Sometimes you need to go for a lesser tension as soon as you move up in thread thickness. A jeans thread is often nylon and already has tension in the way it's wrapped. Try using a low tension and a straight line seam (don't use a zigzag pattern or wave).
Also, try practicing on a piece of scrap material first- make sure it is the same thickness/consistency as the jean material you want to work on. Do a few forward and then backward lines; this will make sure the problem isn't in the initial wind of the bobbin itself, and this usually gets the extra slack out of the bobbin.
