User Manual for a Goodmans LD3270D TV - Televison & Video
My goodmans tv LD3270D has changed language when I was trying to change the audio for my tv, it is now in german, and my sky volume is now in german too, I need to get it back to english.
language preferences are usually very early in the set up screens, if you can't toggle it back to English using google translate to help, look for a reset to defaults, default language is usually English, but then you will have to set all your other preferences again: https://translate.google.co.uk/
Jan 01, 2016 | Goodmans Televison & Video
Hi i have a goodmans LD3270D tv and it has a very loud buzzing noise nothing else i have apicture but the noise is the only thing have. Can you help please?
Fault in the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit.Contact any service technician.If you wish to get some details; check the site linked here.Surf the site with patience.Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Mar 02, 2015 | Goodmans Televison & Video
GOODMANS LD3765D 37" HD READY ITS SOUNDS TINNY
Hello
Enter in this link, where you can download the user manual for your Goodmans Tv. It will give you all details about its settings..
http://safemanuals.com/brand-user-guide-instructions-owner-manual/GOODMANS
Nov 14, 2011 | Televison & Video
Model ld3270d Indicator light rapid flashing blue/red t.v will not turn on
hi there.you will need some capacitors replacing on the power supply board.they arent expensive at pennies each...yuor local repair shop may do the job if you take them the board along...
or easy to do yourself with a little knowledge of electronics and a reasonble soldering iron!!
regards,steve
Oct 22, 2010 | Goodmans GTVL32W27HDF 32 in. LCD TV
My standby light flashes red/blue? and no pic,its only weeks old
I would take it back and get a replacement, it is a lemon, it will void warranty if you open it up. It can be defctive power supply module.
Dec 09, 2009 | Goodmans GTVL32W27HDF 32 in. LCD TV
Can't find the manual for my Goodmans TV. I need to re-tune can you help? It is model number LV1570FVT.
Goodmans doesn't list that TV. Please review this link and check the model number again.
http://www.goodmans.co.uk/productlist.aspx?cid=BLCDTV&language=en-GB
Here are all available user guides for Goocman TVs:
http://www.goodmans.co.uk/supportcategory.aspx?cid=UGTV&pcid=UserGuides&language=en-GB
If you don't see your TV model, select one that is "close" and see if the manual helps you re-tune your TV. They probably all re-tune the same way.
Sep 30, 2009 | Televison & Video
Televison & Video Logo
297 people viewed this question
Top Televison & Video Experts
Electro Med Services...
