Question about Garelick S.S. Motor Bracket for 2-Stroke Outboards
Do outboards by johnson have a lock for the outboard steering. my steering will not move but it is not the teleflex cable as tghat moves freely. it appears to be locked on the other side to where the cable goes in.
    Novelist:
  • 184 Answers
Think "tildeck" HAS the problem- so find the grease nipple and shoot some grease there. If that doesn't work= add some heat - some times the ox axe torch will move it, would commend disconnecting the motor from the cable to confirm the problem
Posted on Dec 14, 2011
  • 48 Answers
If the motor has been sitting it might be siezed by rust. There is a greaase fitting on all outboards to lubricate the shaft that it turns on. Look under the head near your transom and it is probably there. I am thinking this may be your problem.
Posted on Mar 13, 2011
Steering gear
Hi Alfred.
Your answer will depend on the fishing boat.
For really small boats, with an outboard motor on the back, the motor will be on a pivot joint, and have a handle in front. You point the running motor side to side to steer the boat.
Larger boats with outboards will have a steering wheel with a mechanical linkage to an outboard motor or motors that will pivot them side to side to steer.
Larger fishing boats, especially commercial boats, will have an inboard engine and prop shaft, a fixed external propellor or propellors, and a rudder that is connected with a mechanical linkage to the steering wheel or ships-wheel to move the rudder side to side and steer the boat by deflecting how the water flows by when under way.
Hoping this helps.
D
Dec 16, 2015 | Boating
How to set timing on 75 hp johnson outboard
creates an impulse to the cid as a magnet passes by . not much adjustment to timing small screw toward the front that moves the stator perhaps a 1/4 inch .
Aug 17, 2015 | Johnson Evinrude Timer Base, 6 Cyl 75-85...
Steering wheel wont move right or left engine wont move don't want to force it
inboard or outboard motor ??
unbolt the steering cable from the steering point of the engine or leg unit , then try turning the wheel and if it moves then try moving the engine or leg unit and see if it moves !?
Mar 27, 2015 | Boating
Massey ferguson 283
look for small set screw or allen key screw locking cap
Jul 25, 2014 | Teleflex Seastar Outboard Steering...
Steering shaft stuck and will no move left or right Johnson 90 hp outboard
Try to tun shaft with vice grip or Stilton wrench(bobbyaan spanner)put spanner nearest to end,try not to damage shaft.if shaft will not turn you will probably have to cut cable and knock out from other side
Aug 26, 2013 | Sierra International 18-4310 Marine...
Outboard helm cable locked up
Either gears are broken,cable is seized or cable is seized where it goes thru motor,if this is the case try and turn shaft with vies grips or monkey wrench
Mar 17, 2013 | Teleflex Safe T Helm (Old Style)...
Outboard is locked to one side , can't find the catch to release it,
In The Middle Of The Engine Just Below The Cowl Is A Small Lever
Move It Counter Clockwise To Release The Co Pilot
Mar 15, 2013 | Boating
I have a sailboat with a 9. outboard should the motor be moving as I steer with the tiller?
Normally with such a set up you increase the steering friction adjustment till the motor is to all intents and purposes locked solid.
I don't recommend having it moving if you can stop it .
May 31, 2010 | Light Outboard Motor Boat Bass Fishing...
I have a 50 hp 1975 Johnson outboard. When I turn
There is a switch in the control box that locks out the start unless you are in neutral. Open the box and put in a new switch,this is a safty device to keep it from starting in forward and throwing you out of the boat. Jim OMC retired Mech
Jul 07, 2009 | Boating
Need to know how to set up carb on 1985 johnson outboard. front adj on the carb got moved looking for starting point to get me close to running.
try disconnecting the throttle cable, loosen carb linkages, assure that both carbs are FULL closed....tighten linkage - and cable ...check for FULL open and close with the throttle....this will be your starting point, advise to get a service manual for your outboard model to correctly adjust the carbs for max performance....GL hope this helps..
Jul 04, 2009 | Sport & Outdoor - Others
Garelick S.S. Motor Bracket for 2-Stroke Outboards Logo
229 people viewed this question
Top Garelick Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Garelick Boating Expert? Answer questions, earn points and help others
