Question about Acer Aspire One D255-2670
How do you install bluetooth on the netbook without using a bluetooth device?
    Master:
  • 525 Answers
You can get a bluetooth usb adapter and connect it to the usb port
Posted on Mar 13, 2011
Lenovo a516 phone cannot transfer and received files from acer netbook
Without the proper drivers, a connection will not be achieved. Did you install the communication drivers? Your computer may show you that a Bluetooth device is present, but without communication drivers, you just have dead space.
Jan 03, 2014 | Lenovo 3000 Y410 Notebook
Enable bluetooth
Activate the Bluetooth features of your Acer Aspire to unlock your laptop's wireless function. Bluetooth technology allows your computer to control and share data with external devices without having to use a connection cable or download drivers.
In order to establish the connection with other enabled devices, you must first enable the Bluetooth antenna so other devices can locate your computer.
Press the "Bluetooth" button found just above the keyboard.
The LED above the button should illuminate.
Click "Start," "Control Panel" and "Add a Device."
Your Acer scans for other Bluetooth devices in the area.
Click the name of the device in the window that appears, and click "Next" to establish a connection with the external device.
Aug 03, 2013 | Acer Aspire One D150-1587 Netbook
Usb dongle is not working
Step 1:
A Bluetooth dongle is an external Bluetooth device used to enable your PC's Bluetooth connection. Many Bluetooth dongles come without installation disks since the software is pre-programmed into the actual USB stick. These Bluetooth dongles are very useful on netbooks that don't have Bluetooth connection, since netbooks have no CD-Rom drives. Turn on your PC. Insert the USB Bluetooth dongle into the USB port on your desktop tower, or the USB ports located on the perimeter of your laptop. Wait for the program to auto run. Once you connect your dongle, the driver program should launch. Follow the onscreen prompts to install the dongle. A dialogue box should open that says "Installing Drivers" from the taskbar. Allow the driver to install completely before closing the box. Unplug the dongle and restart your PC. Once the PC has been switched on, insert the dongle. Double-click "My Bluetooth Places." This is the Bluetooth icon located in your taskbar, and it should launch the "Initial Bluetooth Configuration Wizard." Click "Next" on the first screen. Next, type in the name of your computer and select your computer type from the drop-down menu, then click "Next." Click "Skip" on the onscreen prompts, then finish. Pairing the Devices Turn on your external Bluetooth device. Double-click "My Bluetooth Places." Select "Find Bluetooth Devices." The name your Bluetooth device should display in the next window. Right click the icon for your Bluetooth device, and scroll down to "Pair Device." Enter the Bluetooth pin code for your external device in the "Bluetooth Pin Code Request" pop-up window. Then click "OK." The default pin code is normally "0000" or "12345." You can find your pin code in your user manual. If you are pairing a cell phone to your PC, you will have to enter the same pin code on your cell phone to establish the Bluetooth connection.
Apr 10, 2013 | Computers & Internet
How to connect bluetooth to my computer
If you have a laptop you have inbuilt application that helps connect laptop with other Bluetooth devices. If you are using a desktop there are many USB-based Bluetooth adapters available that will let you connect Bluetooth peripherals to your PC.
Sep 04, 2012 | Acer Aspire One D255E13438 Netbook
How can i activate pre-installed webcam in my dell inspiron mini 1012
Step 1: First connect the bluetooth device to USB port on your computer and check that it is detecting on your computer or not.
Step 2: Now insert the bluetooth software driver CD to your system that will auto start after few seconds then follow instruction to finish bluetooth software installation.
Step 3: Now go to 'start -> Devices and Printers' and click 'Add a device' from top of the window.
Step 4: Now your Windows 7 system will search the bluetooth device which connected to your system.
Step 5: Click the bluetooth device you want to install from the list and then click the 'Next' button and wait for windows to configure the bluetooth device. If prompted to enter a passcode, enter the default code listed in the bluetooth device manual. In many cases, the default passcode will be '0000'.
Now the bluetooth device has successfully installed and ready to use.
Note: If you bluetooth device was not listed in the search results from Step 4, make the device discoverable. Access your Bluetooth-enabled device's settings page, and turn on the device's 'Listen' or 'Discoverable' function to allow you computer to find it.
Feel free to get Dell technical assistance anytime at http://www.vtechsquad.com/dell-support/
Apr 10, 2012 | Dell Inspiron Mini 1012 Netbook...
How to fix the bluetooth of my laptop i can't connect.
first we have to check if the device is detected by the PC if yes...then u need to add the device first and then only u can transfer files....also need to make sure that the bluetooth in ur handset is in discoverable mode...then go to bluetooth places and add the device...once added u will be able to trf files...
Feb 13, 2012 | Samsung N150 Netbook
How to connect Microsoft Bluetooth mouse 5000
Please refer to the below KB article, this will help you.
http://support.microsoft.com/kb/952818
Please rate if you like..Thanks
Aug 20, 2011 | Acer Aspire One AOD150-1920 Netbook
EVEN IF I PRESS FN PLUS F3, THE BLUETOOTH IS STILL OFF
have you install the drivers supplied with your bluetooth device?
Feb 07, 2010 | Acer Aspire One 751h-1885 Netbook
Microsoft Bluetooth Notebook Mouse 5000 does not connect
Install the winxp driver under compatability mode win xp sp3 might do the trick, otherwise search the right driver. you can also use driverpack sollutions but be aware they want to install all kinds of software you do not need, unbox the things you do not need before hitting install.
before you install anything, find a place near you, im in the Netherlands so the links are dutch!
You can burn it to a dvd or just hit install online, again look and do not install all the software that comes with it, like opera mozilla etc etc
Good luck
driverpack sollutions Google Search
Jan 20, 2018 | Microsoft Bluetooth 5000 Mouse
Can u put bluetooth on one without it built in
yes!
there is a tiny device called : a bluetooth dongle , plug it to one of the usb pluges on the laptop and thats the whole story.
google,ebay,amazon or localshop for it. should be well cheap!
good luck
Nov 05, 2009 | Acer Aspire One Netbook 8.9" Notebook
Acer Aspire One D255-2670 Logo
168 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
