Question about Universal Kreepy Krauly In-Ground Pool Cleaner
I need a skirt for my Kreepy Krauly in ground pool. What is the part nr etc???
  • 640 Answers
The flapper portion of this automatic pool cleaner is called a flapper or pleated seal. I believe that this is part number K12896.
Posted on Mar 23, 2011
  • philipkress Aug 25, 2011
    PRICE AND AVAIABILITY OF A REPLACEMENT NEW PLEATED SEAL
  • Jessica  Harwell
    Jessica Harwell Aug 25, 2011
    They usually range from $40-$80 depending on where you get them. You can google Kreepy Krauly K12896 and it will give you a list of prices and vendors.
Kreepy krauly not cleaning whole pool
If the pool hose has been used for a long time it becomes set in a particular position. Twist the hose at least at leasr 90 degrees so that the hose is set in a different configuration and the Kreepy krauly will go to a different part of the pool.
Feb 27, 2012 | Universal Kreepy Krauly In-Ground Pool...
MY POOL CLEANER SUCKS (LITERALLY) BUT DOES NOT MAKE THAT "CLICKING SOUND" AND DOES NOT MOVE. HAS IT SOMETHING TO DO WITH THE MOVEABLE PART. THERE ARE NO LEAVES IN THE PART ABOVE THE SKIRT AND...
Check your filter and pump basket for debris, also. Triple check the flaps. Debris is often the culprit with these pool cleaners when they malfunction. Check your return line water flow and make sure that it doesn't need to be adjusted.
Jan 18, 2011 | Universal Kreepy Krauly In-Ground Pool...
Kreepy crawly keeps stopping but nothing is blocked
With Kreepy Krauly pool cleaners, it is usually something blocked so you have taken the perfect first step in finding your problem. You will also want ensure that the main drain and all suction lines are closed, except for the line to which the Kreepy Krauly is attached. Also, if this is a new purchase, it could be that your pump and filter system are too small to properly propel the cleaner.
Aug 13, 2010 | Universal Kreepy Krauly In-Ground Pool...
Kreepy Krauly In-Ground Pool Cleaner: my creepy crawler wont hammer...
This usually happens when there is a small stick jambing in the bottom of the openning in the Kreepy Krauly where it sucks in the water and rubbish. It is the rubber tube that has a ****, usually something is jambed in the **** to prevent it from thumping.
May 16, 2010 | Universal Kreepy Krauly In-Ground Pool...
Our kreepy krauly will not stay suctioned to the bottom of the pool. What can we do?
Check for air leaks in your hoses, your pump or in the plumbing system. Also check for clogs in your pump impeller if you have any problems with your basket. Good luck.
Apr 24, 2010 | Universal Kreepy Krauly In-Ground Pool...
My kreepy Krauly will start up and within 5 stops working.
If it is a year old, replace the flapper valve. Also check your water flow and make sure it is adequate. These units are subject to wear on the foot and flapper and these should be changed each season
Mar 25, 2010 | Universal Kreepy Krauly In-Ground Pool...
Hi my kreepy krauly wont stay flat on the bottom of the pool???
Do you have any hose weights fitted to the kreepy hose? If you do,take it off and see if it makes a difference.Is this happening while the kreepy is operating?
Nov 21, 2009 | Universal Kreepy Krauly In-Ground Pool...
Need operational manual
the manual is available at this web add, thanks be sure to leave a good rating.....
http://www.novem.com.mx/mkreepy.pdf
May 12, 2009 | Pentair Kreepy Krauly Suction Side...
Universal Kreepy Krauly  In-Ground Pool Cleaner Logo
292 people viewed this question
Top Universal Pool & Spa Experts
Bill Jordan
Are you an Universal Pool and Spa Expert? Answer questions, earn points and help others
