Question about Hotpoint Washing Machines
Hotpoint ultima WT940. F11 fault. What is this?
    Brigadier General:
  • 6,277 Answers
Sorry but I do not have the list of fault codes for your particular machine but F11 on most of the 'Hotpoint' variants state 'drain pump'. I would suggest as a first step that you clean the drain motor lint tray/filter. At the same time it is possible to check that the pump is not jammed and also to check that it does work.
Here are my complete, general pre-typed guidance notes for checking the filter and motor operation ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Mar 13, 2011
Hotpoint ultima wt940 washing machine
Either you dont have a high enough amperage breaker or the motor is going bad
Dec 10, 2013 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint wt940
the door is not locking , possibly caused by the interlock itself or motor brushes worn ( most likely if machine is a few years old at least ) could also be no power to lock via control board .
Jan 23, 2013 | Hotpoint Ultima WF860 Front Load Washer
Have an hotpoint ultima wt940 an error code of f05 came up.how can i fix it?
  • F05 - Pressure switch jammed on full - Check pump for blockages.
  • I would recommend you pull out your machine and check the drain pipe and pump hope this helps.
Jan 22, 2011 | Hotpoint Ultima WF860 Front Load Washer
How to remove the top from a hotpoint WT940? 2 Rear screws already removed.
you need to give a sharp blow to the front of the lid towards the rear.. there are keyholed lugs holding it down in place... use you hand not a hammer...lol.. Thanks
Dec 18, 2009 | Hotpoint Ultima WF860 Front Load Washer
My hotpont tumbledryer keeps flashing up f11 its a hotpoint ultima ctd85 pls help
Fault code F11 means that the pump is not working,check the pump connections and the pump itself.
Please leave feedback.
Thanks.
Nov 12, 2009 | Hotpoint Dryers
Error F01
i have the same problem the machine gets part way through a cycle and then stops and Displays F1.
Oct 03, 2009 | Hotpoint Ultima WF860 Front Load Washer
Daughter has ultima wt940 error f-01 comes up any ideas
This refers to motor error, check motor wire connections & brushes. If these are ok it is its a pcb fault which requires replacing & programming.
Feb 19, 2009 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint ultima wt741
f11 keeps flashing door won't open
Sep 01, 2008 | Hotpoint Ultima WF860 Front Load Washer
Washing Machines Logo
150 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
