Question about Dryers
I have a GE dryer that started making really load screatching noises. I took it apart and replaced the motor and the belt. It ran for a few minutes and started making the same noise. I am not sure what else could be causing the noise.
  • 118 Answers
The idler pulley bearing might be the trouble. If the dryer has an idler pulley that tensions the belt, check this bearing in the idler pulley. If it is a bush type, just oiling it might be all that is required. Also make sure there isnt any piece of wire etc in the drum bearing. You might have to take the drum out to check this. However the most likely cause of a SCREACHING noise is the idler.
Posted on Mar 13, 2011
GE DPXH46GA6CC gas dryer makes large humming noise in heat cycles and burning smell
Two things are likely going on here,1- something is dragging down your motor check for a twist in the belt, idler pulley bad, belt installed wrong or wrong belt. Also check your front drum felt and glides if the felt is bunched up that will drag down the motor. Now the smell you probably have some felt or lint in the burner clean it carefully you do not want to damage your igniter.
Aug 04, 2013 | GE Dryers
I have a GE electric Dryer Model EED20001 WWD Making a repetitive scraping noise. Sounds like its coming from the motor area. Took the dryer apart and the motor seems to be turning fine belt is good. Any...
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like drum rollers have flat spots on them or in need of lubrication, or maybe your drum belt has slipped off of the idler arm pulley.
If you have a front loading machine,
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer.Also remove the screws holding the lint filter in place.
Be REAL CAREFUL not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the dryer. This will expose the drum and belt. Remove the drum and belt and this will expose the drum rollers, idler arm pulley and motor.
Now is a good time to check the belt to see if it has slipped off of the idler arm pulley and also to check the belt condition for wear.
Be sure to note the route of the belt, this will come in handy when you go to reinstall the belt.
Check your drum rollers for flat spots or wear, if they have flat spots or wear on them replace them.
If the drum rollers don't have flat spots or wear on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem.
Good Luck,
I hope this helps
Please do not forget to rate me,
Thank You
Aug 09, 2010 | GE Dryers
Dryer will not dry with full load, keeps kicking off
if your belt is slipping change the belt also check the felt and rollers make sure thay are turning freely the next step after that is change the motor thank you for useing fixya please rate me
Mar 18, 2009 | Whirlpool LGR7646E Dryer
Dryer comes on for a few minutes, makes horrible sound and goes off. now won't start at all. Frigidaire stackable
It could be the belt was partially broken, and as it came apart causing the dryer to no longer start,,, it made the noise your talking about. If the dryer still heats up, and you can hear the motor running,,, these would all be signs toward a broken belt.
Mar 13, 2009 | Frigidaire FEX831CS Top Load Stacked...
Ge dpsr475gwoaa gas dryer.
rear bearing is dried up needs to be taken apart and re-greased with high temp grease
Feb 17, 2009 | GE DBSR453EBWW Electric Dryer
Dryer drum making thumping noise
My dryer just started making this noise. So I opened the back up to try to figure out what it might be, and when I opened it I saw something. It was part of the belt that drives the dryer. There are grooves vulcanized to the belt, and a small section of grooves or cogs I think is what they are called had come apart from the belt and what laying there on the floor of the dryer. But I ran it and timed the thumps in my head to get it to stop right on the "thump". Sure enough there was a small 1/2'' appx. of belt Cog missing, so the "thump" came from when the belt came around to the motor and the pulley hit a divit in the belt, "thump". So needless to say I need to replace the belt soon before it breaks completely. I figure that it looks like someone may benefit from knowing what the noise is. Now its off to find the proper belt and look up how to change those things...Good luck to those reading this.
jiujitsujd@aol.com
Jan 16, 2009 | LG DLG3788W Gas Dryer
Dryer motor has trouble starting
sounds like you are having or go to have a motor problem repl/ motor
Dec 29, 2008 | Dryers
Thermal overload?
The windings in the motor have been overheated to the point that the insulation is burnt off. I call this pre installed smoke. If it is let out replace the motor. There should be a local appliance parts dealer that can help you get the motor.
Mar 26, 2008 | Kenmore 82722 Electric Portable Dryer
Dryers Logo
93 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
