Question about Panasonic NNSD297SR 1200 Watts Microwave Oven
Cannot change/ set timer or clock. knob is not responding but is flashing blue.
How to reset time
To set the clock, press
"Clock"
once
or
"Timer/Clock"
twice
(depending
on your keypad)
The colon symbol (:) will flash.
Enter time of day.
The time appears
in the window; the colon continues
to flash.
Press
"Clock"
or
"Timer/Clock"
again - colon stops flashing; time of
day is set !
Nov 16, 2015 | Panasonic Microwave Ovens
Why isn't the display responding?
The interdace that converts pushes into signals may have died, you may need a new front panel...they may be available...had to change 2 on our old toshiba
Jul 15, 2015 | GE Microwave Ovens
Clock will not set time
Most microwaves just need to have the clock button pressed 1 time. Then you enter the time. Next some want to to pick am or pm. Then press clock again to set. Sometime last step is the start button instead of clock.
Mar 02, 2015 | Kenmore Elite White 1.5 Cu. Ft. Convection...
On the r559y sharp microwave,how do i set the clockl
press,timer/clock ,colon will flash ,enter correct time{i.e. 12:34},press clock/timer again,,all set,if it doesnt work,return it to where you bought it,
Jan 01, 2015 | Sharp Microwave Ovens
How can I to set clock on Sanyo Microwave EM-C678
1. Open door
2. Press clock/Kitchen Timer button the display will show "0:00" with the hour"0" flashing.
3. Enter the correct hour by turning the potary dial. Enter 1-12
4. Press clock/Kitchen Timer button the display will show "0:00" with the minutes "00" flashing.
5. Enter the correct minutes by turning the potary dial. Enter 00-59
6. Press clock/Kitchen Timer. The colon will remain flashing.
7. Close the door.
Sep 03, 2014 | Microwave Ovens
Have Kenwood MW786 microwave and have misplaced the instructions to operate. I can't remember how to set the clock.
First of all, thank you very much for choosing FIXYA today for your online technical support needs.
I'm Joe, and I will be more than happy to assist you with your service request.
To set the time on your Kenwood microwave oven just press the CLOCK / TIMER button once.
Then enter the current time using the number buttons on the keypad.
Then press the CLOCK / TIMER button again to confirm the time you just set.
Please COMMENT back here to this page if you have any details to add, have any questions, have difficulty accessing the links, or just require further general assistance and I will respond as soon as I see it.
If you were satisfied with the service provided, could you please take a moment to leave a 5 STAR rating. Your feedback is very important and I truly appreciate your consideration.
BEFORE leaving a rating OTHER THAN 5 STARS or a negative TESTIMONIAL, please contact me and I will immediately clear up any concerns or answer any additional questions that you might have until you are completely satisfied with the service provided. The FixYa rating system is a very important component of the Marketplace, and unfortunately once you post a rating or a testimonial to a solution, it cannot be changed at all later on.
Be sure to use the small blue ADD A COMMENT button located just below the text of this solution to leave any additional comments for me regarding this particular issue and I will respond right away.
I truly hope that was helpful to you.
Good luck and take care.
Joe.
Nov 27, 2011 | Kenwood Microwave Ovens
Setting the clock on a microwave what is the last action after setting the time. Everything I've tried results in the error message coming up.
According to the manual this is how to set clock.
To set the clock, press "Clock" once or "Timer/Clock" twice (depending on your keypad).
Enter time of day. The time appears in the window; the colon continues to flash.
Press "Clock" or "Timer/Clock" again - colon stops flashing; time of day is set.
If you need the manual it is on link below.
http://service.us.panasonic.com/OPERMANPDF/NNH624-SET%20UP.PDF
Good Luck
Nov 08, 2010 | Panasonic NNH965BF Microwave Oven
Round soft key OXO Timer I need to change the clock time their model # is 1061978
Operating functions:
To set the clock, press and hold the clock/timer button for three seconds. A clock icon will appear on the left side of the screen. Input the time using the numerical buttons and then click the clock/timer button to save the time.
To set the timer, press and release the clock/timer button so that the display shows all zeroes. Enter the desired time using the keypad. Press start/stop to start the countdown. The countdown may be paused by pressing the stop/start button and resumed by pressing the same button again.
When countdown is complete, timer will beep continuously for thirty seconds and display will flash. Timer will then beep every ten seconds for ten minutes until the stop/start button is pressed.
This timer will also time up to time activities. To start count up, press clear/memory so timer reads all zeroes. Press stop/start and a plus sign will appear on the right side of the screen as the timer begins counting up.
Sep 18, 2010 | Microwave Ovens
Panasonic NNSD297SR 1200 Watts Microwave Oven Logo
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
