Question about Samsung LN-T4053H 40 in. LCD Television
Samsung LN t4053 H. Clicks on and off, on power up. Sounds like bad caps. How do I get at the caps on the power supply board
  • 718 Answers
Samsung LN-T4053H:
If this set is under warranty you should return it to get it repaired/replaced by the seller. If not then;
This sounds like the power supply board could be failing. The electrolytic capacitors on the board may need to be replaced. It may also be a voltage regulator.
IF YOU KNOW HOW TO WORK WITH ELECTRONICS REPAIR(soldering ) or have a friend with knowledge/skill you can fix it.
>Unplug the set and any cables.
>Remove the back cover. The power connects directly to the power supply board.
>look at the capacitors on the power supply board. If the top of any of them are bulging up then that is the problem.
>You will have to replace ALL the electrolytic capacitors except for perhaps the large one.
>Disconnect and remove the power supply board. Handle by the edges to prevent contaminates and static electricity.
> Use ones with the Low Equivalent Series Resistance ESR rating
> Use ones with the same farad rating
> Use ones with the same or higher voltage rating
> Use ones with high temperature rating
> Install one at a time to prevent mix-up and keep the polarity correct.
> Leave a space between the PC board and the bottom of the capacitors for expansion. They heat up.
> Replace power supply board and reconnect cables..
> Replace back cover.
THIS IS AN INDUSTRY WIDE PROBLEM AFFECTING MANY COMPANIES AND PRODUCTS.
Sources for some good capacitors are www.digikey.com or NTE. Try nteinc.com for a local outlet of NTE products.
You can also search for other sources. Some companies even sell all the capacitors in a kit.
Total price of parts should be < $30.00
Yes you can buy a new power board but if the capacitors have not been replaced they will eventually fail also.
The power supply board looks like;
Posted on Mar 13, 2011
I have a Samsung LN-T5271FX/XAA LCD TV and have replaced the power supply board twice now and it needs it again as the TV clicks for a long time before powering up. At issue is the 10V IF Capacitors on the...
Not sure if this will help, but most caps fail with the in rush of power, over and over. Sounds like they were not made right. You might try a UPS ( uninterrupted Power Supply) this may help you with dirty power from your power company. And with high spikes. Make sure you get one that will handle the TV current draw. As far as upping the CAPs keep the same or slightly high voltage and increase in uf. You might find one that has the same uf and a higher voltage rating that will handle it.
Apr 05, 2017 | Samsung LN-T5271F 52 in. LCD Television
TV DONT STAY ON ONLY CLICKS PAUSE TEN SECONDS THEN CLICKS AGAIN
You may have bad power supply or short circuits in the power supply or backlight inverter board, the power supply (or bad caps) is trying to start but sensing tto much current draw so it shut down and try to start again in a loop.
Please read my guide to understand how LCD TV works.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Aug 13, 2010 | Samsung LN-T4065F Television
My samsung ln-t4671f takes 3 to 10 minutes to turn on. it just clicks,clicks clicks
The power supply board is dying,that the board where the power a/c cord into it.Replaced the power supply board will stable and work as normal again.Tries Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Jul 03, 2010 | Samsung LN-T4671F 46 in. LCD Television
My Samsung LN-t4671F LCD TV clicks for about two
You are having another problem with the power board...there are some capacitors which are easily replaced to cave you the cost of the board. If you are technical,I can guide you further,other wise a reputable shop can fix this very reasonably
Jun 07, 2010 | Samsung LN-T4665F 46 in. LCD Television
I have a Samsung LCD (LN-T5271F) about 2 years old and lately when I turn it on, it clicks on and off several times before it actually stays and the tv comes onI have a Samsung LCD (LN-T5271F) about 2...
Call Samung customer service, they are doing this repair for free. I had the same problem at 11 months, they replaced the power supply board under warranty. At 2 years I had the exact same problem again and this time they replaced 2 - 50 cent capacitors on the power supply board. It took the repair man less than an hour and he had the replacement capacitors on hand. The original board and the replacement board they gave me had capacitors that were faulty. Hopefully these new capacitors will last. I have to say that I was thinking (no more samsung products for me) but I got excellent customer service and they admit that they had a faulty product and they accepted responsibility.
Apr 26, 2010 | Samsung LN-T5271F 52 in. LCD Television
Samsung TV now takes over 30min to come on
There are a number of Capacitors on the IP/Power supply bd and they have gone bad. Replaced them with the proper Capacitance as the old ones are BUT get the 35 volt Caps. Going from 10v to 35v will fix this problem.
Apr 14, 2010 | Samsung LN-T5271F 52 in. LCD Television
Samsung LN-S4051D 40 in. LCD Television will not turn on
Are the red lights still flashing after replacing the caps? Bulging caps usually means the caps are at the end of their life span, but shorted caps may look just fine. Check any caps that you did not replace to see if they are shorted. I bet you still have a bad cap somewhere on the power supply that is shorted.
Mar 05, 2010 | Televison & Video
42 inch samsung lcd tv tv takes forever to come on clicks off and clicks on for about 20 minutes finally comes on then shuts off
I would check the power supply for bad caps they will have a swollen top replace those and that should fix your problem
Jan 28, 2010 | Samsung LN-T4665F 46 in. LCD Television
My Samsung LN-T4665F LCD TV is slow to start.It clicks every 5to10 sec about four on five times before it comes on.
You have bad caps.on the power supply. They are under rated, 10volt insted of 16volt or more. Caps.run about $2-3 each. usualy takes 4-6 of them. Or replace the whole power supply. But you will have the same problem in a couple of years. Best bet is to have the bad caps. replaced with the right voltage rateing,and you will not have to worry about it happening again. New power supply is...
BN44-00168A About $120 used-180new cheeper to repair.
Jan 15, 2010 | Samsung LN-T4665F 46 in. LCD Television
Clicks on and off several times before staying on
The power supply will sense if the set is 'drawing' too much current and switch itself off. This could be the case here. The power supply board may eventually go completely bad.
Feb 23, 2009 | Samsung LN-T4042H 40 in. LCD HDTV
Samsung LN-T4053H 40 in. LCD Television Logo
271 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
