Question about GE Refrigerators
Motor fan running but not cooling - GE Refrigerators
  • GE Master
  • 43,501 Answers
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Mar 13, 2011
How do I fix cooling fans that run when car is off
Replace the fan relays. The Radiator Cooling Fan Motor Relay is located: Under hood, driver side, front side of strut tower, mounted in relay panel
Application:
High speed The Radiator Cooling Fan Motor Relay is located: Under hood, driver side, front side of strut tower, mounted in relay panel
Application:
Low speed,here's a new part.
http://www.autozone.com/cooling-heating-and-climate-control/relay-radiator-cooling-fan-motor/duralast-relay-radiator-cooling-fan-motor/plymouth/voyager-2wd/1996/6-cylinders-3-3-0l-mfi/412240_0_0
Sep 22, 2015 | 1996 Plymouth Voyager
Where is the fuse for motor fan in uplander 2006?
there is 2 fuses that you have to check
one will be in the big fuse assembly in the engine bay, the other probably in the fuse assembly in the cab
If they prove ok then it is possible that the coolant temperature SENSOR is faulty and needs replacing
don't confuse it with the temperature sender which operates the temp gauge.
Aug 10, 2015 | 2006 Chevrolet Uplander
Why my 2006 nissan maxima cooling fan wont come on
Defective fan thermostat, fan motor, or the engine is cool enough that the fan need not run.
Bypass the switch and place 12 voltes directly to fan motor to see if it will run.
Oct 21, 2014 | Air Cool Dryers
Cooling fans Will not come on car overheats well
you can disconnect the electrical plug on the rad cooling fan/s and run jumper wires directly to the motor contacts from the battery if it does not run replace the cooling fan motor. if the motor runs then check for a bad cooling fan relay. this is were its best to have a scan tool as you can see the coolant temp of the engine and the computer commanding the cooling fans to come on. if the computer commands the fans to come on then you have eliminated 2/3 of the system working.
Sep 19, 2014 | Cars & Trucks
Cooling fan inop 1995 mustang gt 5.o
you can check the cooling fan by disconnecting the plug at the motor and run jumper wires from the battery directly to the fan motor it should run if its working if it doesn`t run then the cooling fan motor needs replacing. if it does run then check the plug for a bad connection. other things can cause this like the cooling fan relay, the coolant sensor that sends a signal for the computer to turn on the cooling fan by sending a signal to the relay.
Sep 08, 2014 | Cars & Trucks
Cooling fan does not run?
At the main fuse and relay box, check the 30A EGI INJ fuse. If OK, the main relay closes to apply power to the cooling fan relay. Next, check the 30A FAN 1 and FAN 2 fuses.If OK, power is being applied to the fan control module. The PCM processes engine coolant temperature sensor input and sends a signal to the fan control module which, in turn, causes the cooling fan motor to operate. Fan failure could be caused by malfunction of the cooling fan relay, the fan control module, the engine coolant temperature sensor, the cooling fan motor itself, or the PCM
Oct 06, 2012 | 2005 Mazda MPV
94 oldsmobile cutlass supreme oevrhaeting only one fan comes on
CHECK THE OTHER COOLING FAN FUSE AND RELAY.IF BOTH GOOD HOT WIRE COOLING FAN TO SEE IF FAN RUNS IF NOT YOU HAVE A BAD FAN MOTOR NEED TO REPLACE FAN MOTOR.IF FAN RUNS WHEN YOU HOT WIRE IT.FAN MOTOR WIRE CONNECTORS HAS A SHORT.
Aug 27, 2011 | 1994 Oldsmobile Cutlass Supreme
Cooling fan not running as temp. heats up.
most time coolant temperature sensor faulty.but check cooling fan fuse and relay.then hot wire the cooling fan if fan runs.problem in the fan wiring or pcm.if every thing else okay.if cooling fan dont run when hot wired the cooling fan need replacing fan motor has internal open winding circuit.
Apr 15, 2011 | 1995 Buick Skylark
Side-by-side refrigerator - freezer is working just fine, but the refrigerator is not cooling.
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Dec 27, 2010 | GE GSL25JFPBS Side by Side Refrigerator
Refrigerator is not cooling
Dirty condenser, condenser fan or evaporator fan motor are not running, Ice build up on evaporator and restricted the air flow. If compressor, condenser fan and evaporator fan motor are running but not cooling, then either compressor or sealed system problem.
Mar 07, 2010 | Refrigerators
Refrigerators Logo
48 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
