Question about Humminbird 787c2 Combo GPS Receiver
On my 787c2i says gps fix required for this operation
I want to use sat nav on the tablet but it needs gps. how do i get gps on the tablet
To my knowledge, GPS on a tablet requires internet Access if it is not built into the tablet. You would need an application that would use the internet for GPS.
Aug 28, 2015 | Archos Arnova 10b G3 Tablet
How do i change language from panasonic strada GPS
I think this type of GPS is made specially for Japan area, and to change language and maps for your location in order to be working on your locations, the original panasonic DVD operation/setting disk is required which should be provided with panasonic strada GPS
Feb 28, 2015 | Panasonic Strada CN-NVD905U GPS Receiver
I need operating instructions
You can download the operating instructions in PDF format by clicking this link.
Adobe PDF Reader is required to view this manual. Download Adobe Reader
Thanks for using FixYa.
Sep 29, 2011 | Bushnell BackTrack Point-5 GPS Receiver
Operating Instructions for Bushnell backtrack GPS locator
You can download and print the instruction manuals in PDF format by clicking these links:
Quick Start Guide
Full Operating manual
Adobe PDF Reader is required to view the manual. Download Adobe Reader
Hope this helps. Kindly let me know if you have any difficulty in downloading the manuals.
May 12, 2011 | Bushnell BackTrack Handheld GPS Receiver
After using nagivator operation the response is Unable to launch application Problem ? How do I fix the problem?
This is a software problem that requires the Magellan GPS software on your GPS device to be updated the latest version, or sending the GPS device in for repairs and updates.
I would recommend sending the GPS device in for repairs since many people have had no luck updating the software when having the Unable to launch application error.
Here is a link to the MagellanGPS Technical Support page:
http://support.magellangps.com/support/index.php?group=default&languageid=1
Feb 15, 2011 | Magellan GPS
My unit display note gps fix required for this operation? I can't see nothing only white page.My model # is385ci
I would contact our customer service group and see if they can help you out. The number is 800-633-1468.
Joby @ Humminbird
Jan 06, 2011 | Humminbird 385ci Fishfinder Chartplotter...
I installed garmin xt but the signal for gps is 0
Hi
The samsung B7320 takes a real long time to get the 3D fix thats required by the navigatin softwares.
Check the following
1) In manual for see how GPS needs to be configured. I would recommend you keep the settings to Intermediate GPS driver.
2) If the settings are done as per requirement, take your phone in an open space and then see if the signals are available. Be patient as the fix takes a real long time sometimes even few minutes.
3) If the problem of no signals persists you need to test if your GPS chipset is working. Use turbo GPS for this.
Nov 12, 2009 | Samsung Omnia Pro B7320 Smartphone
I can not get a GPS fix from any satellites on my Lowrance H20C GPS. Is there a trick to doing a hard reset or something to fix this? I am running software version 1.1.0 - Build LL2358E / JR1754C if that...
Hello thekernel,
In order for the GPS to get a fix it needs to receive telemetry information from three or GPS satellites. To do that it needs a clear view of the sky. Local geography such as mountains, hills, tall buildings and heavy forest can block the GPS's ability to receive satellite telemetry. The same thing can happen if you are trying to operate the unit indoors or inside of a vehicle without an external antenna. That's why most GPS receivers are installed at the lowest point in the car that has a clear view of the windshield and side windows - such a location provides the best view of the sky.
To test it your GPS, try using the device outside in a relatively open area with a clear view of the sky in all directions. It should acquire a satellite fix in about five minutes or less. If not, then the unit may have an a hardware or antenna failure that would require service.
Best Regards,
Ken
"Go Ahead. Use Us."
Jul 08, 2008 | GPS
My son is in Houston, Texas and cannot get his unit to turn on! He is trying to find out if your system is down or is his unit broken?
Hello nonjoe869,
Most GPS receivers do not require any network to operate. The satellites calculate their current location based on information received from Global Positioning Satellites. However those satellites operate continuously. The only way that the user would experience an "outage" is to be in a place without a clear view of the sky (underground, in a hardened building, etc.). Even then the GPS would still turn on and many functions would operate. It would just not be able to acquire satellites or issue location reports.
That said, if the GPS is part of another device (such a cell phone) that does require a network, the network status could have an impact on the GPS. A network outtage isn't going to prevent the device from actually turning on, however. If the GPS won't turn on at all it is likely a problem with the GPS or the power source.
Best Regards,
Ken
"Go Ahead. Use Us."
Jun 25, 2008 | GPS
Humminbird 787c2 Combo GPS Receiver Logo
163 people viewed this question
Top Humminbird GPS Experts
Mike Marcotte
Mike Marcotte
Steve
Steve
Jerry Greenberg
Jerry Greenberg
Are you a Humminbird GPS Expert? Answer questions, earn points and help others
