Question about Acer Aspire One Netbook 8.9" Notebook
I have an Acer Netbook. I have Windows XP. When I click "Start" then "My Computer", my webcam icon does not appear. Help ?
    Sergeant:
    Novelist:
  • 185 Answers
Are you using an internal or external webcam?
If you are using internal Hold FN and associated F button (diagram of a camera on it)
For example FN and F7 together and release togerther.
If external. Have you inserted the driver disk into your disc drive and installed the compatiable software?
If all of above doesnt work. Try a different usb connection port.
If all else fails and the hardware is on your notebook. Please follow these steps.
Click start. My computer. select top harddrive (1st in list)
At the top left of the my computer box there is a search bar.
Type your camera make / model into the search bar and it will bring up your webcam software (if you installed it)
Search through the folders until you find setup.exe / install.exe or something very simillar and click to install.
Hope this helps and please rate.
Posted on Mar 13, 2011
I have a problem with my webcam in that it won't work. I get a message saying "webcam currently in use with another program". I have no applications running at all and have restored all...
Click on start and then run. Tyoe devmgmt.msc in the run dialog ox and press enter. You will get open the device manager window. Select the device driver of your webcam and uninstall it. Restart your computer and install the device driver again. Hope it helps.
Jul 19, 2011 | Acer Aspire One D250 (99802378332) Netbook
Acer orbicam 3690-2710 stop working after install. Initially worked upon setup, but when I try to reopen after closing it a message appears saying: "A webcam was not found or is not working...
Access Camera Assistant Software:
a. On the taskbar double-click the Camera Assistant Software icon , or from the Windows® Start menu, point to All Programs, Camera Assistant Software, and then click Camera Assistant Software. The Camera Assistant Toolbar location briefly displays on the desktop.
b. On the Camera Assistant Toolbar, click the Start Camera button and click on the icons on the software.
If the the above steps are not working, then follow the below steps:
You can reinstall the WebCam drivers from the Acer recovery management, to do so:
Start Menu> All Programs> Acer erecovery management> Restore> Restore Application & Drivers> Contents> Select Acer Crystal Eye and install it
OR
Got to http://gd.panam.acer.com/home/
Select the computer model
Select Operating System
Click Drivers
Select Camera (Orbicam) and download it.
Once downloaded install it on your computer.
If still facing the issue, then you may need to perform full system recovery, to do so please follow the steps mentioned below
You can restore the computer back to factory default,to do so, follow the below steps: Turn OFF the computer, now as soon as you hit the power button, keep on holding "Alt" key
& keep on tapping "F10" key, i.e Alt+f10, it will open the recovery console, select full factory restore and follow onscreen instruction.
NOTE: This will erase all the datas on the computer
Dec 06, 2010 | Acer Aspire 3690-2710 Notebook
My webcam does not work on my acer netbook. How
Check whether the Webcam is listed in Device manager Go to Start right click on computer click on manage , click on Device manager , In Device manager under imaging devices see whether there is webcam listed , if not install the webcam driver from www.support.acer.com, Check whether the Webcam Application is listed in All programs, if not Re-Install the Software from Acer Recovery manager Access Recovery Manager by going to All Programs ->Acer-> Acer Recovery manager -> Restore-> Restore Drivers and Applications , Select webcam software to Install
Jul 13, 2010 | Acer Aspire One Netbook 8.9" Notebook
I have an Advent 4490 Netbook (Windows XP). The internal webcam has stopped working. I select Fn-F12 and a message says the webcam is switched on, but it is not working. No light either next to webcam. Can...
Hi! try to check if the driver for the webcam is installed on the machine, go to start->right click on my computer->properties->hardware->device manager. Check if the driver is there, uninstall and reinstall the driver by following the steps below:
Drivers
1.Click Start > My Computer.
2.Double-click the icon for XP (C:) drive.
3.You may see a message saying "These files are hidden". Click the Show the contents of this folder option.
4.Double-click the Applications folder.
5.Double-click the Drivers folder.
6.Inside this folder you will see folders for each device you can re-install, for example, Audio.
7.Double-click the folder and look for an icon called Setup.exe or Install.exe.
8.Double-click the icon and follow any on-screen instructions to re-install the driver.
9.After installing drivers it is recommended that you restart your computer.
***you have to run a program or a software (yahoo messenger, etc) for you to test if the webcam if it is working or not***
hope this helps...
May 22, 2010 | Computers & Internet
Just bought a new acer notebook and know how to activate the webc
If you are using Windows XP, open My Computer and look for the camera icon.
If found double click on it to activate the webcam
Thanks
Feb 25, 2010 | Acer Aspire One AOA150-1068 Netbook
HOW DO I USE MY WEBCAM ON MY ACER ASPIRE ONE NETBOOK?
Certain models have are shipped with Acer Crystal Eye Webcam software which enables webcam at boot. I do nto know if it is installed in your netbook.
To test the webcam running Windows XP, follow the steps below:
  1. Go to Start, All Programs, then Windows Movie Maker.
  2. On the left side, click the link for Capture from video device.
  3. Select Next throughout the set up, making any file name changes or setting changes if desired.
  4. On the Capture Video screen, click on the Start Capture button
  5. You will see the video on the right with a time count up
  6. When you are done click the Finish button
  7. Click the play button on the video clip, or drag the clip to the Storyboard below.
If your webcam is not detected or if you are running Windows Vista click the link below.
The wesite has live chat support in case you get stuck
http://netbooks-us.custhelp.com/app/answers/detail/a_id/86/related/1/kw/webcam/r_id/166
Jan 13, 2010 | Acer Aspire One AOD150-1920 Netbook
I can't find camera settings for Acer Aspire One netbook.
It has no configurable setting other than Color Management and you should be able to find it by clicking on the "Start" buttonf and selecting "My Computer" icon and right-click on the Webcam icon and selecting Properties. The webcam Icon should be under the "scanners and Cameras" category.
If you have any problems with the webcam, you can try the following.
First of all, if your AspireOne has linux OS installed, then you can try to use the included Recovery CD to reinstall the drivers.
If your unit has WinXP, then you can download the drivers and installation software at: http://rapidshare.com/files/279643660/AcerAspireOne-Webcam.rar . Acer uses more than one manufacturer for this unit webcam and software for both is in that file.
The webcam should calibrate itself so if there is something wrong with it in Windows XP, what you want to do is as follows:
1. Press the Start button.
2. Right-click on the MyComputer icon and left-click on properties.
3.Select the hardware tag on the pop-up screen.
4. Click on the Device Manager button. A new box should pop-up.
5. Under Imaging Devices you should see "Acer Crystal Eye Webcam", if you don't see it, then download and install the software mentioned above. If you see it, right-click on it and unistall it.
6. Close all open windows and install the software mentioned above.
It is hard to know which webcam is in every unit without the serial number but if you run both installation software you should be able to fix your problem regardless.
Hope this helps.
Sep 13, 2009 | Acer Aspire 4730-4947 Notebook
Acer Netbook a0751h - Webcam problems
Download Yahoo Messenger and use it with the camera, that's what I use on mine.
Jun 28, 2009 | Computers & Internet
Acer crystal eye not found
1. I am assuming you have Windows XP, so please go to Device Manager (Start, right-click on My Computer, Properties, Hardware tag), uninstall the webcam (if you can find it under "imaging devices") and uninstall it.
2. Run software installation you can download from: http://rapidshare.com/files/279643660/AcerAspireOne-Webcam.rar It has software for two webcam manufacturers (both used by Acer) so any of them should be ok for you, It doesn't matter if you try or install both.
3. Go to support.acer.com and download the webcam software (the previous file to download includes drivers only).
This should fix your problem.
Jan 19, 2009 | Acer Aspire One Netbook 8.9" Notebook
Acer Aspire One Netbook 8.9" Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
