I need manuals for hooking up my fisher stereo system model ca 871 amp fm 871 tuner cr-w890 tape deck eq 867 eq can not find manuals
    Brigadier General:
  • 8,546 Answers
I can't even find a reliable picture of the amp but it's not rocket science.
The Tuner output goes to, say, FM or Aux on the am, anything BUT Phono, which is ONLY for a turntable.
The EQ output goes to the first available Tape In; Input Comes from the same Tape Out. Select that tape function to engage it in line with any source and the downstream electronics (second tape, tone, volume, speakers).
The tape deck output goes to Tape In; Input comes from Tape Out. If there is not a second tape loop on the amp, nest the Tape Deck into the EQ's Tape loop. They always have at least one to replace the one they use. Select THAT tape function to engage it in line with any source and the downstream electronics.
Posted on Mar 13, 2011
Fisher equalizer-2322
"Rec" is considered a send (output from Fisher to an external device) and PB (playback) would be an input from external devices in to the Fisher. Remember all outs feed in's, and all in's feed outs...output from Fisher (Rec) IN to EQ. Out of EQ in to Fisher (PB). A quick test is to simply jumper the out to the in and check Fisher for proper operation. Also, in these modes you MUST press the "Tape Monitor" button for the audio signal to be routed through this In/Out loop.
Dec 12, 2013 | Fisher Vintage Ca-880 Integrated Amp...
Fisher equalizer 2322
"Rec" is a send (output from Fisher to an external device) and PB (playback) is a input from external devices in to the Fisher. Remember all outs feed in's, and all in's feed outs...output from Fisher (Rec) IN to EQ. Out of EQ in to Fisher (PB). A quick test is to simply jumper the out to the in and check Fisher for proper operation. Also, in these modes you MUST press the "Tape Monitor" button for the audio signal to be routed through this In/Out loop.
I need to know how I can hook up my Teac EQA 5 equalizer to my Sansui AUD 9 power amp.. I lost the manual to the E/Q
It is very easy, you don't need a manual for this. The EQ line in and Line out get hooked into the record out and Tape in of one of the tape loops on the Sansui amp. Record outs go to EQ in and the EQ out goes to tape play.
Oct 10, 2013 | Sony TC WE435 Stereo Dual Cassette Deck...
Hooking up EQ to RECIEVER for a TECHNICS MODEL SH-8017
You'll need 4 connections total. On my integrated amp, I connected the four connections to all Line In and Line Out ports. And the other ends into the tape 2/EXTRA ports respectively.
Jul 19, 2013 | Panasonic Technics Stereo Graphic...
I have a Fisher stereo.The amp is a ca871 the eq is a ca871 the casset deck is a crw870. How do I connect these components up.
The amp has tape rc out and pb. The eq has line in, line out, tape rec out, tape pb. The casset deck has line in,line out.
Ok, hook the amps RC OUT to the eq's LINE IN.
amps RC Pb to the eq's LINE OUT.
The tape's LINE OUT to the eqs TAPE PB
the tapes LINE IN to the EQs TAPE REC OUT.
on the eq, there should be a button to toggle between tape and source.
let me know if that works.
Jul 01, 2011 | Audio Players & Recorders
I have a Fisher CA-871 and all componets, I misplaced the hookup digram for the amp to all componets. The problem i have is only the EQ-871 to CR-W870 and also to tape deck. I hope you can help Thank...
if you visit the link below you will find hookup diagram for your need..
Take care and please Remember to rate/vote and give me 4 Thumbs Up
for Helping out the Community :)
Hope this helps!
How do I wire my equalizer into my audio system?
http://installationsplus.com/docrepair/hookup.html
Jun 23, 2011 | Audio Players & Recorders
Aai have the following AKAI Audio Stereo System and no Idea how to connect them. Please help Akai Model AP-D210 turntable Akai model CS-F14 Stereo cassette deck Akai model AT-K110 Fm Am Tuner Akai...
In general, outs to ins.
If nothing else, get the manuals for the preamp and the EQ. You'll probably have to pay for them.
Google it.
Akai PR-A04 preamplifier << This is the control center and where everything comes together.
Akai AP-D210 turntable (ONLY to jacks that say "PHONO"
Akai EA-G40 Stereo Graphic Equalizer (in the Tape 1 Out/In set)
Akai CS-F14 Stereo cassette deck (in the Tape Out/In set of the EQUALIZER) *
Akai AT-K110 Fm Am Tuner (to the Tuner inputs)
Akai DT-100 Audio Tuner (to the Aux inputs)
Akai PA-W04 Amplfier (to the amp outputs)
* This will allow you to Equalize the Tape on the Record or the Playback side.
Read some audio magazines or websites. Get to understand Tape Monitor Loops.
Don't use excessive EQ.
Mar 17, 2011 | Akai Audio Players & Recorders
Do you have any manuals as to how to hook this up to a sony str av-710 receiver?
Well, since the EQ-0100 is a stereo analog component you will be able to use it only for stereo analog source material. Of course, once it's inside the av-710, you can manipulate the sound digitally for soundfield and such.
Basically, hook it in like a tape deck, say, in Tape Deck 2's circuit. Then, whenever you want to use it inline with stereo source material just select Tape 2 Monitor and it will be placed inline. Be advised, any digital programming you want to hear will probably be muted if you monitor any tape deck. That's pretty much normal.
You can slave an analog deck off the EQ as it has a Tape Record/Monitor loops of its own and facilities for making the EQ be on the Record OR the Playack side of it.
Normally, the receiver's internal volume, eq or effects controls will not affect the analog loop out to the EQ-100 or attached decks, BUT, this receiver sends processed effects out to Tape Deck 2, if you should desire to record them (page 29 of the manual). Other REC Out jacks pass conventional UNprocessed sound.
I couldn't find the exact instructions for this model but they all work about the same.
Nov 16, 2009 | AudioSource EQ-100 Home Equalizer
I HAVE A OLDER KENWOOD STACK HOME STEREO SYSTEM WITH OUT MANUALS OR REMOTES AND NEED TO KNOW HOW TO HOOK ALL THE COMPONENTS TOGETHER. KC-206 STEREO CONTROL AMP KT-76 TUNER KX-96W CASSETTE DECK KM-106...
start with the tuner, hook up the equalizer to the tuner, then on the rear of the equilizer hook up all the peripherals except the amps which will go to the tuner outputs and all will feed thru the tuner to the amps and out to the speakers
Oct 23, 2009 | Audio Players & Recorders
Having a hard time connecting various audio components
Yes, it is a little tricky...
1) CD Changer (output) -> CD input on Amp
this is tricky... this will allow you to record to your tape deck, and control the sound via the EQ:
2) Tape Deck (tape out / recout) -> TAPE PLAYBACK on EQ
3) Tape RecOut on EQ -> Tape 1 Playback on Amp
4) Amp Tape 1 RecOut -> Tape Deck Playback / Input / RecIn
in essence, your creating a loop starting from the tape deck, going to the eq, then to the amp, then back to the tape deck to record.
Your EQ has another set of LINE IN and LINE OUT - use the second Tape 2 on the amp to create another loop. This will
allow you to control the EQ for any of the other sources.
5) LINE IN on EQ -> Tape 2 RecOut
6) Tape 2 Playback on Amp -> LINE OUT on EQ
5) Radio Tuner (output) -> Tuner input on Amp
6) DVD/VCR Combo Output -> AV/AUX on Amp
7) PC Computer... you don't have room for this. You can either use the PHONO input, and you'll have to purchase a Line Level Phono Converter
or, get a Y cable and split the signal and share with some other source.
Hope this helps.
- OPTiC
www.djproaudio.com
www.repairny.com
Dec 13, 2008 | Technics SH-GE90 Home Equalizer
533 people viewed this question
 Grubhead
Grubhead
