Question about LG Washing Machines
My washer will not continue the cycle and the code IE comes on the screen whats this mean?
    Brigadier General:
  • 6,277 Answers
For most LG's 'IE' means Inlet Error i.e. problem with the water supply.
A few possible causes- the taps are not full on, the hoses are squashed/kinked, the water supply inlet valve is malfunctioning or the control pcb is malfunctioning. Or it could be lying ;-0)
Obviously you can check the taps and hoses AND have a listen around the inlet(s) and you should be able to hear the valve(s) operating. If you cannot- sorry, service call ;-0(
Good luck,
John C
Posted on Mar 13, 2011
What does code uL mean. this comes on in the drain spin cycle
Hi, a UL error code means a load not balanced. The washer is running a load-balance correction routine. Please allow the washer to continue. If the dial is flashing and the washer has stopped, redistribute the load, close the lid, and press START/PAUSE.
Aug 14, 2016 | Whirlpool WTW8200YW 4.6 cu. ft. Cabrio...
Nf code and donnot continue to next cycle
Samsung Washer Error Code NF (Fixed ...
www.appliancerepairlesson.com/.../samsung-washer-error-code-nf-fixed/
Jan 11, 2014 - What does the error code NF mean on a Samsung washer? ... You can set the washer to any cycle and test each solenoid for proper voltage. ... Next would be to check the screens on the back where the water hoses connect. ..... Hi, you don'thave any power to the water valve wires when it should be filling?
Dec 15, 2015 | Frigidaire Affinity ATF7000E Front Load...
An IE code comes on my washing machine and when this happens it does not go through the final rinse cycle
Error code of "IE" signifies a water inlet error.
This means that your machine is not filling to the proper water level, and may be fixed by ensuring that machine's water supply is properly connected and turned on. Also, this means that the washer has not filled with water in 8 minutes.
Hope helps.
Jun 14, 2011 | Washing Machines
What does error code 6P mean on an Amana washer model LW9203W2B
SH: Open thermistor. Unplug appliance and let rest for 15-30 minutes, then plug back in. If code continues, unplug appliance and call for service.
bP: Pressure switch error sensed. Washer will not operate when this error is displayed. Check for pinches or kinks in the water inlet hoses and straighten if necessary. Check the water inlet hoses filter screens and clean if needed. Verify that the water supply is turned on. Unplug washer and let rest for 15-30 minutes, then plug back in. If code continues, call for service.
rP: Water supply problem in spin cycle. Check for pinches or kinks in the water inlet hoses and straighten if necessary. Check the water inlet hoses filter screens and clean if needed. Verify that the water supply is turned on. Unplug washer and let rest for 15-30 minutes, then plug back in. If code continues, call for service.
LO: Lock Out mode. To activate, press START and STOP/OFF pads at the same time. To deactivate, repeat the procedure.
AU: Flashes when a factory preset cycle is put on hold. A normal function.
Clean Filter: Flashes when a cycle is selected as a reminder to clean the filter before starting a cycle for optimum drying results. Code clears when the door is closed and the START pad is pressed.
Dec 29, 2009 | Amana Washing Machines
IE error code
The "IE" code indicates a water inlet problem. If the correct water level is not reached in eight minutes, this code is generated. Check the water inlet valve. Unplug the machine, turn off the water, and remove the water supply hoses. Check the small metal screens inside the openings on the water inlet valve. Make sure they are clear of rust or debris. Check the solenoids using a multimeter or ohmmeter.Check for continuity. A lack of continuity means a bad solenoid and the water inlet valve assy will have to be replaced. I'll attach a photo for reference. Sorry for your trouble and I hope this helped. Best wishes.
Sep 24, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
What does "IE" mean when it attempts spin cycle?
is it IE or LE please confirm it. if it is LE code the fixing procedure is given below This usually happens if you're washing on a delicate setting with a moderate load of clothes. Apparently, delicate also means very few items to wash. To clear the LE code - no need to unload the clothes:
1. Press the power button to turn the washer off.
2. Press the power button to turn the washer back on.
3. Cycle the spin cycle selection to 'no spin'.
4. Press start.
The washer should set to one minute, lock the doors, then drain out the excess water.
Once the 'End' cycle comes up, unplug the machine for several minutes.
Plug the washer back in, press the power button, then set the washer to 'normal' with 'low' spin setting.
Note that the only difference between the normal setting and delicate is the wash time and spin cycle speed. If you have a moderate to large load of delicates, use the normal setting on low spin cycle. The clothes really don't care. Also, make sure you're using 'HE' detergent - low suds. Regular degergent in a front load is not recommended.
Jul 19, 2009 | LG WM1814CW Front Load Washer
LG washer code LE or IE showing up
LE Code continues to appear. What does this mean and how to fix problem?
Pete
Nov 18, 2008 | LG WM1814CW Front Load Washer
Won't run
found a pf not an a fp
PF Power Failure PF flashes if the washer loses power during a running cycle. The washer does not flash PF when it is first plugged in.
Press START to continue the cycle from the moment that power was lost -OR-
Press STOP/CANCEL to clear the display and completely cancel the cycle.
Apr 04, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Washing Machines Logo
43 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
