Question about Dryers
Vintage Oscillating Electric Table Fan ~ Repair & Service
Where can I find info on how to take apart and repair an old electric fan?  I need to re-wire this metal table fan.  I've got is dissembled - as far as I can go, without worrying about doing something I shouldn't. [Have got the wire cage off and the oscillating control off.] What I really need is a repair guide/manual on how to get into the motor housing, and what to do once I'm there.  I'd also like to know if the blades can be removed from the motor housing, such that they can be separately cleaned/painted.  I've got an old Spartan, probably from the 1920s [?].  Is there a website that addresses this issue?  A website that offers old manuals?  Help...?
Go to this link, hope you might find something useful.
http://www.hudsonscustommachining.com/FAQs.doc
or you can go to this URL http://www.vintagefans.com/contact.htm and post your question there.
Posted on Sep 29, 2008
    Problem Solver:
  • 14 Answers
Http://www.dtvintagefans.org/Join this website, and it is most likely someone here can help you. I am also currently a member of this website, and we are always glad to welcome new members!
Posted on Oct 16, 2013
Fan works only if held at certain angle
Posted on Jun 16, 2009
Tip
Casablanca Table Fan, DOA
If your Casablanca Fan (1928D) Table Fan has stopped working completely, or stopped in the middle of oscillating, it might be the internal AC wire that runs up the middle of the fan base, that is broken internally. First, make sure the fan is not plugged in. You have to take the whole fan apart from the front. Check for continuity on the white and black wires that run to the motor. You may have to pierce the black and white wires with a pin to check them, because they are wired directly into the motor. These two wires have a black jacket covering them that can be pulled off if you find an open wire. Either one of these wires can break internally because of the back and forth movement. Cut the wires close as necessary to the motor to make the splice. Solder and use heat shrink insulation and route the new wire back down through the base and splice them where the original wires were. I used a piece of electrical cord with white and black conductors that was cut off an appliance that was dead. It was the same size as the original so it fit well. Please note, this repair requires electrical and mechanical knowledge. You have to take the whole fan apart to do this repair.
on Apr 21, 2014 | Casablanca Fan (1928D) Table
Is Casablanca Zephyr Table fan # 1928C available???
It is. $50 on eBay.
  • Casablanca Zephair Desk Fan Table Fan Model 1928D ' eBay www.ebay.com > Search > Casablanca Zephair Desk Fan Table Fan Model 1928D Find best value and selection for your Casablanca Zephair Desk Fan Table Fan Model 1928D search ... Vintage CASABLANCA Model 1928C Floor Fan 120vac 60HZ ...
  • Casablanca Fan Zephyr Oscillating Desk - sears.com www.sears.com/search=casablanca fan zephyr oscillating desk Home / Results For: "casablanca fan zephyr oscillating desk" ... SYBA 8-inch Tall Personal Table Mini Oscillating Fan, 2-Speed, Adjustable Head, Black.
  • Casablanca Zephair Desk Fan (Table/Desk Fan) 1928D in ... www.hansenwholesale.com/ceilingfans/casablanca/model.asp?ProdNo=1928D Casablanca Zephair Desk Fan (Table/Desk Fan) Model 1928D. Choose Custom Options & Accessories Here. ... The Casablanca Zephair Desk Fan is UL Listed for ...
  • Casablanca Fans Zephair Floor Fan Portable Fan 1928F www.casablancafansonline.com > ... > Portable/Freestanding Fans Casablanca Fans Zephair Floor Fan Portable Fan ... This 0.0 light Portable Fan from the Zephair Floor Fan collection by Casablanca Fans will enhance your home with a ...
  • Mar 24, 2016 | Casablanca Fan Zephair 19N8C Table
    I have a swan vornado oscillating table fan. I
    Stop loving it. The new fans won't even last a few years.
    Oct 14, 2014 | Dryers
    Light in ceiling fan burned out even after i changed bulb
    probably burnt the electric feed wire off the light bulb socket. you will have 2 find the circuit breaker to the fan/light and turn the breaker off & then take the light section of the ceiling fan apart & look at the socket for a burnt off wire. you will need diagonal cutters to cut off the wire section with burnt insulation and wire strippers to stripe off the insulation, about 3/4 of an inch. you might be able to reconnect the wire to the light bulb socket if the socket has screw terminals but some sockets have solder terminals and require you to be able to solder the wire back on with an electric soldering gun, which cost between $12.00 to $ 30.00 you could see the cost of the tools at amazon.com
    also need solder and soldering flux at radio shack,home depot
    amazon.com or lowes.com
    If you need to add an extra length of wire you can connect it with wire nus from home depot.
    home depot sells books on lamp repair and on electrical repair or borrow the book from the library.amazon .com may even have used books on lamp repair and home electric repair for sale at 1/2 price or less.
    Jul 29, 2012 | Hampton Bay 24002 Ceiling Fan
    Vintage emerson electric table fan started making high pitched noise and now the blades will not turn. Even off I can't get them to rotate freely. It has never been serviced or oiled.
    The motors on ALL fans have a shaft going thru the motor which turns as a result of the pulsation of AC current.
    The shaft is maintained in the center of the motor but alas parts wear out. Metal on metal (the squeaking sound) indicates the parts are wearing.
    The stopping (seizing) of the fan blades indicates that any movement of the shaft is no longer possible due to friction.
    As repair, a technician could keep the casing and install a new motor.
    good luck and don't forget to vote!!!
    Sep 29, 2010 | Emerson Dryers
    Oscillating table fan makes banging noise when rotating
    mcdevito75 here, Sounds like that oscillating swtich is either a little loose or could use a drop or 2 of 3 in 1 oil. Try to twist offf the oscillating swatch button and see if you can tighten it or put a drop of oil on it.
    Jul 24, 2010 | Holmes Products Holmes HASF1304S-UC 12",...
    Vintage General Electric Range
    Lazidaisies,
    you asked where can I find a service manual for a vintage stove? General Electric, 24"wide, push-button, electric; 1950s.
    Placard on inside of oven door is "erased", except for embossed numbers: On the Left = 1 1245W2M2 10 7 On the Right = NM28552
    You should go to GE and call them on the phone. They will have th resources to give you this Manuel!
    bless you,
    huuum
    Please rate me before you sign off
    Sep 12, 2008 | Kitchen Ranges
    Wiring
    12,000-BTU Portable Air Conditioner with Manual ... 3135 30-Inch Oscillating Industrial-Grade Pedestal Fan ~ Lasko ... 42.62 : Soleus Air FCM-30 12-Inch Convertible Stand/Table Fan ...
    Aug 25, 2008 | Lasko 1820 Stand (Pedestal) Fan
    Dryers Logo
    4,112 people viewed this question
    Top Dryers Experts
