Question about Brother MFC 240C All-In-One InkJet Printer
I get an alert when scanning to my pc that there is not enough memory,.I have loads of memory ...I have rebooted...help, thanks
  • vforgie Mar 13, 2011
    I already have it installed this is a new alert saying there is no memory and that I should delete some files, I have loads of free memory,,,
How to create a reboot disk? and how to reboot?
I you go to file hippo and down load a free program called ccleaner and then run the clean then the registry scan for issues but save the back up file. That should bring you back to good speed. also at file hippo malware bite is free also for a scan for malware which can slow your computer down. Hope this helps.
Mar 09, 2015 | Acer Aspire Computers & Internet
How can i solve this problem, the computer does not load up window?
You need to give more details on your system. What type and how old.
Jul 19, 2014 | Dell Computers & Internet
Emachine EL1852 keep on restarting
Does it load operating system fully before restarting?If it does,run a full scan of the drive with an updated anti-virus.
If not,do a reboot[enslave] of your hard disk from another computer.This is how to:-
Remove the hard disk from your machine.
Disconnect CD/DVD ROM from machine 2 and connect your hard drive.
Start the machine.'You're trying to run Unix' alert comes on, press f1[ save changes].
A disk check operation starts.This repairs the operating system on your hard disk.
After successful loading operating system of machine2,turn it off and remove your drive.
Fix it on your machine and start it.
Hope this helps.Thanks!
Sep 27, 2011 | E-Machines eMachines Desktop PC
I tried to install "Red Alert 2" on my PC. and
Hi, try installing your red alert 2 installer to another computer.If it works your computer might be the problem. Check if you have enough space for the game.Try changing the destination folder. If it does not work your installer might be the problem.
Feb 26, 2011 | West Wood Studios Command and Conquer Red...
Why does HP Media Center PC m7350n freeze and reboot?
There may be a setting in the Recovery setting to tell the computer to reboot while errors happen. You can check whether the fans are working so the processor and everything is cool enough and whether the memory is working fine. There are some tools to test the memory or you can replace them and see. You may also perform a virus scan just in case.
Aug 17, 2010 | HP Pavilion Media Center TV m7350n...
My computer keeps alerting that I don't have enough memory to run Excel 2007 or Word 2007. I just bought more RAM and it still alerts that there isn't enough (upgraded from 2 512's to 2 1 Gb's)! What's...
Hi there i will help you to get this problem fix: first i must tell you that its only a memory problem its not that the memory is bad, it mean that the computer is not recognizing the memory you put in and this can happen if the memory is not fit correctly into the slot, so you should double check to make sure the memory is fit properly in the slot if you still experience the problem then you should ask someone with more ideas to put it in for you , if the problem still exist take the memory back to the store along with the original 1 and let them exchange it for you with similar to those you take out and if the problem still exist there might be a problem with the memory slot
thanks for asking
if my advise is helpful to this problem kindly vote for me
hbristol173
Mar 30, 2010 | Dell Inspiron 6000 Notebook
T3025 won't load os
It Could be faulty memory. Find out what kind of memory you have and see if manufacturer has recommended memory settings for that board.
It could also be a faulty video card.. just replace it. or if u dont have one yet, the integrated graphics chip cud help for now.
Please let us know if that was helpful enough.
Good Luck & Thanks,
Shiv.
Aug 18, 2009 | Computers & Internet
Computer is very slow and not responsive at times. I have also received an alert to stop using Script (?) because this will make the screen onresponsive
You could be facing several problems namely
1. viruses : use an antivirus
2. No enough disk space for the virtual memory; delete some unnessary files from the harddisk
3. You have many programs which load automatically when u start the computer, this are shown on the bottom part of the start bar: stop some of them every time u restart the computer.
4. You have less memory: increase the memory capacity
Aug 14, 2008 | Gateway Computers & Internet
PC keeps on restarting
Power supply can be your issue , when windows boots from CD it a mear dos-mode boot , If it was motherbaord problem it wouldn't boot at all . If you move power supply to test the motherboard issue just make sure it enough power to boot the other motherboard ( some pwer supplies can boot all motherboards )
Jul 31, 2008 | ASUS P5S800-VM Motherboard
Brother MFC 240C All-In-One InkJet Printer Logo
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
