Question about Hardware & Accessories
This is an overflow level issue. There is an overflow outlet in the air blower manifold which appears to be draining too much water out of my spa. This problem is new this year. The spa has been in operation for several years already without issue. I need to know what causes this problem and how I can fix it.
  • 3 more comments
  • egraeber Mar 19, 2011
    I don't have make or model info for the spa, however the air blower seems like a pretty standard setup per other documentation I have seen. There must be someone out there who has encountered this problem before. Please advise.
    The check valve is on the air side of the loop. The overflow is at the top of the air blower manifold pipe. It is about 6 inches higher than the level it drains to. I can't figure out how that happens, but I can't see how the check valve would be involved. Please explain.
  • egraeber Mar 20, 2011
    Actually, a friend and I were looking at it yesterday and we concluded that the water level was at exactly the same level as the lowest open nipple on the blower manifold. There are 4 open nipples--i.e. nothing connected to them--at the top of the manifold on one side of it. From the look of it, about the bottom 3 of them shouldn't be open for the water level to be correct. There aren't any pipes hanging around in there that look like they came loose from the nipples, though, so I don't quite see how it used to work at all unless there was some kind of plug for the bottom 3 holes. I sure can't find anything in there that looks like it might have come off of them...
    Have you ever seen this particular issue before? I have had this spa for probably 20+ years and it only just started having this issue. I can't find any material laying under or around the area that looks like it used to block off those holes...
    That will be my next step. Actually, everything on the spa is working quite well except for this one issue. Thanks for the feedback, though.
  • 43,501 Answers
There is a one way check valve in there... that goes bad and allows the water out....you will need to replace the check valve...finding the correct valve could be a problem if you have no make and model numbers to go off of...
The best thing would be to get it out and compare it with others at a store somewhere... hopefully you can match it up with something... it will mean draining the Spa down to get it out...
heatman101
Posted on Mar 19, 2011
  • 2 more comments
  • D. Floyd Kolb
    D. Floyd Kolb Mar 20, 2011
    My thought was that if the water somehow reaches that level that it could then siphon the water....
    But other then that it would have me baffled also...
    Is there anyway that you can tell what pipe the water is running out of??? and then trace it back....
    I assume that there is no possibility of the drain or anything else leaking...
  • D. Floyd Kolb
    Is it possible that the holes were plugged with the foam insulation or had some type of other plug on the back of them???
    At any rate it seems as though you will need to get them plugged off, so that you can keep the Spa full of water...
  • D. Floyd Kolb
    Actually no... that's why it seems as though something just disintegrated after being twenty years old...that was my thinking with the foam....there are not many spas that even last twenty years...
    would be very interesting if I could look at it though... that's one thing I hate about troubleshooting in this way...
    I assume that the blower is still blowing air out??? there are no hoses that could have disintegrated??? if so where would they have went???
    This is really a weird one....but strange things do happen...I would try to find a cap or plug to block them off with...
  • D. Floyd Kolb
    That really should not be too hard to fix....thanks for the 4T rating and glad I could help you work through it!!
  • 8,197 Answers
Sorry we can not help you fix the problem with out the make and model #. I suggest that you call the manufacture to help you with the problem. They have a 800 # google it
Posted on Mar 16, 2011
Can the pool overflow from rain?
A pool will over flow in the rain, the pool pump is only for circulating water not for draining overflow , you can go to a local pool supply and buy a pump to hook to a garden hose and drain it partially, be aware that the pump runs on electric power and you want to be careful not to drain the pool below the skimmer level or you will end up replacing the pool pump motor
Dec 11, 2014 | Jandy Pool & Spa
How to deflate and store
DRAINING THE SPA:
1. Unplug power pack from electrical receptacle before draining spa.
2. Put the rubber plug into the outlet in the inner wall of the spa.
3. Open the outlet in the outer wall of the spa. Screw one end of inflation hose into it.
4. Remove the rubber plug from the outlet in the inner wall of the spa.This will allow water to flow out of the spa. 5.When water is completely drained, press BUBBLE and run for 2-3 minutes to drain the water in the air pipeline. 6.When drainage is finished, remove the inflation hose and replace cap on outside of spa. Store rubber plug for future use.
SPA STORAGE
Make sure all water is drained from the spa and control box.This is essential to extend the life of the spa.We recommend the use of a wet/dry vacuum to blow out or suck up water from the spa pipes and pump lines. Remove the filter cartridge. It is recommended you store the spa in its original package in a warm, dry place.
Note: Plastic becomes brittle and susceptible to breakage when exposed to subzero temperatures. Freezing can severely damage the spa. Improper winterization of your spa may void your warranty.
http://img1.wfrcdn.com/docresources/17478/11/119999.pdf
Aug 13, 2014 | Therapure Four Person Inflatable Round Hot...
Amana furnace model amv9 has water dripping from the exhaust outlet. the exhaust doesnt seem to be clogged and the overflow for water to run into doesnt seem to be clogged. water is makign its way int
You did not say if you have a dehumidifier or air conditioner installed on this unit. If those are not installed on it then the only place moisture could be coming from is down the exhaust connection for the flue. If one or both of those items are installed then the issue is the drain trays might have debris built up that you cannot see.
Mar 23, 2014 | Heating & Cooling
I have a pool with a built in spa and I need to Isolate the spa from the rest of the pool. So I can heat it and not the whole pool. I don't know how to add pics so I will describe the best I can. I have 2...
the actuator at the intake of the pump divides spa intake and the pool intakesmake sure switch on actuator is on 1 or 2 if in pool mode the off should be at spa intake the out inpool postition the off should be to the spa outlet
Feb 18, 2011 | Jandy Pool & Spa
Change thermostat
Hi, you have to follow the instruction below to remove and replace the thermostat....
Removal
  • Disconnect the negative battery terminal with a socket wrench. Always use a socket wrench or close-ended wrench on the battery connector so you don't ruin the head of the bolt.
  • Drain antifreeze from the cooling system. The simplest way to do this is to have the vehicle on jack stands. Open the radiator cap to relieve pressure -- make sure the engine is cool before you do this. Use a bucket or pan to catch coolant under the radiator. Open the radiator drain on the bottom of the radiator with pliers or by hand. The 3.1L engine has an air bleed valve on the throttle body which you should open two turns.
  • Remove the drain plugs located on the underside of the block just above the oil pan and let the coolant drain into your pan or bucket. Close all the drain plugs.
  • Unbolt the the water outlet from the thermostat, if your Cutlass has a four-cylinder engine. All other models have the water outlet on the intake manifold. Remove the outlet and the thermostat. If your Cutlass has cruise control, remove the vacuum modulator bracket from the thermostat housing.
Installation
  • Use the scraper tool to clean the surfaces where the thermostat and engine block meet. Apply a bead of RTV in the water outlet groove.
  • Put your new thermostat in place on the housing. Make sure the side with the spring goes towards the engine. Tighten the thermostat bolts with the torque wrench to the specifications provided. Remember that tightening specifications for the mounting bolts vary between parts manufacturers. If your engine has an air bleed valve near the throttle body, close that too.
  • Check that you have closed and tightened the radiator drain and the two drain plugs near the oil pan. Pour the coolant back into the radiator, adding extra coolant if necessary to fill to the base of the radiator neck. Fill the radiator overflow tank to the "FILL" mark with coolant.
  • Leave the radiator cap off, start and idle the engine. The coolant level visible in the radiator should drop slightly. Fill it back up to the base of the radiator neck. Put the radiator cap back on and make sure the arrow on the cap points towards the overflow tank. With the engine still idling, squeeze the outlet hose with your hand. The outlet hose is the big one that connects to the top of the radiator. If you feel it getting hot, this tells you the thermostat has opened up and is functioning properly.
  • Turn off the engine. Check for leaks on hose fittings and around the drains. Check that the hoses all appear sound and that none are leaking or cracked.
Dec 06, 2010 | 1996 Oldsmobile Cutlass Ciera
Where to locate the thermostat on an 03 pontiac grand am?
Not sure which engine you have so please pick the appropriate engine:
2.2L Engine
  1. If equipped with an automatic transaxle, remove the exhaust manifold, as outlined in this section.
  2. Drain the cooling system.
  3. Remove the thermostat housing to water pump feed pipe bolts.
  4. Remove the thermostat housing to water pump feed pipe.
Thermostat mounting-2.2L engine
3.1L Engines
  1. Disconnect the negative battery cable.
  2. Drain the cooling system to a level below the thermostat housing.
  3. Remove the air cleaner assembly.
  4. Disconnect the surge tank line from the thermostat housing.
  5. Remove thermostat housing-to-intake manifold attaching bolt and nut, then remove the housing.
  6. Remove the thermostat.
3.4L Engine
  1. Drain the cooling system.
  2. Remove the air cleaner.
  3. Remove exhaust crossover pipe.
  4. Disconnect the surge tank line fitting from the coolant outlet.
  5. Remove the thermostat housing to intake manifold bolts.
  6. Remove the thermostat housing outlet and thermostat
  7. Clean the mating surfaces.
Nov 01, 2010 | 2003 Pontiac Grand Am
Water is leaking from inlet/outlet area. is that a heat exchanger problem?
If there is a water leak in between the pool/spa plumbing and the inlet/outlet manifold, it just needs a new gasket if it is a plastic manifold, and if it is a cast iron manifold, the 2" threads for inlet and outlet need to be unthreaded, then coated with a pipe sealant (non-teflon) then rethreaded.
If this leak is in between the outer and inner inlet/outlet manifold peices, then a new gasket is needed. The part number for that gasket is: 006713f.
If the leak is coming from inside the cabinet and leaking down the interior or exterior, it could be a heat exchanger issue.
The most likely event is that the o-ring that seals the header manifold is worn and needs to be replaced.
This would take about 30 minutes of labor and an o-ring.
Please vote positively if this has helped.
Nov 01, 2010 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
How to change the thermostat
Alero, Grand Am 1999-2005 Thermostat - Removal & Installation 2.2L Engine
    Fig. Thermostat mounting-2.2L engine
  5. Remove the thermostat.
To install:
  1. Install the thermostat.
  2. Install the thermostat housing to water pump feed pipe.
  3. Install the thermostat housing to water pump feed pipe bolt. Tighten the thermostat housing to water pump feed pipe bolt to 89 inch lbs. (10 Nm).
  4. If equipped with an automatic transaxle, install the exhaust manifold, as outlined in this section.
  5. Fill the cooling system.
3.1L Engines
To install:
  1. Clean all gasket surfaces completely.
  2. Insert the thermostat in the intake manifold.
  3. Attach the thermostat housing to the intake manifold.
  4. Install the mounting bolt and nut. Tighten to 18 ft. lbs. (25 Nm).
  5. Install the air cleaner assembly.
  6. Connect the surge tank line to thermostat housing.
  7. Refill the cooling system.
  8. Connect the negative battery cable, remove the radiator cap, then start the engine. Allow the engine to run with radiator cap removed, until the upper radiator hose becomes hot (thermostat open). With the engine idling, add coolant to the radiator until the level is up to the bottom of the filler neck.
  9. Install the radiator cap, making sure the arrows line up with the overflow tube.
3.4L Engine
To install:
  1. Install the thermostat and housing outlet.
  2. Install the thermostat housing bolts. Tighten the thermostat housing bolts to 18 ft. lbs. (25 Nm).
  3. Install exhaust crossover pipe.
  4. Connect the surge tank line fitting to the coolant outlet. Tighten the fittings to 15 ft. lbs. (21 Nm).
  5. Install the air cleaner.
  6. Fill the cooling system.
  7. Inspect the system for leaks.
Hope this help (remember comment and rated this).
Apr 04, 2010 | 1999 Oldsmobile Alero
Our blower randomly turns on
The spa side switch probably has a short and will need to be replaced. If the rubber coated buttons are cracked then moisture has gotten inside and corroded the contacts.
Sep 30, 2009 | Polaris Qt Quiet Spa Blower 220v 2 Hp
Fridge water "overflow" ?
It is supposed to drain to a plastic tray under the fridge. There is usually not a lot of water that drips down there... and the water usually will evaporate before overflowing.
If the water is draining on the inside of the fridge, then the drain tube on the rear of the fridge might be clogged. You should be able to remove the tube fairly easily, and then see if you can blow air into it to see if its clogged. Sometimes it just gets clogged with dirt and dust. If the tube is clogged, and you cannot blow air through it, then see if you can get a small somewhat flexible wire and push it through the tube.
Hopefully it will make it all the way to the other side.
Hope this helps.
Good luck.
Mac =)
Feb 11, 2008 | Refrigerators
Hardware & Accessories Logo
143 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
