globes to fall at random.
Apr 19, 2016 | Hunter Dryers
Do i need a smart globe pen to operate my globe?
To use the SmartGlobe, you will need the SmartPen. It is needed to activate the location-related information for the iOs app or PC software. Replacement pens are available from Oregon Scientific if you purchased the globe used for $70. See http://www.oregonscientific.com/us/en/Kids/SmartGlobe . If you recently purchased a new globe from a store, contact the company using the information here: http://www.oregonscientific.com/us/en/service/contactus .
If you need the manual for your SmartGlobe, see http://www.oregonscientific.com/webapp/wcs/stores/servlet/ManualsView?catalogId=10001&langId=-1&storeId=10151&categoryId=11658 . There are both full manuals and a quick start guide. These are in PDF format.
I hope this helps.
Dec 13, 2014 | Oregon Scientific Smart Globe
How to change a lamp in Toyota Corolla 2012?
The headlight globe usually just twists out of the back of the headlight assembly. When fitting the new globe,use a cloth or glove. Don't touch any part of the globe with bare hands as the oily film will cause the new globe to fail very quickly.
Dec 02, 2014 | 2012 Toyota Corolla L Sedan 1.8L 4-cyl....
Replace park bulb.vt commodore
To replace the front parklight globe on a vt commodore can be a little tricky.
1.turn the lights on to see which 1 is inoperative once you know turn lights off.
2.open bonnet
3.go to side that is inoperative and on the back of the headlight you will see a round large plastic cover turn this to release it.
4.under the headlight globe there will be 2 wires flow these to the park globe socket gently twist and pull it out.
5.once the sockets out and you can see the globe ,pull the globe out of socket.
6.push new globe into socket
7.refit the socket in headlight
8.refit all trims
9.turn lights on make sure new globe is work..
Jan 22, 2014 | Cars & Trucks
Globe access point
APN: Go to MENU, SERVICES, DATA ACCOUNTS, GPRS, create NEW SETTINGS.1. if your globe sim card is not yet activated for inet, then configure it manually.. go to connectivity then go to access points, make a new one and name it Globe inet..then on the APN put this "http.globe.com.ph" without the "
2. then after that, go to internet profiles, make a new profile and name it globe inet.. name it Globe inet. then choose to use a proxy.. then enter this proxy address "203.177.91.131".. and then it the proxy server port, put "80".. then on the access point choose Globe inet..
3. now you need to make another internet profile.. so make a new one. name it "proxy".. then choose to use proxy, and then enter this proxy "195.189.142.132" then on the proxy server port put "80"..then on the access point put Globe inet..
4. ok now your done configuring your globe inet settings,. next step is to go to games and apps, then choose settings, then choose profiles, and add profile.. name the profile "proxy". then on the internet profile choose "proxy" then save it and activate it..
Feb 14, 2012 | LG Cell Phones
Lo beam headlight replacement passenger side
open the bonnet, locate a screw on top of the headlight and undo it, locate two screws between the centre grill and headlight and undo them and locate a screw right behind the headlight assembly and loosen it. Now the whole headlight should come out. It wont come all the way out. By unplugging the electrical plug you can take it out completely. Lift up the lock thats hold the rear headlight cover and that will expose the internals of the headlight and then you can change whatever globe you want. First disconnect the wiring plug from the globe and then release the clip holding the globe and replace the globe and make you sure you dont touch the glass part of the new globe which installing. Touching it will shorten the globes life and there is a chance that it might explode inside and create mess. You need to buy H7 type globe for low beam.
Nov 10, 2010 | 2000 Mercury Cougar
The globe for my casa vieja ceiling fan broke. where can i buy a new one? how do I measure the size to know what I need?
You can find replacement globes at most lighting or building supply stores. The dimention you need is the diameter of the circle that the globe sits into.
Apr 30, 2010 | Casa Vieja Casa Surveyor Ceiling Fan
Need new globes on lights
Go to lowes or home depot as both places carry replacement globes in stock. They can also special order for you. Bring in one of the old globes to be sure you get a perfect fit.
Apr 28, 2009 | Westinghouse Helix 78794 Chrome Finish...
Replace globe
i need a new globe mine broke how can i get one?
Jan 05, 2009 | Hampton Bay 40093 Tripolie Ceiling Fan
Need new pen for globe
Call their Consumer Services at 1-800-701-5327. They will be able to help you order a new one.
Dec 17, 2008 | LeapFrog Leapster Electronic Book:...
Dryers Logo
167 people viewed this question
Top Dryers Experts
