Question about Toshiba Computers & Internet
How do you change what applications open with the Dual Mode shortcut keys on the Toshiba Satellite I've already set applications to the shortcuts but I don't know how to remove them or change them.
  • 4 Answers
Go to start mean and go program and see the them go and unintall the program
Posted on Aug 01, 2008
Toshiba Satellite l300 1ap windows 7
Restore Toshiba to Out of the Box Condition
If your model Toshiba laptop has a Restore partition on the hard drive then follow these steps to restore your Toshiba to the Out of the Box condition.
1. Press and hold the 0 (zero) key and at the same time, tap the power button once to switch on
your notebook.
2. When the machine Starts beeping; release the 0 key.
3. When prompted by the warning screen; select Yes to continue with the system recovery.
4. Select Recovery of Factory Default Software; click Next.
5. Select Recover to out-of-box state. 6. Click Next again.
7. Click Next to Start recovery.
8. Restart the Toshiba laptop when there restoration process finishes running. Follow the prompts that appear on the screen to set up the laptop's date, time and language settings.
Oct 15, 2012 | Toshiba Satellite Pro L300 (L300-EZ1502)...
Howdo I change the appearance of shortcuts on my toshiba satellite
right click the shortcut click properties whenthe box opens click the shortcut tab and there you go all of your options are right there.
Oct 01, 2012 | Toshiba Toahiba Satellite A60 A65 Series...
Nokia 3120 Classi Supportive File Noting to Display
Pada program jika dipilih muncul tulisan "Supportive file. Nothing to display."
Untuk nokia 3120 classic, bisa dicoba alternative ini:
-> Pastikan progam yang hendak dipakai sudah diklik "options" atau bisa diatur dulu "application access"! (Supaya program dapat muncul)
-> a. Pilih "menu-settings-display-active standby-active standby mode (on)
lalu pada posisi standby pada shortcut bar pilih "options-select shortcuts-application list-silahkan pilih programya (ditandai)
pilihannya:
done-done-(save change? Dan pilih "yes"
Lalu pada posisi standbay pada shortcut bar, dipilih program2 yang sudah dipilih
b. Cara yang ke 2 bisa memanfaatkan tombol shortcuts:
"Menu-settings-display-my shortcuts-left selection key atau right selection key atau navigation key-application list-pilih programnya
Pada posisi standby, silahkan dipilih pilihan tombol shorcut yang sudah diatur
*Semoga bermanfaat
Jan 28, 2012 | Nokia 3120 Classic Cell Phone
How do I enable a compaq laptop's keys
Compaq Presario computers provide users with a row of function keys for added keyboard functionality. Function keys can serve a dual purpose as well.
Function keys are located at the top of Compaq Presario keyboards.
By learning how function keys work on a Compaq Presario you can take advantage of time saving keyboard shortcuts.Purpose
Use function keys to access menus, save changes and create shortcut keys.
Various applications, including Microsoft Office, allow you to select a function key as a shortcut key for running specific tasks. These settings are usually found under the Tools, Settings or File menu.
Each Compaq Presario computer has twelve function keys.
The most common used keys are "F2," "F8," "F10" and "F12."
The first three are used mainly to access and use the Compaq BIOS. "F12" is used to access a set of run from options during the boot process.
How to Access
Access function keys on a Compaq Presario by pressing any of the keys on the top row of the keyboard. Access the key's dual purpose by first pressing the "Fn" key located on the bottom row of keys.
Use function keys as shortcut keys by pressing them anytime while in the desired application. Remember, you must set them as shortcut keys first.
Note that some programs may already have certain function keys set as shortcuts.
Open menus and view the shortcut keys beside each menu item before setting your own shortcuts.
Dual Uses Each function key has a dual use. Press "Fn" plus the desired function key for the key's other use.
Below each function number is a small picture within a square or rectangle.
This dictates the dual use. "F1" opens help and support. "F2" serves as a printer shortcut.
Open your homepage by pressing "F3."
If you use dual monitors, switch between monitors by using "F4." "F5" puts your computer in stand-by mode.
Quickly lock your computer by pressing "F6." "F7" and "F8" adjust the screen's contrast.
Play and pause your music in Windows Media Player or other default media player by using "F9."
Press "F10" to stop playing media. Skip ahead or rewind media by using "F11" and "F12."
Other "Fn" Keys
In addition to function keys, the "Fn" key is also provides other keys with a dual use.
Any key with a small square on the key has a dual purpose such as the "scroll," "insert" and "delete" buttons.
Since laptop keyboards have no number pads, certain keys serve as the number pad by pressing the "Fn" key.
Jan 08, 2012 | Compaq Computers & Internet
I was wondering if anyone knows how to make the toshiba satellite c650 display the sound volume when i use the fn + 3 or fn + 4 buttons.
One way of doing this in Windows Xp is create a shortcut from control panel into desktop. After putting the shortcut icon on the desktop, Rigth-Click on the Icon Select Properties. Click on to Shortcut keys and Press desired shortcut keys.
Sep 10, 2011 | Toshiba Computers & Internet
How do I turn off safe mode on Mozilla
Want to turn off Safe mode option on your Mozilla Firefox? Then follow this simple steps:
  1. Open Mozilla Firefox
  2. At the top of it (Firefox window), click on the Firefox button (in you have Windows Xp, click on File menu) and then click Exit.
  3. Start Firefox as you normally would.
  4. If Firefox keeps starting in Safe Mode see Firefox is stuck in Safe Mode.
If your Mozilla Browser is stuck on safe mode better to the steps here: Click here
May 16, 2011 | RCA VR702HF VCR
I am the new user, Kindly support me with out charging users guides on how to use ms word easily with short cut keys
Open up Word, click on Help >> MS Office Word Help and a whole bunch of online solutions will appear on the right side. Have fun.
For example:
About shortcut keys
You can quickly accomplish tasks you perform frequently by using shortcut keys - one or more keys you press on the keyboard to complete a task.
For example, pressing CTRL+B changes the selected text to bold, just as clicking Bold on the Formatting toolbar (toolbar: A bar with buttons and options that you use to carry out commands. To display a toolbar, press ALT and then SHIFT+F10.) or selecting Bold in the Font dialog box (Format menu) changes the selected text to bold.
Printing a list of shortcut keys
If you frequently refer to the Help topics that list shortcut keys, you may find it helpful to keep a printed copy of those topics. In Help, locate the topic you want, and then click Print .
You can also run a macro (macro: An action or a set of actions that you can use to automate tasks. Macros are recorded in the Visual Basic for Applications programming language.) that creates a list of the current shortcut key assignments, and then print the list.
On the Tools menu, point to Macro, and then click Macros.
In the Macros in box, click Word commands.
In the Macro name box, click ListCommands.
Click Run.
In the List Commands dialog box, click Current menu and keyboard settings.
Click OK.
On the File menu, click Print.
Customizing shortcut keys
You can customize shortcut keys in Microsoft Word by assigning shortcut keys to commands that do not already have them or by removing shortcut keys you don't want. If you don't like the changes you make, you can return to the default shortcut key settings at any time.
Using shortcut keys with different keyboard layouts or Word as your e-mail editor
Shortcut keys mentioned in the Help topics, menus, and dialog boxes refer to the U.S. keyboard layout. Keys on other layouts may not correspond exactly to the keys on a U.S. keyboard. If the language of the keyboard layout you are using doesn't match the language you set for Microsoft Word or Word Help, you may have to make adjustments when using shortcut keys or change your keyboard layout.
If you are using Word as your e-mail editor, some of the shortcut keys listed may not be available or may produce different results.
Dec 31, 2010 | Audio Players & Recorders
Need Model specific touchpad drivers *EDIT*
Hey there, not sure if you tried this or not but this is the hardware setup for your laptop
seth
http://cdgenp01.csd.toshiba.com/content/support/downloads/util_hw_setup_25547A.exe
Jun 27, 2009 | Toshiba Satellite P105-S9722 Notebook
The (HP Descjet F2200 series ) is working ,just
There are settings that you frequently use for printing, you might want to make them the
default print settings so they are already set when you open the Print dialog box from
within your software application.
To change the default print settings
1. In the HP Solution Center, click Settings, point to Print Settings, and then click
Printer Settings.
2. Make changes to the print settings, and click OK.
To create a printing shortcut
1. On the File menu in your software application, click Print.
2. Make sure the product is the selected printer.
3. Click the button that opens the Properties dialog box.
Depending on your software application, this button might be called Properties,
Options, Printer Setup, Printer, or Preferences.
4. Click the Printing Shortcuts tab.
5. In the Printing Shortcuts list, click a printing shortcut.
The print settings for the selected printing shortcut are displayed.
6. Change the print settings to those you want in the new printing shortcut.
7. Click Save as and type a name for the new printing shortcut, and then click Save.
The printing shortcut is added to the list.
If you don't have a copy of the manual click on the link below and it has many more printing (how to) instructions in chapter 7 page 34
http://h10032.www1.hp.com/ctg/Manual/c01438223.pdf
May 16, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Computers & Internet Logo
41 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
